I had a thought to use xavier to run Houdini and/or Cinema 4d as they both have linux versions . However, It seems that they have strict hardware requirements as from the Houdini hardware compat info:
- Intel or AMD x64 CPU with SSE 4.2 required. Houdini 18.0 will not run on a system with an instruction set lower than SSE 4.2.
I also see conflicting info about open GL (2019…no, but example from 2020)
So am I correct that is a no-go? Has anyone got it to run on Xavier or Nano?
