Xavier B has occured some problem ,i cant login it and when i login it with minicom it shows Data abort
Exception: Data abort
DFAR: 0x03c10000, DFSR: 0x00001008
PC: 0x0c480814
LR: 0x0c4837a7, SP: 0x0c49c6d0, PSR: 0x4000003f
R0: 0x0c4907d4, R1: 0x00000000, R2: 0x0000000d
R3: 0x03c10000, R4: 0x0c4953fc, R5: 0x0c480b0d
R6: 0x8100000d, R7: 0x07b5ad45, R8: 0x00000000
R9: 0x00000000, R10: 0x00000000, R11: 0x00000000
R12: 0x00000000
Hi Zhenfeng,
Can I know if you had flashed the system to Drive Software 9.0?
If not, could you please try to flash Drive Software 9.0?
i had flashed it
Dear Zhrnteng,
Could you checking reflashing the board and share logs if you still have this issue.
I have the same issue, I have just flashed with Drive 9.0 and can no longer access xavier B via minicom and no HDMI output is present.
DRIVE_Software_9.0_Linux_hyperion.tar.gz (399 KB)
i had flashed it A+B again , and flashed failed but i can login it via minicom . emmm…
Dear Zhenfeng,
Could you please attach the SDKM logs(Default path /.nvsdkm/logs/) to investigate the issue.
where is the path /.nvsdkm/logs
Dear Zhenfeng,
Default path of logs are ~/.nvsdkm/logs/ and ~/.nvsdkm/sdkm.log
Hi Zhenfeng,
Is this still an issue? Or please attach the SDKM logs(Default path /.nvsdkm/logs/) to investigate the issue.
