A few days agoI shut down my PC normally, using the shutdown option in the far right corner. Now when I try to start the computer, the screen is completely black. When I move the display port cable to the back of the PC, i can access it using the terminal. It says “net eth0: failed to reset MAC” and then I’m prompted with a login. It then says " This system has been minimized by removing packages and content that are not required on a system that users do not log into . To restore this content, you can run the ‘unminimize’ command." Running the “unminimize” command and rebooting does not solve my error. I want to access the PC using the regular OS through the display port on the front.
Update: Immediately after booting, the following lines are shown in the terminal:
[7.299693] tegra-xudc-new 3550000.xudc: extcon_get_extcon_dev_by_cable failed -19
cp: no writing through dangling symlink ‘etc/resolv.conf’
[10.592307] cgroup: cgroup2: unknown option “nsdelegate”
[11.861979] random: crng init done
[11.862131] random: 7 urandom warning(s) missed due to ratelimiting
[12.400928] mttcan c310000.mttcan can0: bitrate error 0.2%
[12.415224] mttcan c320000.mttcan can1: bitrate error 0.2%
