ray_lo
June 22, 2020, 8:52am
1
We have issue using c-phy to get image.(L4T 32.4.2)
Here’s our device tree setting & trace log.
Oscilloscope show there are signals coming out from sensor.
Is there any configuration we missed?
DT:
host1x {
vi@15c10000 {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
e3387_vi_in0: endpoint {
port-index = <0>;
bus-width = <3>;
remote-endpoint = <&e3387_csi_out0>;
nvcsi@15a00000 {
num-channels = <1>;
//#address-cells = <1>;
//#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3387_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <3>;
remote-endpoint = <&e3387_ov5693_out0>;
port@1 {
reg = <1>;
e3387_csi_out0: endpoint@1 {
remote-endpoint = <&e3387_vi_in0>;
i2c@3180000 {
ov5693_a@36 {
compatible = "nvidia,ov5693";
/* I2C device address */
reg = <0x36>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "3.674";
physical_h = "2.738";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
iovdd-reg = "vif";
/* Sensor output flip settings */
//vertical-flip = "true";
mode0 { // OV5693_MODE_2592X1944
mclk_khz = "24000";
num_lanes = "3";
phy_mode = "CPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
//cil_settletime = "20";
active_w = "8000";
active_h = "6016";
mode_type = "bayer";
pixel_phase = "bggr";
csi_pixel_bit_depth = "10";
readout_orientation = "0";
line_length = "8000";
inherent_gain = "1";
mclk_multiplier = "100";
pix_clk_hz = "1800000000";//1416000000
gain_factor = "10";
min_gain_val = "10";/* 1DB*/
max_gain_val = "160";/* 16DB*/
step_gain_val = "1";
default_gain = "10";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "1816577";/*1.816577 */
max_framerate = "30000000";/*30*/
step_framerate = "1";
default_framerate = "30000000";
exposure_factor = "1000000";
min_exp_time = "34";/* us */
max_exp_time = "550385";/* us */
step_exp_time = "1";
default_exp_time = "33334";/* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3387_ov5693_out0: endpoint {
port-index = <0>;
bus-width = <3>;
remote-endpoint = <&e3387_csi_in0>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <3>;
max_lane_speed = <2500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <1000000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
module0 {
badge = "e3387_front_P5V27C";
position = "rear";
orientation = "1";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "ov5693 2-0036";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/ov5693_a@36";
Trace Log:
root@localhost:~# cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 389/389 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _---=> hardirq/softirq
|| / _--=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:4-3595 [000] .... 29.730590: rtos_queue_peek_from_isr_failed: tstamp:1248742473 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 29.898396: rtos_queue_peek_from_isr_failed: tstamp:1253742400 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 30.066451: rtos_queue_peek_from_isr_failed: tstamp:1258742433 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 30.178475: rtos_queue_peek_from_isr_failed: tstamp:1263742438 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 30.346470: rtos_queue_peek_from_isr_failed: tstamp:1268742431 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 30.514436: rtos_queue_peek_from_isr_failed: tstamp:1273742431 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 30.682666: rtos_queue_peek_from_isr_failed: tstamp:1278742470 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 30.850457: rtos_queue_peek_from_isr_failed: tstamp:1283742470 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 31.018536: rtos_queue_peek_from_isr_failed: tstamp:1288742440 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 31.186618: rtos_queue_peek_from_isr_failed: tstamp:1293742438 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 31.298577: rtos_queue_peek_from_isr_failed: tstamp:1298742473 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 31.466417: rtos_queue_peek_from_isr_failed: tstamp:1303742435 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 31.634448: rtos_queue_peek_from_isr_failed: tstamp:1308742434 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 31.802504: rtos_queue_peek_from_isr_failed: tstamp:1313742474 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 31.970471: rtos_queue_peek_from_isr_failed: tstamp:1318742400 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 32.142383: rtos_queue_peek_from_isr_failed: tstamp:1323742438 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 32.254511: rtos_queue_peek_from_isr_failed: tstamp:1328742431 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 32.426609: rtos_queue_peek_from_isr_failed: tstamp:1333742434 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 32.594400: rtos_queue_peek_from_isr_failed: tstamp:1338742438 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 32.762405: rtos_queue_peek_from_isr_failed: tstamp:1343742438 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 32.934405: rtos_queue_peek_from_isr_failed: tstamp:1348742439 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 33.102479: rtos_queue_peek_from_isr_failed: tstamp:1353742470 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 33.214512: rtos_queue_peek_from_isr_failed: tstamp:1358742472 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 33.382564: rtos_queue_peek_from_isr_failed: tstamp:1363742470 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 33.554432: rtos_queue_peek_from_isr_failed: tstamp:1368742473 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 33.666369: rtos_queue_send_from_isr_failed: tstamp:1371532947 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 33.666375: rtos_queue_send_from_isr_failed: tstamp:1371533255 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 33.666376: rtos_queue_send_from_isr_failed: tstamp:1371533550 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 33.666378: rtos_queue_send_from_isr_failed: tstamp:1371533846 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 33.666379: rtos_queue_send_from_isr_failed: tstamp:1371534139 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 33.666381: rtcpu_string: tstamp:1371534952 id:0x04010000 str:"Configuring VI GoS.
kworker/0:4-3595 [000] .... 33.666420: rtcpu_string: tstamp:1371535315 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:4-3595 [000] .... 33.666435: rtcpu_string: tstamp:1371535735 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:4-3595 [000] .... 33.666450: rtcpu_string: tstamp:1371536224 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:4-3595 [000] .... 33.666467: rtcpu_string: tstamp:1371536630 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:4-3595 [000] .... 33.666479: rtcpu_string: tstamp:1371537035 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:4-3595 [000] .... 33.666491: rtcpu_string: tstamp:1371537443 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:4-3595 [000] .... 33.666529: rtcpu_string: tstamp:1371548499 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol versi"
kworker/0:4-3595 [000] .... 33.666531: rtcpu_string: tstamp:1371548767 id:0x04010000 str:"on 2.2
kworker/0:4-3595 [000] .... 33.666543: rtos_queue_send_from_isr_failed: tstamp:1372017666 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 33.666545: rtos_queue_send_from_isr_failed: tstamp:1372017846 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 33.666546: rtos_queue_send_from_isr_failed: tstamp:1372018014 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 33.666547: rtos_queue_send_from_isr_failed: tstamp:1372018170 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 33.666548: rtos_queue_send_from_isr_failed: tstamp:1372018327 queue:0x0bcbc160
kworker/0:1-808 [000] .... 33.726409: rtos_queue_peek_from_isr_failed: tstamp:1373742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 33.782412: rtos_queue_send_from_isr_failed: tstamp:1375169952 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 33.782418: rtos_queue_send_from_isr_failed: tstamp:1375170113 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 33.782419: rtos_queue_send_from_isr_failed: tstamp:1375170275 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 33.782420: rtos_queue_send_from_isr_failed: tstamp:1375170432 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 33.782421: rtos_queue_send_from_isr_failed: tstamp:1375170587 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 33.782423: rtcpu_string: tstamp:1375171464 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:4-3595 [000] .... 33.782462: rtcpu_vinotify_event: tstamp:1375177299 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1055850336 data:0x10000000
kworker/0:4-3595 [000] .... 33.782464: rtcpu_vinotify_event: tstamp:1375177452 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1055857344 data:0x31000001
kworker/0:4-3595 [000] .... 33.782465: rtcpu_vinotify_event: tstamp:1375177625 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:1055859136 data:0x07020001
kworker/0:4-3595 [000] .... 33.782466: rtos_queue_send_from_isr_failed: tstamp:1376104767 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 33.782468: rtos_queue_send_from_isr_failed: tstamp:1376104930 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 33.782469: rtos_queue_send_from_isr_failed: tstamp:1376105092 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 33.782470: rtos_queue_send_from_isr_failed: tstamp:1376105252 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 33.782471: rtos_queue_send_from_isr_failed: tstamp:1376105409 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 33.782472: rtcpu_vinotify_event: tstamp:1376199235 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1085752128 data:0x10000000
kworker/0:4-3595 [000] .... 33.782473: rtcpu_vinotify_event: tstamp:1376199411 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1085759200 data:0x31000002
kworker/0:4-3595 [000] .... 33.838455: rtos_queue_send_from_isr_failed: tstamp:1376878837 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 33.838461: rtos_queue_send_from_isr_failed: tstamp:1376879000 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 33.838462: rtos_queue_send_from_isr_failed: tstamp:1376879162 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 33.838491: rtos_queue_send_from_isr_failed: tstamp:1376879319 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 33.838492: rtos_queue_send_from_isr_failed: tstamp:1376879476 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 33.838495: rtcpu_nvcsi_intr: tstamp:1377225664 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000100
kworker/0:4-3595 [000] .... 33.838496: rtcpu_nvcsi_intr: tstamp:1377225664 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:4-3595 [000] .... 33.894415: rtos_queue_peek_from_isr_failed: tstamp:1378742400 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 33.894422: rtos_queue_send_from_isr_failed: tstamp:1378871378 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 33.894423: rtos_queue_send_from_isr_failed: tstamp:1378871541 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 33.894425: rtos_queue_send_from_isr_failed: tstamp:1378871701 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 33.894426: rtos_queue_send_from_isr_failed: tstamp:1378871858 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 33.894427: rtos_queue_send_from_isr_failed: tstamp:1378872015 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 34.062422: rtos_queue_peek_from_isr_failed: tstamp:1383742400 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 34.174413: rtos_queue_peek_from_isr_failed: tstamp:1388742400 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 34.342366: rtos_queue_peek_from_isr_failed: tstamp:1393742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 34.510394: rtos_queue_peek_from_isr_failed: tstamp:1398742405 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 34.678388: rtos_queue_peek_from_isr_failed: tstamp:1403742400 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 34.846390: rtos_queue_peek_from_isr_failed: tstamp:1408742400 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 35.014367: rtos_queue_peek_from_isr_failed: tstamp:1413742400 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 35.182399: rtos_queue_peek_from_isr_failed: tstamp:1418742403 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 35.294377: rtos_queue_peek_from_isr_failed: tstamp:1423742403 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 35.462360: rtos_queue_peek_from_isr_failed: tstamp:1428742399 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 35.630357: rtos_queue_peek_from_isr_failed: tstamp:1433742400 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 35.799043: rtos_queue_peek_from_isr_failed: tstamp:1438742402 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 35.966366: rtos_queue_peek_from_isr_failed: tstamp:1443742400 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 36.134415: rtos_queue_peek_from_isr_failed: tstamp:1448742402 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 36.302404: rtos_queue_peek_from_isr_failed: tstamp:1453742399 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 36.414459: rtos_queue_peek_from_isr_failed: tstamp:1458742413 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 36.470759: rtos_queue_send_from_isr_failed: tstamp:1459915048 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 36.470765: rtos_queue_send_from_isr_failed: tstamp:1459915210 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 36.470767: rtos_queue_send_from_isr_failed: tstamp:1459915371 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 36.470768: rtos_queue_send_from_isr_failed: tstamp:1459915532 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 36.470769: rtos_queue_send_from_isr_failed: tstamp:1459915689 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 36.586100: rtos_queue_peek_from_isr_failed: tstamp:1463742400 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 36.642338: rtos_queue_send_from_isr_failed: tstamp:1464294580 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 36.642343: rtos_queue_send_from_isr_failed: tstamp:1464294742 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 36.642345: rtos_queue_send_from_isr_failed: tstamp:1464294904 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 36.642346: rtos_queue_send_from_isr_failed: tstamp:1464295061 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 36.642347: rtos_queue_send_from_isr_failed: tstamp:1464295218 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 36.642349: rtos_queue_send_from_isr_failed: tstamp:1465338005 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 36.642350: rtos_queue_send_from_isr_failed: tstamp:1465338165 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 36.642351: rtos_queue_send_from_isr_failed: tstamp:1465338325 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 36.642352: rtos_queue_send_from_isr_failed: tstamp:1465338482 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 36.642353: rtos_queue_send_from_isr_failed: tstamp:1465338641 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 36.642354: rtos_queue_send_from_isr_failed: tstamp:1465498929 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 36.642355: rtos_queue_send_from_isr_failed: tstamp:1465499087 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 36.642356: rtos_queue_send_from_isr_failed: tstamp:1465499248 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 36.642357: rtos_queue_send_from_isr_failed: tstamp:1465499405 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 36.642359: rtos_queue_send_from_isr_failed: tstamp:1465499561 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 36.642362: rtcpu_nvcsi_intr: tstamp:1465505424 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:4-3595 [000] .... 36.642363: rtcpu_nvcsi_intr: tstamp:1465505424 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:4-3595 [000] .... 36.642364: rtcpu_nvcsi_intr: tstamp:1465506490 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000000
kworker/0:4-3595 [000] .... 36.699494: rtos_queue_send_from_isr_failed: tstamp:1465890297 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 36.699499: rtos_queue_send_from_isr_failed: tstamp:1465890462 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 36.699500: rtos_queue_send_from_isr_failed: tstamp:1465890626 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 36.699501: rtos_queue_send_from_isr_failed: tstamp:1465890786 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 36.699502: rtos_queue_send_from_isr_failed: tstamp:1465890944 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 36.699505: rtcpu_string: tstamp:1465891403 id:0x04010000 str:"Configuring VI GoS.
kworker/0:4-3595 [000] .... 36.699540: rtcpu_string: tstamp:1465891595 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:4-3595 [000] .... 36.699554: rtcpu_string: tstamp:1465891866 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:4-3595 [000] .... 36.699566: rtcpu_string: tstamp:1465892150 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:4-3595 [000] .... 36.699579: rtcpu_string: tstamp:1465892391 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:4-3595 [000] .... 36.699592: rtcpu_string: tstamp:1465892634 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:4-3595 [000] .... 36.699603: rtcpu_string: tstamp:1465892876 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:4-3595 [000] .... 36.699615: rtos_queue_send_from_isr_failed: tstamp:1465897674 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 36.699617: rtos_queue_send_from_isr_failed: tstamp:1465897833 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 36.699618: rtos_queue_send_from_isr_failed: tstamp:1465897997 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 36.699619: rtos_queue_send_from_isr_failed: tstamp:1465898152 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 36.699620: rtos_queue_send_from_isr_failed: tstamp:1465898309 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 36.699623: rtcpu_vinotify_event: tstamp:1466134728 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:18446744073373711136 data:0x10000000
kworker/0:4-3595 [000] .... 36.699625: rtcpu_vinotify_event: tstamp:1466134909 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:18446744073373718112 data:0x31000001
kworker/0:4-3595 [000] .... 36.699626: rtcpu_vinotify_event: tstamp:1466135060 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:18446744073373719904 data:0x07020001
kworker/0:4-3595 [000] .... 36.699627: rtcpu_vinotify_event: tstamp:1466135231 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:18446744073373753984 data:0x10000000
kworker/0:4-3595 [000] .... 36.699628: rtcpu_vinotify_event: tstamp:1466135377 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:18446744073373761056 data:0x31000002
kworker/0:4-3595 [000] .... 36.758407: rtos_queue_peek_from_isr_failed: tstamp:1468742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 36.926437: rtos_queue_peek_from_isr_failed: tstamp:1473742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 37.094391: rtos_queue_peek_from_isr_failed: tstamp:1478742400 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 37.206413: rtos_queue_send_from_isr_failed: tstamp:1483091034 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 37.206419: rtos_queue_send_from_isr_failed: tstamp:1483091210 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 37.206420: rtos_queue_send_from_isr_failed: tstamp:1483091373 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 37.206421: rtos_queue_send_from_isr_failed: tstamp:1483091548 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 37.206422: rtos_queue_send_from_isr_failed: tstamp:1483091705 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 37.262367: rtos_queue_peek_from_isr_failed: tstamp:1483742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 37.374368: rtos_queue_peek_from_isr_failed: tstamp:1488742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 37.542361: rtos_queue_peek_from_isr_failed: tstamp:1493742399 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 37.710361: rtos_queue_peek_from_isr_failed: tstamp:1498742403 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 37.878349: rtos_queue_peek_from_isr_failed: tstamp:1503742403 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 37.990352: rtos_queue_send_from_isr_failed: tstamp:1507112202 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 37.990357: rtos_queue_send_from_isr_failed: tstamp:1507112377 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 37.990359: rtos_queue_send_from_isr_failed: tstamp:1507112539 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 37.990360: rtos_queue_send_from_isr_failed: tstamp:1507112697 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 37.990361: rtos_queue_send_from_isr_failed: tstamp:1507112858 queue:0x0bcbc160
kworker/0:1-808 [000] .... 38.046339: rtos_queue_peek_from_isr_failed: tstamp:1508742404 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 38.214345: rtos_queue_peek_from_isr_failed: tstamp:1513742404 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 38.382341: rtos_queue_peek_from_isr_failed: tstamp:1518742404 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 38.494375: rtos_queue_peek_from_isr_failed: tstamp:1523742404 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 38.662359: rtos_queue_peek_from_isr_failed: tstamp:1528742404 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 38.830412: rtos_queue_peek_from_isr_failed: tstamp:1533742404 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 38.998380: rtos_queue_peek_from_isr_failed: tstamp:1538742400 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 39.166378: rtos_queue_peek_from_isr_failed: tstamp:1543742400 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 39.278682: rtos_queue_send_from_isr_failed: tstamp:1547914073 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 39.278687: rtos_queue_send_from_isr_failed: tstamp:1547914235 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 39.278688: rtos_queue_send_from_isr_failed: tstamp:1547914397 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 39.278690: rtos_queue_send_from_isr_failed: tstamp:1547914555 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 39.278691: rtos_queue_send_from_isr_failed: tstamp:1547914712 queue:0x0bcbc160
kworker/0:1-808 [000] .... 39.334795: rtos_queue_send_from_isr_failed: tstamp:1548447291 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 39.334801: rtos_queue_send_from_isr_failed: tstamp:1548447452 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 39.334802: rtos_queue_send_from_isr_failed: tstamp:1548447613 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 39.334804: rtos_queue_send_from_isr_failed: tstamp:1548447771 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 39.334805: rtos_queue_send_from_isr_failed: tstamp:1548447928 queue:0x0bcbc160
kworker/0:1-808 [000] .... 39.334807: rtos_queue_peek_from_isr_failed: tstamp:1548742400 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 39.334808: rtos_queue_send_from_isr_failed: tstamp:1549484160 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 39.334810: rtos_queue_send_from_isr_failed: tstamp:1549484341 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 39.334811: rtos_queue_send_from_isr_failed: tstamp:1549484502 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 39.334812: rtos_queue_send_from_isr_failed: tstamp:1549484659 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 39.334813: rtos_queue_send_from_isr_failed: tstamp:1549484816 queue:0x0bcbc160
kworker/0:1-808 [000] .... 39.334814: rtos_queue_send_from_isr_failed: tstamp:1549639061 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 39.334815: rtos_queue_send_from_isr_failed: tstamp:1549639240 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 39.334816: rtos_queue_send_from_isr_failed: tstamp:1549639401 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 39.334817: rtos_queue_send_from_isr_failed: tstamp:1549639558 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 39.334818: rtos_queue_send_from_isr_failed: tstamp:1549639715 queue:0x0bcbc160
kworker/0:1-808 [000] .... 39.334821: rtcpu_nvcsi_intr: tstamp:1549645419 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:1-808 [000] .... 39.334823: rtcpu_nvcsi_intr: tstamp:1549645419 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:1-808 [000] .... 39.334824: rtcpu_nvcsi_intr: tstamp:1549646911 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000000
kworker/0:1-808 [000] .... 39.390416: rtos_queue_send_from_isr_failed: tstamp:1550029891 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 39.390421: rtos_queue_send_from_isr_failed: tstamp:1550030055 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 39.390423: rtos_queue_send_from_isr_failed: tstamp:1550030218 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 39.390424: rtos_queue_send_from_isr_failed: tstamp:1550030376 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 39.390425: rtos_queue_send_from_isr_failed: tstamp:1550030534 queue:0x0bcbc160
kworker/0:1-808 [000] .... 39.390428: rtcpu_string: tstamp:1550030996 id:0x04010000 str:"Configuring VI GoS.
kworker/0:1-808 [000] .... 39.390472: rtcpu_string: tstamp:1550031188 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:1-808 [000] .... 39.390487: rtcpu_string: tstamp:1550031455 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:1-808 [000] .... 39.390501: rtcpu_string: tstamp:1550031739 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:1-808 [000] .... 39.390515: rtcpu_string: tstamp:1550031980 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:1-808 [000] .... 39.390530: rtcpu_string: tstamp:1550032224 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:1-808 [000] .... 39.390565: rtcpu_string: tstamp:1550032466 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:1-808 [000] .... 39.502362: rtos_queue_peek_from_isr_failed: tstamp:1553742404 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 39.614366: rtos_queue_peek_from_isr_failed: tstamp:1558742404 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 39.670410: rtos_queue_send_from_isr_failed: tstamp:1559082531 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 39.670416: rtos_queue_send_from_isr_failed: tstamp:1559082701 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 39.670418: rtos_queue_send_from_isr_failed: tstamp:1559082864 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 39.670419: rtos_queue_send_from_isr_failed: tstamp:1559083021 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 39.670420: rtos_queue_send_from_isr_failed: tstamp:1559083178 queue:0x0bcbc160
kworker/0:1-808 [000] .... 39.670423: rtcpu_vinotify_event: tstamp:1559136207 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2646073920 data:0x10000000
kworker/0:1-808 [000] .... 39.670424: rtcpu_vinotify_event: tstamp:1559136382 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2646080928 data:0x31000001
kworker/0:1-808 [000] .... 39.670425: rtcpu_vinotify_event: tstamp:1559136560 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2646082720 data:0x07020001
kworker/0:1-808 [000] .... 39.786373: rtos_queue_peek_from_isr_failed: tstamp:1563742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 39.954412: rtos_queue_peek_from_isr_failed: tstamp:1568742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 40.122420: rtos_queue_peek_from_isr_failed: tstamp:1573742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 40.290427: rtos_queue_peek_from_isr_failed: tstamp:1578742407 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 40.402429: rtos_queue_send_from_isr_failed: tstamp:1583112469 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 40.402434: rtos_queue_send_from_isr_failed: tstamp:1583112644 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 40.402436: rtos_queue_send_from_isr_failed: tstamp:1583112806 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 40.402437: rtos_queue_send_from_isr_failed: tstamp:1583112963 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 40.402438: rtos_queue_send_from_isr_failed: tstamp:1583113120 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 40.402441: rtcpu_vinotify_event: tstamp:1583323510 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3415032992 data:0x10000000
kworker/0:4-3595 [000] .... 40.402443: rtcpu_vinotify_event: tstamp:1583323690 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3415040064 data:0x31000002
kworker/0:4-3595 [000] .... 40.458435: rtos_queue_peek_from_isr_failed: tstamp:1583742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 40.626364: rtos_queue_peek_from_isr_failed: tstamp:1588742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 40.738343: rtos_queue_peek_from_isr_failed: tstamp:1593742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 40.906354: rtos_queue_peek_from_isr_failed: tstamp:1598742403 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 41.074422: rtos_queue_peek_from_isr_failed: tstamp:1603742403 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 41.242399: rtos_queue_peek_from_isr_failed: tstamp:1608742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 41.354604: rtos_queue_send_from_isr_failed: tstamp:1611759514 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 41.354609: rtos_queue_send_from_isr_failed: tstamp:1611759679 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 41.354610: rtos_queue_send_from_isr_failed: tstamp:1611759842 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 41.354612: rtos_queue_send_from_isr_failed: tstamp:1611760000 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 41.354613: rtos_queue_send_from_isr_failed: tstamp:1611760157 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 41.410420: rtos_queue_peek_from_isr_failed: tstamp:1613742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 41.578401: rtos_queue_peek_from_isr_failed: tstamp:1618742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 41.694372: rtos_queue_peek_from_isr_failed: tstamp:1623742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 41.862403: rtos_queue_peek_from_isr_failed: tstamp:1628742413 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 42.030379: rtos_queue_peek_from_isr_failed: tstamp:1633742412 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 42.142361: rtos_queue_send_from_isr_failed: tstamp:1636878716 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 42.142367: rtos_queue_send_from_isr_failed: tstamp:1636878893 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 42.142369: rtos_queue_send_from_isr_failed: tstamp:1636879054 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 42.142370: rtos_queue_send_from_isr_failed: tstamp:1636879213 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 42.142371: rtos_queue_send_from_isr_failed: tstamp:1636879370 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 42.198404: rtos_queue_peek_from_isr_failed: tstamp:1638742403 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 42.366450: rtos_queue_peek_from_isr_failed: tstamp:1643742413 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 42.366457: rtos_queue_send_from_isr_failed: tstamp:1643911620 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 42.366459: rtos_queue_send_from_isr_failed: tstamp:1643911782 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 42.366460: rtos_queue_send_from_isr_failed: tstamp:1643911941 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 42.366461: rtos_queue_send_from_isr_failed: tstamp:1643912098 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 42.366462: rtos_queue_send_from_isr_failed: tstamp:1643912255 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 42.366463: rtos_queue_send_from_isr_failed: tstamp:1644446871 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 42.366464: rtos_queue_send_from_isr_failed: tstamp:1644447033 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 42.366466: rtos_queue_send_from_isr_failed: tstamp:1644447197 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 42.366467: rtos_queue_send_from_isr_failed: tstamp:1644447355 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 42.366468: rtos_queue_send_from_isr_failed: tstamp:1644447510 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 42.422382: rtos_queue_send_from_isr_failed: tstamp:1645482316 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 42.422388: rtos_queue_send_from_isr_failed: tstamp:1645482488 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 42.422389: rtos_queue_send_from_isr_failed: tstamp:1645482648 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 42.422390: rtos_queue_send_from_isr_failed: tstamp:1645482805 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 42.422392: rtos_queue_send_from_isr_failed: tstamp:1645482962 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 42.422393: rtos_queue_send_from_isr_failed: tstamp:1645646726 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 42.422394: rtos_queue_send_from_isr_failed: tstamp:1645646887 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 42.422395: rtos_queue_send_from_isr_failed: tstamp:1645647046 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 42.422396: rtos_queue_send_from_isr_failed: tstamp:1645647203 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 42.422397: rtos_queue_send_from_isr_failed: tstamp:1645647359 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 42.422400: rtcpu_nvcsi_intr: tstamp:1645689515 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000000
kworker/0:4-3595 [000] .... 42.422401: rtcpu_nvcsi_intr: tstamp:1645705450 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:4-3595 [000] .... 42.422403: rtcpu_nvcsi_intr: tstamp:1645705450 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:4-3595 [000] .... 42.422404: rtos_queue_send_from_isr_failed: tstamp:1646039933 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 42.422405: rtos_queue_send_from_isr_failed: tstamp:1646040099 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 42.422406: rtos_queue_send_from_isr_failed: tstamp:1646040262 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 42.422407: rtos_queue_send_from_isr_failed: tstamp:1646040419 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 42.422408: rtos_queue_send_from_isr_failed: tstamp:1646040577 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 42.422411: rtcpu_string: tstamp:1646041050 id:0x04010000 str:"Configuring VI GoS.
kworker/0:4-3595 [000] .... 42.422453: rtcpu_string: tstamp:1646041244 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:4-3595 [000] .... 42.422469: rtcpu_string: tstamp:1646041511 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:4-3595 [000] .... 42.422484: rtcpu_string: tstamp:1646041792 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:4-3595 [000] .... 42.422499: rtcpu_string: tstamp:1646042033 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:4-3595 [000] .... 42.422514: rtcpu_string: tstamp:1646042276 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:4-3595 [000] .... 42.422529: rtcpu_string: tstamp:1646042518 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:4-3595 [000] .... 42.534428: rtos_queue_peek_from_isr_failed: tstamp:1648742400 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 42.702391: rtos_queue_peek_from_isr_failed: tstamp:1653742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 42.814399: rtos_queue_peek_from_isr_failed: tstamp:1658742413 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 42.982373: rtos_queue_peek_from_isr_failed: tstamp:1663742409 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 43.038426: rtos_queue_send_from_isr_failed: tstamp:1664340624 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 43.038431: rtos_queue_send_from_isr_failed: tstamp:1664340790 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 43.038432: rtos_queue_send_from_isr_failed: tstamp:1664340953 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 43.038434: rtos_queue_send_from_isr_failed: tstamp:1664341110 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 43.038435: rtos_queue_send_from_isr_failed: tstamp:1664341266 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 43.038438: rtcpu_vinotify_event: tstamp:1664343690 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1719370304 data:0x10000000
kworker/0:4-3595 [000] .... 43.038439: rtcpu_vinotify_event: tstamp:1664674181 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1719393376 data:0x31000001
kworker/0:4-3595 [000] .... 43.038440: rtcpu_vinotify_event: tstamp:1664674335 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:1719395168 data:0x07020001
kworker/0:4-3595 [000] .... 43.150415: rtos_queue_peek_from_isr_failed: tstamp:1668742417 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 43.318374: rtos_queue_peek_from_isr_failed: tstamp:1673742403 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 43.486397: rtos_queue_peek_from_isr_failed: tstamp:1678742413 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 43.654385: rtos_queue_peek_from_isr_failed: tstamp:1683742412 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 43.766364: rtos_queue_send_from_isr_failed: tstamp:1688321910 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 43.766369: rtos_queue_send_from_isr_failed: tstamp:1688322085 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 43.766371: rtos_queue_send_from_isr_failed: tstamp:1688322247 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 43.766372: rtos_queue_send_from_isr_failed: tstamp:1688322404 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 43.766373: rtos_queue_send_from_isr_failed: tstamp:1688322562 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 43.822393: rtcpu_vinotify_event: tstamp:1688520708 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2486769696 data:0x10000000
kworker/0:4-3595 [000] .... 43.822398: rtcpu_vinotify_event: tstamp:1688520869 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2486776768 data:0x31000002
kworker/0:4-3595 [000] .... 43.822401: rtos_queue_peek_from_isr_failed: tstamp:1688742404 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 43.934360: rtos_queue_peek_from_isr_failed: tstamp:1693742413 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 44.102424: rtos_queue_peek_from_isr_failed: tstamp:1698742408 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 44.270404: rtos_queue_peek_from_isr_failed: tstamp:1703742413 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 44.438450: rtos_queue_peek_from_isr_failed: tstamp:1708742413 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 44.494394: rtos_queue_send_from_isr_failed: tstamp:1710651595 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 44.494399: rtos_queue_send_from_isr_failed: tstamp:1710651758 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 44.494401: rtos_queue_send_from_isr_failed: tstamp:1710651919 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 44.494402: rtos_queue_send_from_isr_failed: tstamp:1710652077 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 44.494403: rtos_queue_send_from_isr_failed: tstamp:1710652234 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 44.606596: rtos_queue_peek_from_isr_failed: tstamp:1713742412 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 44.774378: rtos_queue_peek_from_isr_failed: tstamp:1718742413 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 44.942382: rtos_queue_peek_from_isr_failed: tstamp:1723742403 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 45.054378: rtos_queue_peek_from_isr_failed: tstamp:1728742413 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 45.222376: rtos_queue_peek_from_isr_failed: tstamp:1733742413 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 45.390394: rtos_queue_peek_from_isr_failed: tstamp:1738742413 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 45.390401: rtos_queue_send_from_isr_failed: tstamp:1738813977 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 45.390443: rtos_queue_send_from_isr_failed: tstamp:1738814139 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 45.390445: rtos_queue_send_from_isr_failed: tstamp:1738814300 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 45.390446: rtos_queue_send_from_isr_failed: tstamp:1738814457 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 45.390447: rtos_queue_send_from_isr_failed: tstamp:1738814614 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 45.503606: rtos_queue_send_from_isr_failed: tstamp:1742536646 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 45.503611: rtos_queue_send_from_isr_failed: tstamp:1742536809 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 45.503613: rtos_queue_send_from_isr_failed: tstamp:1742536970 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 45.503614: rtos_queue_send_from_isr_failed: tstamp:1742537127 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 45.503615: rtos_queue_send_from_isr_failed: tstamp:1742537285 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 45.559683: rtos_queue_send_from_isr_failed: tstamp:1742970084 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 45.559688: rtos_queue_send_from_isr_failed: tstamp:1742970249 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 45.559689: rtos_queue_send_from_isr_failed: tstamp:1742970410 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 45.559690: rtos_queue_send_from_isr_failed: tstamp:1742970569 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 45.559692: rtos_queue_send_from_isr_failed: tstamp:1742970726 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 45.559694: rtos_queue_peek_from_isr_failed: tstamp:1743742403 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 45.559695: rtos_queue_send_from_isr_failed: tstamp:1744002756 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 45.559696: rtos_queue_send_from_isr_failed: tstamp:1744002920 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 45.559697: rtos_queue_send_from_isr_failed: tstamp:1744003080 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 45.559698: rtos_queue_send_from_isr_failed: tstamp:1744003238 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 45.559699: rtos_queue_send_from_isr_failed: tstamp:1744003394 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 45.559701: rtos_queue_send_from_isr_failed: tstamp:1744159987 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 45.559702: rtos_queue_send_from_isr_failed: tstamp:1744160173 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 45.559703: rtos_queue_send_from_isr_failed: tstamp:1744160333 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 45.559704: rtos_queue_send_from_isr_failed: tstamp:1744160494 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 45.559705: rtos_queue_send_from_isr_failed: tstamp:1744160651 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 45.559708: rtcpu_nvcsi_intr: tstamp:1744272013 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000000
kworker/0:4-3595 [000] .... 45.559709: rtcpu_nvcsi_intr: tstamp:1744287954 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:4-3595 [000] .... 45.559710: rtcpu_nvcsi_intr: tstamp:1744287954 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:4-3595 [000] .... 45.614590: rtos_queue_send_from_isr_failed: tstamp:1744557356 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 45.614600: rtos_queue_send_from_isr_failed: tstamp:1744557521 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 45.614602: rtos_queue_send_from_isr_failed: tstamp:1744557684 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 45.614605: rtos_queue_send_from_isr_failed: tstamp:1744557841 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 45.614607: rtos_queue_send_from_isr_failed: tstamp:1744557999 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 45.614611: rtcpu_string: tstamp:1744558477 id:0x04010000 str:"Configuring VI GoS.
kworker/0:4-3595 [000] .... 45.614681: rtcpu_string: tstamp:1744558671 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:4-3595 [000] .... 45.614698: rtcpu_string: tstamp:1744558937 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:4-3595 [000] .... 45.614713: rtcpu_string: tstamp:1744559222 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:4-3595 [000] .... 45.614726: rtcpu_string: tstamp:1744559463 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:4-3595 [000] .... 45.614741: rtcpu_string: tstamp:1744559706 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:4-3595 [000] .... 45.614755: rtcpu_string: tstamp:1744559948 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:4-3595 [000] .... 45.614769: rtos_queue_send_from_isr_failed: tstamp:1745807936 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 45.614771: rtos_queue_send_from_isr_failed: tstamp:1745808099 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 45.614772: rtos_queue_send_from_isr_failed: tstamp:1745808263 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 45.614773: rtos_queue_send_from_isr_failed: tstamp:1745808421 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 45.614774: rtos_queue_send_from_isr_failed: tstamp:1745808580 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 45.614775: rtos_queue_send_from_isr_failed: tstamp:1745996123 queue:0x0bcb41f8
kworker/0:4-3595 [000] .... 45.614776: rtos_queue_send_from_isr_failed: tstamp:1745996421 queue:0x0bcb8a60
kworker/0:4-3595 [000] .... 45.614777: rtos_queue_send_from_isr_failed: tstamp:1745996721 queue:0x0bcba5e0
kworker/0:4-3595 [000] .... 45.614778: rtos_queue_send_from_isr_failed: tstamp:1745997019 queue:0x0bcbb3a0
kworker/0:4-3595 [000] .... 45.614780: rtos_queue_send_from_isr_failed: tstamp:1745997316 queue:0x0bcbc160
kworker/0:4-3595 [000] .... 45.726396: rtos_queue_peek_from_isr_failed: tstamp:1748742482 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 45.894367: rtos_queue_peek_from_isr_failed: tstamp:1753742482 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 46.062417: rtos_queue_peek_from_isr_failed: tstamp:1758742481 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 46.174398: rtos_queue_peek_from_isr_failed: tstamp:1763742482 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 46.342359: rtos_queue_peek_from_isr_failed: tstamp:1768742474 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 46.510364: rtos_queue_peek_from_isr_failed: tstamp:1773742474 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 46.678352: rtos_queue_peek_from_isr_failed: tstamp:1778742474 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 46.846433: rtos_queue_peek_from_isr_failed: tstamp:1783742474 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 47.014360: rtos_queue_peek_from_isr_failed: tstamp:1788742473 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 47.182370: rtos_queue_peek_from_isr_failed: tstamp:1793742473 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 47.294361: rtos_queue_peek_from_isr_failed: tstamp:1798742483 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 47.462341: rtos_queue_peek_from_isr_failed: tstamp:1803742474 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 47.630352: rtos_queue_peek_from_isr_failed: tstamp:1808742474 queue:0x0bcbcf78
kworker/0:4-3595 [000] .... 47.798391: rtos_queue_peek_from_isr_failed: tstamp:1813742474 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 47.966396: rtos_queue_peek_from_isr_failed: tstamp:1818742472 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 48.134394: rtos_queue_peek_from_isr_failed: tstamp:1823742474 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 48.302366: rtos_queue_peek_from_isr_failed: tstamp:1828742472 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 48.414376: rtos_queue_peek_from_isr_failed: tstamp:1833742472 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 48.582396: rtos_queue_peek_from_isr_failed: tstamp:1838742474 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 48.750406: rtos_queue_peek_from_isr_failed: tstamp:1843742472 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 48.918370: rtos_queue_peek_from_isr_failed: tstamp:1848742470 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 49.086382: rtos_queue_peek_from_isr_failed: tstamp:1853742470 queue:0x0bcbcf78
Try boost the nvcsi/vi clocks to try.
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
ray_lo
June 23, 2020, 1:31am
4
Hi ShaneCCC:
I tried but nothing change.
root@localhost:~# echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
root@localhost:~# echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
doot@localhost:~# echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
nel/debug/bpmp/debug/clk/vi/ratel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kern
998400000
kernel/debug/bpmp/debug/clk/isp/ratebug/bpmp/debug/clk/isp/max_rate | tee /sys/k
cat /sys/ker1190400000
/kernel/debug/bpmp/debug/clk/nvcsi/rateat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/
400000000
Trace:
kworker/0:0-4 [000] … 146.453831: rtos_queue_peek_from_isr_failed: tstamp:4895843055 queue:0x0bcbcf78
kworker/0:0-4 [000] … 146.621822: rtos_queue_peek_from_isr_failed: tstamp:4900843063 queue:0x0bcbcf78
kworker/0:0-4 [000] … 146.733823: rtos_queue_peek_from_isr_failed: tstamp:4905843059 queue:0x0bcbcf78
kworker/0:0-4 [000] … 146.901851: rtos_queue_peek_from_isr_failed: tstamp:4910843055 queue:0x0bcbcf78
kworker/0:0-4 [000] … 147.069856: rtos_queue_peek_from_isr_failed: tstamp:4915843059 queue:0x0bcbcf78
kworker/0:0-4 [000] … 147.237861: rtos_queue_peek_from_isr_failed: tstamp:4920843059 queue:0x0bcbcf78
kworker/0:0-4 [000] … 147.405823: rtos_queue_peek_from_isr_failed: tstamp:4925843055 queue:0x0bcbcf78
kworker/0:0-4 [000] … 147.573919: rtos_queue_peek_from_isr_failed: tstamp:4930843066 queue:0x0bcbcf78
kworker/0:0-4 [000] … 147.741819: rtos_queue_peek_from_isr_failed: tstamp:4935843059 queue:0x0bcbcf78
kworker/0:0-4 [000] … 147.853841: rtos_queue_peek_from_isr_failed: tstamp:4940843059 queue:0x0bcbcf78
kworker/0:0-4 [000] … 148.021818: rtos_queue_peek_from_isr_failed: tstamp:4945843059 queue:0x0bcbcf78
kworker/0:0-4 [000] … 148.189817: rtos_queue_peek_from_isr_failed: tstamp:4950843059 queue:0x0bcbcf78
kworker/0:0-4 [000] … 148.357821: rtos_queue_peek_from_isr_failed: tstamp:4955843059 queue:0x0bcbcf78
kworker/0:0-4 [000] … 148.525821: rtos_queue_peek_from_isr_failed: tstamp:4960843059 queue:0x0bcbcf78
kworker/0:0-4 [000] … 148.693818: rtos_queue_peek_from_isr_failed: tstamp:4965843059 queue:0x0bcbcf78
kworker/0:0-4 [000] … 148.861837: rtos_queue_peek_from_isr_failed: tstamp:4970843060 queue:0x0bcbcf78
kworker/0:0-4 [000] … 148.973818: rtos_queue_peek_from_isr_failed: tstamp:4975843059 queue:0x0bcbcf78
kworker/0:0-4 [000] … 149.141816: rtos_queue_peek_from_isr_failed: tstamp:4980843058 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 149.309836: rtos_queue_peek_from_isr_failed: tstamp:4985843055 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 149.477821: rtos_queue_peek_from_isr_failed: tstamp:4990843059 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 149.645831: rtos_queue_peek_from_isr_failed: tstamp:4995843060 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 149.813903: rtos_queue_peek_from_isr_failed: tstamp:5000843060 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 149.981819: rtos_queue_peek_from_isr_failed: tstamp:5005843059 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 150.093817: rtos_queue_peek_from_isr_failed: tstamp:5010843068 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 150.261819: rtos_queue_peek_from_isr_failed: tstamp:5015843059 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 150.429826: rtos_queue_peek_from_isr_failed: tstamp:5020843059 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 150.597868: rtos_queue_peek_from_isr_failed: tstamp:5025843058 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 150.765868: rtos_queue_peek_from_isr_failed: tstamp:5030843055 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 150.933842: rtos_queue_peek_from_isr_failed: tstamp:5035843055 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 151.101822: rtos_queue_peek_from_isr_failed: tstamp:5040843055 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 151.213817: rtos_queue_peek_from_isr_failed: tstamp:5045843063 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 151.381819: rtos_queue_peek_from_isr_failed: tstamp:5050843059 queue:0x0bcbcf78
kworker/0:4-5997 [000] … 151.437833: rtos_queue_peek_from_isr_failed: tstamp:5051498859 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 173.957861: rtos_queue_peek_from_isr_failed: tstamp:5755230879 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 173.957868: rtcpu_start: tstamp:5755233349
kworker/0:3-1754 [000] … 173.957871: rtos_queue_send_from_isr_failed: tstamp:5755371765 queue:0x0bcb41f8
kworker/0:3-1754 [000] … 173.957872: rtos_queue_send_from_isr_failed: tstamp:5755372063 queue:0x0bcb8a60
kworker/0:3-1754 [000] … 173.957873: rtos_queue_send_from_isr_failed: tstamp:5755372361 queue:0x0bcba5e0
kworker/0:3-1754 [000] … 173.957874: rtos_queue_send_from_isr_failed: tstamp:5755372657 queue:0x0bcbb3a0
kworker/0:3-1754 [000] … 173.957875: rtos_queue_send_from_isr_failed: tstamp:5755372951 queue:0x0bcbc160
kworker/0:3-1754 [000] … 173.957878: rtcpu_string: tstamp:5755373755 id:0x04010000 str:"Configuring VI GoS.
kworker/0:3-1754 [000] … 173.957898: rtcpu_string: tstamp:5755374121 id:0x04010000 str:"VM GOS[#0 ] addr=0xc2100000
kworker/0:3-1754 [000] … 173.957909: rtcpu_string: tstamp:5755374541 id:0x04010000 str:"VM GOS[#1 ] addr=0xc2101000
kworker/0:3-1754 [000] … 173.957917: rtcpu_string: tstamp:5755375040 id:0x04010000 str:"VM GOS[#2 ] addr=0xc2102000
kworker/0:3-1754 [000] … 173.957923: rtcpu_string: tstamp:5755375501 id:0x04010000 str:"VM GOS[#3 ] addr=0xc2103000
kworker/0:3-1754 [000] … 173.957927: rtcpu_string: tstamp:5755375905 id:0x04010000 str:"VM GOS[#4 ] addr=0xc2104000
kworker/0:3-1754 [000] … 173.957931: rtcpu_string: tstamp:5755376310 id:0x04010000 str:"VM GOS[#5 ] addr=0xc2105000
kworker/0:3-1754 [000] … 173.957935: rtcpu_string: tstamp:5755387438 id:0x04010000 str:“vi5_hwinit: firmware CL2018101701 protocol versi”
kworker/0:3-1754 [000] … 173.957938: rtcpu_string: tstamp:5755387708 id:0x04010000 str:"on 2.2
kworker/0:3-1754 [000] … 173.957942: rtos_queue_send_from_isr_failed: tstamp:5755712028 queue:0x0bcb41f8
kworker/0:3-1754 [000] … 173.957943: rtos_queue_send_from_isr_failed: tstamp:5755712210 queue:0x0bcb8a60
kworker/0:3-1754 [000] … 173.957945: rtos_queue_send_from_isr_failed: tstamp:5755712374 queue:0x0bcba5e0
kworker/0:3-1754 [000] … 173.957946: rtos_queue_send_from_isr_failed: tstamp:5755712531 queue:0x0bcbb3a0
kworker/0:3-1754 [000] … 173.957946: rtos_queue_send_from_isr_failed: tstamp:5755712687 queue:0x0bcbc160
kworker/0:3-1754 [000] … 174.017840: rtos_queue_send_from_isr_failed: tstamp:5758547903 queue:0x0bcb41f8
kworker/0:3-1754 [000] … 174.017845: rtos_queue_send_from_isr_failed: tstamp:5758548084 queue:0x0bcb8a60
kworker/0:3-1754 [000] … 174.017846: rtos_queue_send_from_isr_failed: tstamp:5758548247 queue:0x0bcba5e0
kworker/0:3-1754 [000] … 174.017847: rtos_queue_send_from_isr_failed: tstamp:5758548404 queue:0x0bcbb3a0
kworker/0:3-1754 [000] … 174.017848: rtos_queue_send_from_isr_failed: tstamp:5758548560 queue:0x0bcbc160
kworker/0:3-1754 [000] … 174.017850: rtcpu_string: tstamp:5758549444 id:0x04010000 str:"VI GOS[#0 ] set to VM GOS[4] base 0xc2104000
kworker/0:3-1754 [000] … 174.017861: rtcpu_vinotify_event: tstamp:5758579790 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3884987584 data:0x10000000
kworker/0:3-1754 [000] … 174.017863: rtcpu_vinotify_event: tstamp:5758579943 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3884991456 data:0x31000001
kworker/0:3-1754 [000] … 174.017864: rtcpu_vinotify_event: tstamp:5758580118 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3884992448 data:0x07020001
kworker/0:3-1754 [000] … 174.078971: rtcpu_nvcsi_intr: tstamp:5759636369 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000100
kworker/0:3-1754 [000] … 174.078975: rtcpu_nvcsi_intr: tstamp:5759636369 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:3-1754 [000] … 174.078977: rtos_queue_peek_from_isr_failed: tstamp:5760231264 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 174.129854: rtos_queue_send_from_isr_failed: tstamp:5760696683 queue:0x0bcb41f8
kworker/0:3-1754 [000] … 174.129858: rtos_queue_send_from_isr_failed: tstamp:5760696848 queue:0x0bcb8a60
kworker/0:3-1754 [000] … 174.129859: rtos_queue_send_from_isr_failed: tstamp:5760697011 queue:0x0bcba5e0
kworker/0:3-1754 [000] … 174.129860: rtos_queue_send_from_isr_failed: tstamp:5760697168 queue:0x0bcbb3a0
kworker/0:3-1754 [000] … 174.129861: rtos_queue_send_from_isr_failed: tstamp:5760697325 queue:0x0bcbc160
kworker/0:3-1754 [000] … 174.129863: rtcpu_vinotify_event: tstamp:5760770812 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3953734592 data:0x10000000
kworker/0:3-1754 [000] … 174.129865: rtcpu_vinotify_event: tstamp:5760770990 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3953738464 data:0x31000002
kworker/0:3-1754 [000] … 174.129866: rtos_queue_send_from_isr_failed: tstamp:5761478871 queue:0x0bcb41f8
kworker/0:3-1754 [000] … 174.129867: rtos_queue_send_from_isr_failed: tstamp:5761479030 queue:0x0bcb8a60
kworker/0:3-1754 [000] … 174.129868: rtos_queue_send_from_isr_failed: tstamp:5761479191 queue:0x0bcba5e0
kworker/0:3-1754 [000] … 174.129869: rtos_queue_send_from_isr_failed: tstamp:5761479366 queue:0x0bcbb3a0
kworker/0:3-1754 [000] … 174.129870: rtos_queue_send_from_isr_failed: tstamp:5761479522 queue:0x0bcbc160
kworker/0:3-1754 [000] … 174.185837: rtos_queue_send_from_isr_failed: tstamp:5762258248 queue:0x0bcb41f8
kworker/0:3-1754 [000] … 174.185840: rtos_queue_send_from_isr_failed: tstamp:5762258431 queue:0x0bcb8a60
kworker/0:3-1754 [000] … 174.185841: rtos_queue_send_from_isr_failed: tstamp:5762258592 queue:0x0bcba5e0
kworker/0:3-1754 [000] … 174.185842: rtos_queue_send_from_isr_failed: tstamp:5762258750 queue:0x0bcbb3a0
kworker/0:3-1754 [000] … 174.185843: rtos_queue_send_from_isr_failed: tstamp:5762258907 queue:0x0bcbc160
kworker/0:3-1754 [000] … 174.241847: rtos_queue_peek_from_isr_failed: tstamp:5765231263 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 174.409853: rtos_queue_peek_from_isr_failed: tstamp:5770231267 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 174.577814: rtos_queue_peek_from_isr_failed: tstamp:5775231264 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 174.745815: rtos_queue_peek_from_isr_failed: tstamp:5780231263 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 174.913817: rtos_queue_peek_from_isr_failed: tstamp:5785231263 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 175.081817: rtos_queue_peek_from_isr_failed: tstamp:5790231266 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 175.193814: rtos_queue_peek_from_isr_failed: tstamp:5795231264 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 175.361816: rtos_queue_peek_from_isr_failed: tstamp:5800231266 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 175.529815: rtos_queue_peek_from_isr_failed: tstamp:5805231261 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 175.697816: rtos_queue_peek_from_isr_failed: tstamp:5810231261 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 175.865819: rtos_queue_peek_from_isr_failed: tstamp:5815231263 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 176.033813: rtos_queue_peek_from_isr_failed: tstamp:5820231268 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 176.201817: rtos_queue_peek_from_isr_failed: tstamp:5825231263 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 176.313847: rtos_queue_peek_from_isr_failed: tstamp:5830231264 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 176.481819: rtos_queue_peek_from_isr_failed: tstamp:5835231266 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 176.649819: rtos_queue_peek_from_isr_failed: tstamp:5840231263 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 176.761817: rtos_queue_send_from_isr_failed: tstamp:5843521679 queue:0x0bcb41f8
kworker/0:3-1754 [000] … 176.761821: rtos_queue_send_from_isr_failed: tstamp:5843521843 queue:0x0bcb8a60
kworker/0:3-1754 [000] … 176.761822: rtos_queue_send_from_isr_failed: tstamp:5843522002 queue:0x0bcba5e0
kworker/0:3-1754 [000] … 176.761823: rtos_queue_send_from_isr_failed: tstamp:5843522159 queue:0x0bcbb3a0
kworker/0:3-1754 [000] … 176.761824: rtos_queue_send_from_isr_failed: tstamp:5843522329 queue:0x0bcbc160
kworker/0:3-1754 [000] … 176.761825: rtos_queue_send_from_isr_failed: tstamp:5843566486 queue:0x0bcb41f8
kworker/0:3-1754 [000] … 176.761826: rtos_queue_send_from_isr_failed: tstamp:5843566647 queue:0x0bcb8a60
kworker/0:3-1754 [000] … 176.761827: rtos_queue_send_from_isr_failed: tstamp:5843566808 queue:0x0bcba5e0
kworker/0:3-1754 [000] … 176.761828: rtos_queue_send_from_isr_failed: tstamp:5843566965 queue:0x0bcbb3a0
kworker/0:3-1754 [000] … 176.761829: rtos_queue_send_from_isr_failed: tstamp:5843567141 queue:0x0bcbc160
kworker/0:3-1754 [000] … 176.761832: rtcpu_nvcsi_intr: tstamp:5843573855 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:3-1754 [000] … 176.761833: rtcpu_nvcsi_intr: tstamp:5843573855 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:3-1754 [000] … 176.761834: rtcpu_nvcsi_intr: tstamp:5843575087 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000000
kworker/0:3-1754 [000] … 176.761838: rtcpu_string: tstamp:5843575617 id:0x04010000 str:"Configuring VI GoS.
kworker/0:3-1754 [000] … 176.761886: rtcpu_string: tstamp:5843575816 id:0x04010000 str:"VM GOS[#0 ] addr=0xc2100000
kworker/0:3-1754 [000] … 176.761892: rtcpu_string: tstamp:5843576079 id:0x04010000 str:"VM GOS[#1 ] addr=0xc2101000
kworker/0:3-1754 [000] … 176.761897: rtcpu_string: tstamp:5843576360 id:0x04010000 str:"VM GOS[#2 ] addr=0xc2102000
kworker/0:3-1754 [000] … 176.761901: rtcpu_string: tstamp:5843576604 id:0x04010000 str:"VM GOS[#3 ] addr=0xc2103000
kworker/0:3-1754 [000] … 176.761905: rtcpu_string: tstamp:5843576847 id:0x04010000 str:"VM GOS[#4 ] addr=0xc2104000
kworker/0:3-1754 [000] … 176.761909: rtcpu_string: tstamp:5843577089 id:0x04010000 str:"VM GOS[#5 ] addr=0xc2105000
kworker/0:3-1754 [000] … 176.817822: rtos_queue_peek_from_isr_failed: tstamp:5845231270 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 176.989856: rtos_queue_peek_from_isr_failed: tstamp:5850231263 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 176.989863: rtos_queue_send_from_isr_failed: tstamp:5851342390 queue:0x0bcb41f8
kworker/0:3-1754 [000] … 176.989864: rtos_queue_send_from_isr_failed: tstamp:5851342553 queue:0x0bcb8a60
kworker/0:3-1754 [000] … 176.989866: rtos_queue_send_from_isr_failed: tstamp:5851342717 queue:0x0bcba5e0
kworker/0:3-1754 [000] … 176.989867: rtos_queue_send_from_isr_failed: tstamp:5851342875 queue:0x0bcbb3a0
kworker/0:3-1754 [000] … 176.989868: rtos_queue_send_from_isr_failed: tstamp:5851343032 queue:0x0bcbc160
kworker/0:3-1754 [000] … 177.045845: rtcpu_vinotify_event: tstamp:5851541905 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:6854398688 data:0x10000000
kworker/0:3-1754 [000] … 177.045851: rtcpu_vinotify_event: tstamp:5851542089 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:6854402528 data:0x31000001
kworker/0:3-1754 [000] … 177.045852: rtcpu_vinotify_event: tstamp:5851542238 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:6854403520 data:0x07020001
kworker/0:3-1754 [000] … 177.045856: rtos_queue_send_from_isr_failed: tstamp:5852276162 queue:0x0bcb41f8
kworker/0:3-1754 [000] … 177.045857: rtos_queue_send_from_isr_failed: tstamp:5852276323 queue:0x0bcb8a60
kworker/0:3-1754 [000] … 177.045858: rtos_queue_send_from_isr_failed: tstamp:5852276486 queue:0x0bcba5e0
kworker/0:3-1754 [000] … 177.045859: rtos_queue_send_from_isr_failed: tstamp:5852276644 queue:0x0bcbb3a0
kworker/0:3-1754 [000] … 177.045860: rtos_queue_send_from_isr_failed: tstamp:5852276801 queue:0x0bcbc160
kworker/0:3-1754 [000] … 177.045861: rtcpu_vinotify_event: tstamp:5852480940 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:6884280320 data:0x10000000
kworker/0:3-1754 [000] … 177.045862: rtcpu_vinotify_event: tstamp:5852481097 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:6884284224 data:0x31000002
kworker/0:3-1754 [000] … 177.157926: rtos_queue_peek_from_isr_failed: tstamp:5855231263 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 177.269911: rtos_queue_peek_from_isr_failed: tstamp:5860231267 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 177.437830: rtos_queue_peek_from_isr_failed: tstamp:5865231266 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 177.493853: rtos_queue_send_from_isr_failed: tstamp:5866169636 queue:0x0bcb41f8
kworker/0:3-1754 [000] … 177.493858: rtos_queue_send_from_isr_failed: tstamp:5866169799 queue:0x0bcb8a60
kworker/0:3-1754 [000] … 177.493860: rtos_queue_send_from_isr_failed: tstamp:5866169961 queue:0x0bcba5e0
kworker/0:3-1754 [000] … 177.493861: rtos_queue_send_from_isr_failed: tstamp:5866170118 queue:0x0bcbb3a0
kworker/0:3-1754 [000] … 177.493862: rtos_queue_send_from_isr_failed: tstamp:5866170276 queue:0x0bcbc160
kworker/0:3-1754 [000] … 177.605836: rtos_queue_peek_from_isr_failed: tstamp:5870231267 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 177.773863: rtos_queue_peek_from_isr_failed: tstamp:5875231266 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 177.941827: rtos_queue_peek_from_isr_failed: tstamp:5880231266 queue:0x0bcbcf78
kworker/0:0-4 [000] … 178.109830: rtos_queue_peek_from_isr_failed: tstamp:5885231266 queue:0x0bcbcf78
kworker/0:0-4 [000] … 178.277854: rtos_queue_peek_from_isr_failed: tstamp:5890231266 queue:0x0bcbcf78
kworker/0:0-4 [000] … 178.277861: rtos_queue_send_from_isr_failed: tstamp:5890602828 queue:0x0bcb41f8
kworker/0:0-4 [000] … 178.277862: rtos_queue_send_from_isr_failed: tstamp:5890603003 queue:0x0bcb8a60
kworker/0:0-4 [000] … 178.277863: rtos_queue_send_from_isr_failed: tstamp:5890603168 queue:0x0bcba5e0
kworker/0:0-4 [000] … 178.277864: rtos_queue_send_from_isr_failed: tstamp:5890603325 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 178.277865: rtos_queue_send_from_isr_failed: tstamp:5890603484 queue:0x0bcbc160
kworker/0:0-4 [000] … 178.389838: rtos_queue_peek_from_isr_failed: tstamp:5895231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 178.557839: rtos_queue_peek_from_isr_failed: tstamp:5900231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 178.725818: rtos_queue_peek_from_isr_failed: tstamp:5905231268 queue:0x0bcbcf78
kworker/0:0-4 [000] … 178.893829: rtos_queue_peek_from_isr_failed: tstamp:5910231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 179.061826: rtos_queue_peek_from_isr_failed: tstamp:5915231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 179.229821: rtos_queue_peek_from_isr_failed: tstamp:5920231263 queue:0x0bcbcf78
kworker/0:0-4 [000] … 179.397828: rtos_queue_peek_from_isr_failed: tstamp:5925231266 queue:0x0bcbcf78
kworker/0:0-4 [000] … 179.509819: rtos_queue_peek_from_isr_failed: tstamp:5930231263 queue:0x0bcbcf78
kworker/0:0-4 [000] … 179.567832: rtos_queue_send_from_isr_failed: tstamp:5931524064 queue:0x0bcb41f8
kworker/0:0-4 [000] … 179.567837: rtos_queue_send_from_isr_failed: tstamp:5931524227 queue:0x0bcb8a60
kworker/0:0-4 [000] … 179.567839: rtos_queue_send_from_isr_failed: tstamp:5931524389 queue:0x0bcba5e0
kworker/0:0-4 [000] … 179.567840: rtos_queue_send_from_isr_failed: tstamp:5931524548 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 179.567841: rtos_queue_send_from_isr_failed: tstamp:5931524707 queue:0x0bcbc160
kworker/0:0-4 [000] … 179.621874: rtos_queue_send_from_isr_failed: tstamp:5932061520 queue:0x0bcb41f8
kworker/0:0-4 [000] … 179.621880: rtos_queue_send_from_isr_failed: tstamp:5932061700 queue:0x0bcb8a60
kworker/0:0-4 [000] … 179.621881: rtos_queue_send_from_isr_failed: tstamp:5932061861 queue:0x0bcba5e0
kworker/0:0-4 [000] … 179.621882: rtos_queue_send_from_isr_failed: tstamp:5932062018 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 179.621883: rtos_queue_send_from_isr_failed: tstamp:5932062173 queue:0x0bcbc160
kworker/0:0-4 [000] … 179.621884: rtos_queue_send_from_isr_failed: tstamp:5933090803 queue:0x0bcb41f8
kworker/0:0-4 [000] … 179.621885: rtos_queue_send_from_isr_failed: tstamp:5933090983 queue:0x0bcb8a60
kworker/0:0-4 [000] … 179.621886: rtos_queue_send_from_isr_failed: tstamp:5933091143 queue:0x0bcba5e0
kworker/0:0-4 [000] … 179.621887: rtos_queue_send_from_isr_failed: tstamp:5933091301 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 179.621888: rtos_queue_send_from_isr_failed: tstamp:5933091458 queue:0x0bcbc160
kworker/0:0-4 [000] … 179.621889: rtos_queue_send_from_isr_failed: tstamp:5933259135 queue:0x0bcb41f8
kworker/0:0-4 [000] … 179.621890: rtos_queue_send_from_isr_failed: tstamp:5933259296 queue:0x0bcb8a60
kworker/0:0-4 [000] … 179.621891: rtos_queue_send_from_isr_failed: tstamp:5933259457 queue:0x0bcba5e0
kworker/0:0-4 [000] … 179.621892: rtos_queue_send_from_isr_failed: tstamp:5933259615 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 179.621893: rtos_queue_send_from_isr_failed: tstamp:5933259772 queue:0x0bcbc160
kworker/0:0-4 [000] … 179.621896: rtcpu_nvcsi_intr: tstamp:5933265501 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:0-4 [000] … 179.621898: rtcpu_nvcsi_intr: tstamp:5933265501 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:0-4 [000] … 179.621899: rtcpu_nvcsi_intr: tstamp:5933266565 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000000
kworker/0:0-4 [000] … 179.621900: rtos_queue_send_from_isr_failed: tstamp:5933635425 queue:0x0bcb41f8
kworker/0:0-4 [000] … 179.621901: rtos_queue_send_from_isr_failed: tstamp:5933635585 queue:0x0bcb8a60
kworker/0:0-4 [000] … 179.621902: rtos_queue_send_from_isr_failed: tstamp:5933635748 queue:0x0bcba5e0
kworker/0:0-4 [000] … 179.621903: rtos_queue_send_from_isr_failed: tstamp:5933635905 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 179.621904: rtos_queue_send_from_isr_failed: tstamp:5933636062 queue:0x0bcbc160
kworker/0:0-4 [000] … 179.621906: rtcpu_string: tstamp:5933636516 id:0x04010000 str:"Configuring VI GoS.
kworker/0:0-4 [000] … 179.621922: rtcpu_string: tstamp:5933636708 id:0x04010000 str:"VM GOS[#0 ] addr=0xc2100000
kworker/0:0-4 [000] … 179.621928: rtcpu_string: tstamp:5933636993 id:0x04010000 str:"VM GOS[#1 ] addr=0xc2101000
kworker/0:0-4 [000] … 179.621934: rtcpu_string: tstamp:5933637276 id:0x04010000 str:"VM GOS[#2 ] addr=0xc2102000
kworker/0:0-4 [000] … 179.621939: rtcpu_string: tstamp:5933637518 id:0x04010000 str:"VM GOS[#3 ] addr=0xc2103000
kworker/0:0-4 [000] … 179.621944: rtcpu_string: tstamp:5933637762 id:0x04010000 str:"VM GOS[#4 ] addr=0xc2104000
kworker/0:0-4 [000] … 179.621949: rtcpu_string: tstamp:5933638005 id:0x04010000 str:"VM GOS[#5 ] addr=0xc2105000
kworker/0:0-4 [000] … 179.677912: rtos_queue_peek_from_isr_failed: tstamp:5935231264 queue:0x0bcbcf78
kworker/0:0-4 [000] … 179.845816: rtos_queue_peek_from_isr_failed: tstamp:5940231268 queue:0x0bcbcf78
kworker/0:0-4 [000] … 179.957848: rtos_queue_send_from_isr_failed: tstamp:5942869751 queue:0x0bcb41f8
kworker/0:0-4 [000] … 179.957854: rtos_queue_send_from_isr_failed: tstamp:5942869916 queue:0x0bcb8a60
kworker/0:0-4 [000] … 179.957856: rtos_queue_send_from_isr_failed: tstamp:5942870079 queue:0x0bcba5e0
kworker/0:0-4 [000] … 179.957857: rtos_queue_send_from_isr_failed: tstamp:5942870236 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 179.957858: rtos_queue_send_from_isr_failed: tstamp:5942870393 queue:0x0bcbc160
kworker/0:0-4 [000] … 179.957861: rtcpu_vinotify_event: tstamp:5942939074 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:5488308640 data:0x10000000
kworker/0:0-4 [000] … 179.957862: rtcpu_vinotify_event: tstamp:5942939230 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:5488312448 data:0x31000001
kworker/0:0-4 [000] … 179.957863: rtcpu_vinotify_event: tstamp:5942939406 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:5488313440 data:0x07020001
kworker/0:0-4 [000] … 180.013898: rtos_queue_peek_from_isr_failed: tstamp:5945231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 180.181856: rtos_queue_peek_from_isr_failed: tstamp:5950231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 180.349871: rtos_queue_peek_from_isr_failed: tstamp:5955231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 180.517830: rtos_queue_peek_from_isr_failed: tstamp:5960231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 180.629857: rtos_queue_peek_from_isr_failed: tstamp:5965231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 180.685887: rtos_queue_send_from_isr_failed: tstamp:5966628291 queue:0x0bcb41f8
kworker/0:0-4 [000] … 180.685899: rtos_queue_send_from_isr_failed: tstamp:5966628457 queue:0x0bcb8a60
kworker/0:0-4 [000] … 180.685901: rtos_queue_send_from_isr_failed: tstamp:5966628619 queue:0x0bcba5e0
kworker/0:0-4 [000] … 180.685902: rtos_queue_send_from_isr_failed: tstamp:5966628780 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 180.685903: rtos_queue_send_from_isr_failed: tstamp:5966628937 queue:0x0bcbc160
kworker/0:0-4 [000] … 180.685905: rtcpu_vinotify_event: tstamp:5966727382 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:6248580192 data:0x10000000
kworker/0:0-4 [000] … 180.685907: rtcpu_vinotify_event: tstamp:5966727561 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:6248584064 data:0x31000002
kworker/0:0-4 [000] … 180.797862: rtos_queue_peek_from_isr_failed: tstamp:5970231268 queue:0x0bcbcf78
kworker/0:0-4 [000] … 180.965878: rtos_queue_peek_from_isr_failed: tstamp:5975231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 181.133892: rtos_queue_peek_from_isr_failed: tstamp:5980231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 181.301837: rtos_queue_peek_from_isr_failed: tstamp:5985231266 queue:0x0bcbcf78
kworker/0:0-4 [000] … 181.470012: rtos_queue_peek_from_isr_failed: tstamp:5990231268 queue:0x0bcbcf78
kworker/0:0-4 [000] … 181.581893: rtos_queue_send_from_isr_failed: tstamp:5994992612 queue:0x0bcb41f8
kworker/0:0-4 [000] … 181.581898: rtos_queue_send_from_isr_failed: tstamp:5994992809 queue:0x0bcb8a60
kworker/0:0-4 [000] … 181.581899: rtos_queue_send_from_isr_failed: tstamp:5994992971 queue:0x0bcba5e0
kworker/0:0-4 [000] … 181.581900: rtos_queue_send_from_isr_failed: tstamp:5994993128 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 181.581901: rtos_queue_send_from_isr_failed: tstamp:5994993283 queue:0x0bcbc160
kworker/0:0-4 [000] … 181.638127: rtos_queue_peek_from_isr_failed: tstamp:5995231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 181.749911: rtos_queue_peek_from_isr_failed: tstamp:6000231262 queue:0x0bcbcf78
kworker/0:0-4 [000] … 181.917855: rtos_queue_peek_from_isr_failed: tstamp:6005231293 queue:0x0bcbcf78
kworker/0:0-4 [000] … 182.085854: rtos_queue_peek_from_isr_failed: tstamp:6010231280 queue:0x0bcbcf78
kworker/0:0-4 [000] … 182.253868: rtos_queue_peek_from_isr_failed: tstamp:6015231266 queue:0x0bcbcf78
kworker/0:0-4 [000] … 182.365841: rtos_queue_send_from_isr_failed: tstamp:6018865087 queue:0x0bcb41f8
kworker/0:0-4 [000] … 182.365846: rtos_queue_send_from_isr_failed: tstamp:6018865252 queue:0x0bcb8a60
kworker/0:0-4 [000] … 182.365847: rtos_queue_send_from_isr_failed: tstamp:6018865415 queue:0x0bcba5e0
kworker/0:0-4 [000] … 182.365848: rtos_queue_send_from_isr_failed: tstamp:6018865572 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 182.365849: rtos_queue_send_from_isr_failed: tstamp:6018865729 queue:0x0bcbc160
kworker/0:0-4 [000] … 182.421841: rtos_queue_peek_from_isr_failed: tstamp:6020231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 182.589854: rtos_queue_peek_from_isr_failed: tstamp:6025231276 queue:0x0bcbcf78
kworker/0:0-4 [000] … 182.647497: rtos_queue_send_from_isr_failed: tstamp:6027522188 queue:0x0bcb41f8
kworker/0:0-4 [000] … 182.647502: rtos_queue_send_from_isr_failed: tstamp:6027522354 queue:0x0bcb8a60
kworker/0:0-4 [000] … 182.647504: rtos_queue_send_from_isr_failed: tstamp:6027522513 queue:0x0bcba5e0
kworker/0:0-4 [000] … 182.647505: rtos_queue_send_from_isr_failed: tstamp:6027522670 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 182.647506: rtos_queue_send_from_isr_failed: tstamp:6027522826 queue:0x0bcbc160
kworker/0:0-4 [000] … 182.647507: rtos_queue_send_from_isr_failed: tstamp:6028049278 queue:0x0bcb41f8
kworker/0:0-4 [000] … 182.647508: rtos_queue_send_from_isr_failed: tstamp:6028049444 queue:0x0bcb8a60
kworker/0:0-4 [000] … 182.647510: rtos_queue_send_from_isr_failed: tstamp:6028049603 queue:0x0bcba5e0
kworker/0:0-4 [000] … 182.647511: rtos_queue_send_from_isr_failed: tstamp:6028049762 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 182.647512: rtos_queue_send_from_isr_failed: tstamp:6028049918 queue:0x0bcbc160
kworker/0:0-4 [000] … 182.701902: rtos_queue_send_from_isr_failed: tstamp:6029107661 queue:0x0bcb41f8
kworker/0:0-4 [000] … 182.701907: rtos_queue_send_from_isr_failed: tstamp:6029107823 queue:0x0bcb8a60
kworker/0:0-4 [000] … 182.701909: rtos_queue_send_from_isr_failed: tstamp:6029107985 queue:0x0bcba5e0
kworker/0:0-4 [000] … 182.701910: rtos_queue_send_from_isr_failed: tstamp:6029108142 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 182.701911: rtos_queue_send_from_isr_failed: tstamp:6029108298 queue:0x0bcbc160
kworker/0:0-4 [000] … 182.701912: rtos_queue_send_from_isr_failed: tstamp:6029271952 queue:0x0bcb41f8
kworker/0:0-4 [000] … 182.701913: rtos_queue_send_from_isr_failed: tstamp:6029272114 queue:0x0bcb8a60
kworker/0:0-4 [000] … 182.701914: rtos_queue_send_from_isr_failed: tstamp:6029272277 queue:0x0bcba5e0
kworker/0:0-4 [000] … 182.701915: rtos_queue_send_from_isr_failed: tstamp:6029272434 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 182.701916: rtos_queue_send_from_isr_failed: tstamp:6029272588 queue:0x0bcbc160
kworker/0:0-4 [000] … 182.701918: rtcpu_nvcsi_intr: tstamp:6029278239 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:0-4 [000] … 182.701920: rtcpu_nvcsi_intr: tstamp:6029278239 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:0-4 [000] … 182.701921: rtcpu_nvcsi_intr: tstamp:6029279463 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000000
kworker/0:0-4 [000] … 182.701922: rtos_queue_send_from_isr_failed: tstamp:6029649327 queue:0x0bcb41f8
kworker/0:0-4 [000] … 182.701923: rtos_queue_send_from_isr_failed: tstamp:6029649491 queue:0x0bcb8a60
kworker/0:0-4 [000] … 182.701924: rtos_queue_send_from_isr_failed: tstamp:6029649654 queue:0x0bcba5e0
kworker/0:0-4 [000] … 182.701925: rtos_queue_send_from_isr_failed: tstamp:6029649811 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 182.701926: rtos_queue_send_from_isr_failed: tstamp:6029649968 queue:0x0bcbc160
kworker/0:0-4 [000] … 182.701929: rtcpu_string: tstamp:6029650437 id:0x04010000 str:"Configuring VI GoS.
kworker/0:0-4 [000] … 182.701945: rtcpu_string: tstamp:6029650629 id:0x04010000 str:"VM GOS[#0 ] addr=0xc2100000
kworker/0:0-4 [000] … 182.701952: rtcpu_string: tstamp:6029650896 id:0x04010000 str:"VM GOS[#1 ] addr=0xc2101000
kworker/0:0-4 [000] … 182.701959: rtcpu_string: tstamp:6029651181 id:0x04010000 str:"VM GOS[#2 ] addr=0xc2102000
kworker/0:0-4 [000] … 182.701965: rtcpu_string: tstamp:6029651424 id:0x04010000 str:"VM GOS[#3 ] addr=0xc2103000
kworker/0:0-4 [000] … 182.701971: rtcpu_string: tstamp:6029651665 id:0x04010000 str:"VM GOS[#4 ] addr=0xc2104000
kworker/0:0-4 [000] … 182.701977: rtcpu_string: tstamp:6029651906 id:0x04010000 str:"VM GOS[#5 ] addr=0xc2105000
kworker/0:0-4 [000] … 182.757851: rtos_queue_peek_from_isr_failed: tstamp:6030231272 queue:0x0bcbcf78
kworker/0:0-4 [000] … 182.869871: rtos_queue_peek_from_isr_failed: tstamp:6035231280 queue:0x0bcbcf78
kworker/0:0-4 [000] … 183.037847: rtos_queue_peek_from_isr_failed: tstamp:6040231280 queue:0x0bcbcf78
kworker/0:0-4 [000] … 183.149843: rtos_queue_send_from_isr_failed: tstamp:6042632678 queue:0x0bcb41f8
kworker/0:0-4 [000] … 183.149848: rtos_queue_send_from_isr_failed: tstamp:6042632844 queue:0x0bcb8a60
kworker/0:0-4 [000] … 183.149849: rtos_queue_send_from_isr_failed: tstamp:6042633007 queue:0x0bcba5e0
kworker/0:0-4 [000] … 183.149850: rtos_queue_send_from_isr_failed: tstamp:6042633165 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 183.149851: rtos_queue_send_from_isr_failed: tstamp:6042633322 queue:0x0bcbc160
kworker/0:0-4 [000] … 183.149854: rtcpu_vinotify_event: tstamp:6042635324 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4385753056 data:0x10000000
kworker/0:0-4 [000] … 183.149855: rtcpu_vinotify_event: tstamp:6042943863 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4385765792 data:0x31000001
kworker/0:0-4 [000] … 183.149857: rtcpu_vinotify_event: tstamp:6042944017 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4385766784 data:0x07020001
kworker/0:0-4 [000] … 183.205818: rtos_queue_peek_from_isr_failed: tstamp:6045231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 183.373818: rtos_queue_peek_from_isr_failed: tstamp:6050231298 queue:0x0bcbcf78
kworker/0:0-4 [000] … 183.541815: rtos_queue_peek_from_isr_failed: tstamp:6055231276 queue:0x0bcbcf78
kworker/0:0-4 [000] … 183.709813: rtos_queue_peek_from_isr_failed: tstamp:6060231266 queue:0x0bcbcf78
kworker/0:0-4 [000] … 183.877846: rtos_queue_peek_from_isr_failed: tstamp:6065231299 queue:0x0bcbcf78
kworker/0:0-4 [000] … 183.877852: rtos_queue_send_from_isr_failed: tstamp:6066497534 queue:0x0bcb41f8
kworker/0:0-4 [000] … 183.877854: rtos_queue_send_from_isr_failed: tstamp:6066497697 queue:0x0bcb8a60
kworker/0:0-4 [000] … 183.877855: rtos_queue_send_from_isr_failed: tstamp:6066497859 queue:0x0bcba5e0
kworker/0:0-4 [000] … 183.877856: rtos_queue_send_from_isr_failed: tstamp:6066498020 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 183.877857: rtos_queue_send_from_isr_failed: tstamp:6066498177 queue:0x0bcbc160
kworker/0:0-4 [000] … 183.877860: rtcpu_vinotify_event: tstamp:6066732099 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:5149428416 data:0x10000000
kworker/0:0-4 [000] … 183.877861: rtcpu_vinotify_event: tstamp:6066732256 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:5149432288 data:0x31000002
kworker/0:0-4 [000] … 183.989839: rtos_queue_peek_from_isr_failed: tstamp:6070231280 queue:0x0bcbcf78
kworker/0:0-4 [000] … 184.157852: rtos_queue_peek_from_isr_failed: tstamp:6075231277 queue:0x0bcbcf78
kworker/0:0-4 [000] … 184.325826: rtos_queue_peek_from_isr_failed: tstamp:6080231276 queue:0x0bcbcf78
kworker/0:0-4 [000] … 184.493817: rtos_queue_peek_from_isr_failed: tstamp:6085231279 queue:0x0bcbcf78
kworker/0:0-4 [000] … 184.661839: rtos_queue_peek_from_isr_failed: tstamp:6090231266 queue:0x0bcbcf78
kworker/0:0-4 [000] … 184.720334: rtos_queue_send_from_isr_failed: tstamp:6092998920 queue:0x0bcb41f8
kworker/0:0-4 [000] … 184.720340: rtos_queue_send_from_isr_failed: tstamp:6092999085 queue:0x0bcb8a60
kworker/0:0-4 [000] … 184.720341: rtos_queue_send_from_isr_failed: tstamp:6092999247 queue:0x0bcba5e0
kworker/0:0-4 [000] … 184.720343: rtos_queue_send_from_isr_failed: tstamp:6092999404 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 184.720344: rtos_queue_send_from_isr_failed: tstamp:6092999561 queue:0x0bcbc160
kworker/0:0-4 [000] … 184.829867: rtos_queue_peek_from_isr_failed: tstamp:6095231294 queue:0x0bcbcf78
kworker/0:0-4 [000] … 184.997883: rtos_queue_peek_from_isr_failed: tstamp:6100231272 queue:0x0bcbcf78
kworker/0:0-4 [000] … 185.109835: rtos_queue_peek_from_isr_failed: tstamp:6105231267 queue:0x0bcbcf78
kworker/0:0-4 [000] … 185.277855: rtos_queue_peek_from_isr_failed: tstamp:6110231297 queue:0x0bcbcf78
kworker/0:0-4 [000] … 185.445857: rtos_queue_peek_from_isr_failed: tstamp:6115231298 queue:0x0bcbcf78
kworker/0:0-4 [000] … 185.501879: rtos_queue_send_from_isr_failed: tstamp:6116952263 queue:0x0bcb41f8
kworker/0:0-4 [000] … 185.501883: rtos_queue_send_from_isr_failed: tstamp:6116952438 queue:0x0bcb8a60
kworker/0:0-4 [000] … 185.501885: rtos_queue_send_from_isr_failed: tstamp:6116952599 queue:0x0bcba5e0
kworker/0:0-4 [000] … 185.501886: rtos_queue_send_from_isr_failed: tstamp:6116952757 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 185.501887: rtos_queue_send_from_isr_failed: tstamp:6116952913 queue:0x0bcbc160
kworker/0:0-4 [000] … 185.619109: rtos_queue_peek_from_isr_failed: tstamp:6120231280 queue:0x0bcbcf78
kworker/0:0-4 [000] … 185.619115: rtos_queue_send_from_isr_failed: tstamp:6120898200 queue:0x0bcb41f8
kworker/0:0-4 [000] … 185.619117: rtos_queue_send_from_isr_failed: tstamp:6120898365 queue:0x0bcb8a60
kworker/0:0-4 [000] … 185.619118: rtos_queue_send_from_isr_failed: tstamp:6120898527 queue:0x0bcba5e0
kworker/0:0-4 [000] … 185.619119: rtos_queue_send_from_isr_failed: tstamp:6120898684 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 185.619120: rtos_queue_send_from_isr_failed: tstamp:6120898841 queue:0x0bcbc160
kworker/0:0-4 [000] … 185.675061: rtos_queue_send_from_isr_failed: tstamp:6121326136 queue:0x0bcb41f8
kworker/0:0-4 [000] … 185.675066: rtos_queue_send_from_isr_failed: tstamp:6121326350 queue:0x0bcb8a60
kworker/0:0-4 [000] … 185.675067: rtos_queue_send_from_isr_failed: tstamp:6121326512 queue:0x0bcba5e0
kworker/0:0-4 [000] … 185.675068: rtos_queue_send_from_isr_failed: tstamp:6121326669 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 185.675069: rtos_queue_send_from_isr_failed: tstamp:6121326825 queue:0x0bcbc160
kworker/0:0-4 [000] … 185.675070: rtos_queue_send_from_isr_failed: tstamp:6122368182 queue:0x0bcb41f8
kworker/0:0-4 [000] … 185.675072: rtos_queue_send_from_isr_failed: tstamp:6122368344 queue:0x0bcb8a60
kworker/0:0-4 [000] … 185.675073: rtos_queue_send_from_isr_failed: tstamp:6122368504 queue:0x0bcba5e0
kworker/0:0-4 [000] … 185.675074: rtos_queue_send_from_isr_failed: tstamp:6122368659 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 185.675075: rtos_queue_send_from_isr_failed: tstamp:6122368816 queue:0x0bcbc160
kworker/0:0-4 [000] … 185.675076: rtos_queue_send_from_isr_failed: tstamp:6122533005 queue:0x0bcb41f8
kworker/0:0-4 [000] … 185.675077: rtos_queue_send_from_isr_failed: tstamp:6122533168 queue:0x0bcb8a60
kworker/0:0-4 [000] … 185.675078: rtos_queue_send_from_isr_failed: tstamp:6122533327 queue:0x0bcba5e0
kworker/0:0-4 [000] … 185.675079: rtos_queue_send_from_isr_failed: tstamp:6122533484 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 185.675080: rtos_queue_send_from_isr_failed: tstamp:6122533641 queue:0x0bcbc160
kworker/0:0-4 [000] … 185.675083: rtcpu_nvcsi_intr: tstamp:6122539270 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:0-4 [000] … 185.675085: rtcpu_nvcsi_intr: tstamp:6122539270 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:0-4 [000] … 185.675086: rtcpu_nvcsi_intr: tstamp:6122540743 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000000
kworker/0:0-4 [000] … 185.730050: rtos_queue_send_from_isr_failed: tstamp:6122914323 queue:0x0bcb41f8
kworker/0:0-4 [000] … 185.730061: rtos_queue_send_from_isr_failed: tstamp:6122914491 queue:0x0bcb8a60
kworker/0:0-4 [000] … 185.730062: rtos_queue_send_from_isr_failed: tstamp:6122914654 queue:0x0bcba5e0
kworker/0:0-4 [000] … 185.730065: rtos_queue_send_from_isr_failed: tstamp:6122914811 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 185.730066: rtos_queue_send_from_isr_failed: tstamp:6122914969 queue:0x0bcbc160
kworker/0:0-4 [000] … 185.730071: rtcpu_string: tstamp:6122915438 id:0x04010000 str:"Configuring VI GoS.
kworker/0:0-4 [000] … 185.730107: rtcpu_string: tstamp:6122915630 id:0x04010000 str:"VM GOS[#0 ] addr=0xc2100000
kworker/0:0-4 [000] … 185.730114: rtcpu_string: tstamp:6122915899 id:0x04010000 str:"VM GOS[#1 ] addr=0xc2101000
kworker/0:0-4 [000] … 185.730120: rtcpu_string: tstamp:6122916181 id:0x04010000 str:"VM GOS[#2 ] addr=0xc2102000
kworker/0:0-4 [000] … 185.730127: rtcpu_string: tstamp:6122916424 id:0x04010000 str:"VM GOS[#3 ] addr=0xc2103000
kworker/0:0-4 [000] … 185.730133: rtcpu_string: tstamp:6122916665 id:0x04010000 str:"VM GOS[#4 ] addr=0xc2104000
kworker/0:0-4 [000] … 185.730139: rtcpu_string: tstamp:6122916906 id:0x04010000 str:"VM GOS[#5 ] addr=0xc2105000
kworker/0:0-4 [000] … 185.730145: rtos_queue_send_from_isr_failed: tstamp:6124178248 queue:0x0bcb41f8
kworker/0:0-4 [000] … 185.730146: rtos_queue_send_from_isr_failed: tstamp:6124178423 queue:0x0bcb8a60
kworker/0:0-4 [000] … 185.730194: rtos_queue_send_from_isr_failed: tstamp:6124178588 queue:0x0bcba5e0
kworker/0:0-4 [000] … 185.730196: rtos_queue_send_from_isr_failed: tstamp:6124178745 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 185.730197: rtos_queue_send_from_isr_failed: tstamp:6124178903 queue:0x0bcbc160
kworker/0:0-4 [000] … 185.730198: rtos_queue_send_from_isr_failed: tstamp:6124370077 queue:0x0bcb41f8
kworker/0:0-4 [000] … 185.730199: rtos_queue_send_from_isr_failed: tstamp:6124370385 queue:0x0bcb8a60
kworker/0:0-4 [000] … 185.730200: rtos_queue_send_from_isr_failed: tstamp:6124370694 queue:0x0bcba5e0
kworker/0:0-4 [000] … 185.730201: rtos_queue_send_from_isr_failed: tstamp:6124370990 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 185.730202: rtos_queue_send_from_isr_failed: tstamp:6124371286 queue:0x0bcbc160
kworker/0:0-4 [000] … 185.786013: rtos_queue_peek_from_isr_failed: tstamp:6125231345 queue:0x0bcbcf78
kworker/0:0-4 [000] … 185.953858: rtos_queue_peek_from_isr_failed: tstamp:6130231344 queue:0x0bcbcf78
kworker/0:0-4 [000] … 186.122009: rtos_queue_peek_from_isr_failed: tstamp:6135231347 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 186.233877: rtos_queue_peek_from_isr_failed: tstamp:6140231344 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 186.401831: rtos_queue_peek_from_isr_failed: tstamp:6145231337 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 186.569825: rtos_queue_peek_from_isr_failed: tstamp:6150231337 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 186.737823: rtos_queue_peek_from_isr_failed: tstamp:6155231337 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 186.905829: rtos_queue_peek_from_isr_failed: tstamp:6160231337 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 187.073817: rtos_queue_peek_from_isr_failed: tstamp:6165231342 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 187.241823: rtos_queue_peek_from_isr_failed: tstamp:6170231337 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 187.353817: rtos_queue_peek_from_isr_failed: tstamp:6175231350 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 187.521815: rtos_queue_peek_from_isr_failed: tstamp:6180231338 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 187.689829: rtos_queue_peek_from_isr_failed: tstamp:6185231338 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 187.857822: rtos_queue_peek_from_isr_failed: tstamp:6190231346 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 188.025839: rtos_queue_peek_from_isr_failed: tstamp:6195231338 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 188.193817: rtos_queue_peek_from_isr_failed: tstamp:6200231336 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 188.361821: rtos_queue_peek_from_isr_failed: tstamp:6205231338 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 188.473848: rtos_queue_peek_from_isr_failed: tstamp:6210231341 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 188.641819: rtos_queue_peek_from_isr_failed: tstamp:6215231337 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 188.809836: rtos_queue_peek_from_isr_failed: tstamp:6220231337 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 188.977820: rtos_queue_peek_from_isr_failed: tstamp:6225231338 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 189.145820: rtos_queue_peek_from_isr_failed: tstamp:6230231338 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 189.313818: rtos_queue_peek_from_isr_failed: tstamp:6235231337 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 189.481834: rtos_queue_peek_from_isr_failed: tstamp:6240231338 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 189.593818: rtos_queue_peek_from_isr_failed: tstamp:6245231340 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 189.761818: rtos_queue_peek_from_isr_failed: tstamp:6250231340 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 189.929839: rtos_queue_peek_from_isr_failed: tstamp:6255231344 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 190.097840: rtos_queue_peek_from_isr_failed: tstamp:6260231337 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 190.265843: rtos_queue_peek_from_isr_failed: tstamp:6265231340 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 190.433829: rtos_queue_peek_from_isr_failed: tstamp:6270231338 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 190.601824: rtos_queue_peek_from_isr_failed: tstamp:6275231337 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 190.713832: rtos_queue_peek_from_isr_failed: tstamp:6280231337 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 190.881822: rtos_queue_peek_from_isr_failed: tstamp:6285231340 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 191.049843: rtos_queue_peek_from_isr_failed: tstamp:6290231333 queue:0x0bcbcf78
kworker/0:3-1754 [000] … 191.217817: rtos_queue_peek_from_isr_failed: tstamp:6295231333 queue:0x0bcbcf78
kworker/0:0-4 [000] … 191.329829: rtos_queue_peek_from_isr_failed: tstamp:6299499000 queue:0x0bcbcf78
The trace log show the intr_cil_data_lane_rxfifo_full_err1_a, could you increase the pix_clk_hz or have smaller output size to try.
ray_lo
June 23, 2020, 3:56am
6
I adjust pix_clk_hz 1800000000 to 4000000000
Still nothing change.
Trace
kworker/0:1-727 [000] … 90.876012: rtos_queue_peek_from_isr_failed: tstamp:3154489971 queue:0x0bcbcf78
kworker/0:1-727 [000] … 91.044059: rtos_queue_peek_from_isr_failed: tstamp:3159489974 queue:0x0bcbcf78
kworker/0:1-727 [000] … 91.212013: rtos_queue_peek_from_isr_failed: tstamp:3164489973 queue:0x0bcbcf78
kworker/0:1-727 [000] … 91.380052: rtos_queue_peek_from_isr_failed: tstamp:3169489971 queue:0x0bcbcf78
kworker/0:1-727 [000] … 91.492004: rtos_queue_peek_from_isr_failed: tstamp:3174489983 queue:0x0bcbcf78
kworker/0:1-727 [000] … 91.660005: rtos_queue_peek_from_isr_failed: tstamp:3179489971 queue:0x0bcbcf78
kworker/0:1-727 [000] … 91.828001: rtos_queue_peek_from_isr_failed: tstamp:3184489975 queue:0x0bcbcf78
kworker/0:1-727 [000] … 91.996003: rtos_queue_peek_from_isr_failed: tstamp:3189489975 queue:0x0bcbcf78
kworker/0:1-727 [000] … 92.164004: rtos_queue_peek_from_isr_failed: tstamp:3194489974 queue:0x0bcbcf78
kworker/0:1-727 [000] … 92.332003: rtos_queue_peek_from_isr_failed: tstamp:3199489987 queue:0x0bcbcf78
kworker/0:1-727 [000] … 92.500069: rtos_queue_peek_from_isr_failed: tstamp:3204489974 queue:0x0bcbcf78
kworker/0:1-727 [000] … 92.612063: rtos_queue_peek_from_isr_failed: tstamp:3209489974 queue:0x0bcbcf78
kworker/0:1-727 [000] … 92.780076: rtos_queue_peek_from_isr_failed: tstamp:3214489971 queue:0x0bcbcf78
kworker/0:1-727 [000] … 92.948002: rtos_queue_peek_from_isr_failed: tstamp:3219489975 queue:0x0bcbcf78
kworker/0:1-727 [000] … 93.116022: rtos_queue_peek_from_isr_failed: tstamp:3224489974 queue:0x0bcbcf78
kworker/0:1-727 [000] … 93.284006: rtos_queue_peek_from_isr_failed: tstamp:3229489978 queue:0x0bcbcf78
kworker/0:1-727 [000] … 93.452002: rtos_queue_peek_from_isr_failed: tstamp:3234489977 queue:0x0bcbcf78
kworker/0:1-727 [000] … 93.620016: rtos_queue_peek_from_isr_failed: tstamp:3239489978 queue:0x0bcbcf78
kworker/0:1-727 [000] … 93.732004: rtos_queue_peek_from_isr_failed: tstamp:3244489975 queue:0x0bcbcf78
kworker/0:1-727 [000] … 93.900008: rtos_queue_peek_from_isr_failed: tstamp:3249489973 queue:0x0bcbcf78
kworker/0:1-727 [000] … 94.068037: rtos_queue_peek_from_isr_failed: tstamp:3254489975 queue:0x0bcbcf78
kworker/0:1-727 [000] … 94.236015: rtos_queue_peek_from_isr_failed: tstamp:3259489975 queue:0x0bcbcf78
kworker/0:1-727 [000] … 94.404018: rtos_queue_peek_from_isr_failed: tstamp:3264489978 queue:0x0bcbcf78
kworker/0:1-727 [000] … 94.572024: rtos_queue_peek_from_isr_failed: tstamp:3269489975 queue:0x0bcbcf78
kworker/0:1-727 [000] … 94.740003: rtos_queue_peek_from_isr_failed: tstamp:3274489978 queue:0x0bcbcf78
kworker/0:1-727 [000] … 94.852002: rtos_queue_peek_from_isr_failed: tstamp:3279489983 queue:0x0bcbcf78
kworker/0:1-727 [000] … 95.020002: rtos_queue_peek_from_isr_failed: tstamp:3284489975 queue:0x0bcbcf78
kworker/0:1-727 [000] … 95.188032: rtos_queue_peek_from_isr_failed: tstamp:3289489975 queue:0x0bcbcf78
kworker/0:1-727 [000] … 95.356158: rtos_queue_peek_from_isr_failed: tstamp:3294489979 queue:0x0bcbcf78
kworker/0:1-727 [000] … 95.356167: rtos_queue_peek_from_isr_failed: tstamp:3294678821 queue:0x0bcbcf78
kworker/0:1-727 [000] … 95.864040: rtos_queue_peek_from_isr_failed: tstamp:3309993616 queue:0x0bcbcf78
kworker/0:1-727 [000] … 95.864048: rtcpu_start: tstamp:3309997336
kworker/0:1-727 [000] … 95.864050: rtos_queue_send_from_isr_failed: tstamp:3310128736 queue:0x0bcb41f8
kworker/0:1-727 [000] … 95.864052: rtos_queue_send_from_isr_failed: tstamp:3310129035 queue:0x0bcb8a60
kworker/0:1-727 [000] … 95.864053: rtos_queue_send_from_isr_failed: tstamp:3310129332 queue:0x0bcba5e0
kworker/0:1-727 [000] … 95.864054: rtos_queue_send_from_isr_failed: tstamp:3310129625 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 95.864055: rtos_queue_send_from_isr_failed: tstamp:3310129919 queue:0x0bcbc160
kworker/0:1-727 [000] … 95.864084: rtcpu_string: tstamp:3310130735 id:0x04010000 str:"Configuring VI GoS.
kworker/0:1-727 [000] … 95.864098: rtcpu_string: tstamp:3310131098 id:0x04010000 str:"VM GOS[#0 ] addr=0xc2100000
kworker/0:1-727 [000] … 95.864102: rtcpu_string: tstamp:3310131518 id:0x04010000 str:"VM GOS[#1 ] addr=0xc2101000
kworker/0:1-727 [000] … 95.864107: rtcpu_string: tstamp:3310132003 id:0x04010000 str:"VM GOS[#2 ] addr=0xc2102000
kworker/0:1-727 [000] … 95.864111: rtcpu_string: tstamp:3310132405 id:0x04010000 str:"VM GOS[#3 ] addr=0xc2103000
kworker/0:1-727 [000] … 95.864115: rtcpu_string: tstamp:3310132814 id:0x04010000 str:"VM GOS[#4 ] addr=0xc2104000
kworker/0:1-727 [000] … 95.864119: rtcpu_string: tstamp:3310133260 id:0x04010000 str:"VM GOS[#5 ] addr=0xc2105000
kworker/0:1-727 [000] … 95.864123: rtcpu_string: tstamp:3310144296 id:0x04010000 str:“vi5_hwinit: firmware CL2018101701 protocol versi”
kworker/0:1-727 [000] … 95.864125: rtcpu_string: tstamp:3310144572 id:0x04010000 str:"on 2.2
kworker/0:1-727 [000] … 95.864129: rtos_queue_send_from_isr_failed: tstamp:3310457812 queue:0x0bcb41f8
kworker/0:1-727 [000] … 95.864131: rtos_queue_send_from_isr_failed: tstamp:3310457994 queue:0x0bcb8a60
kworker/0:1-727 [000] … 95.864132: rtos_queue_send_from_isr_failed: tstamp:3310458156 queue:0x0bcba5e0
kworker/0:1-727 [000] … 95.864133: rtos_queue_send_from_isr_failed: tstamp:3310458312 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 95.864134: rtos_queue_send_from_isr_failed: tstamp:3310458467 queue:0x0bcbc160
kworker/0:1-727 [000] … 95.983574: rtos_queue_send_from_isr_failed: tstamp:3313354354 queue:0x0bcb41f8
kworker/0:1-727 [000] … 95.983579: rtos_queue_send_from_isr_failed: tstamp:3313354533 queue:0x0bcb8a60
kworker/0:1-727 [000] … 95.983581: rtos_queue_send_from_isr_failed: tstamp:3313354694 queue:0x0bcba5e0
kworker/0:1-727 [000] … 95.983582: rtos_queue_send_from_isr_failed: tstamp:3313354849 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 95.983583: rtos_queue_send_from_isr_failed: tstamp:3313355005 queue:0x0bcbc160
kworker/0:1-727 [000] … 95.983585: rtcpu_string: tstamp:3313355882 id:0x04010000 str:"VI GOS[#0 ] set to VM GOS[4] base 0xc2104000
kworker/0:1-727 [000] … 95.983598: rtcpu_vinotify_event: tstamp:3313367908 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2948203520 data:0x10000000
kworker/0:1-727 [000] … 95.983599: rtcpu_vinotify_event: tstamp:3313368064 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2948207360 data:0x31000001
kworker/0:1-727 [000] … 95.983601: rtcpu_vinotify_event: tstamp:3313368238 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2948208352 data:0x07020001
kworker/0:1-727 [000] … 95.983602: rtcpu_nvcsi_intr: tstamp:3314436662 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000100
kworker/0:1-727 [000] … 95.983604: rtcpu_nvcsi_intr: tstamp:3314436662 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:1-727 [000] … 95.983606: rtos_queue_peek_from_isr_failed: tstamp:3314993996 queue:0x0bcbcf78
kworker/0:1-727 [000] … 96.036027: rtos_queue_send_from_isr_failed: tstamp:3315514020 queue:0x0bcb41f8
kworker/0:1-727 [000] … 96.036031: rtos_queue_send_from_isr_failed: tstamp:3315514184 queue:0x0bcb8a60
kworker/0:1-727 [000] … 96.036032: rtos_queue_send_from_isr_failed: tstamp:3315514348 queue:0x0bcba5e0
kworker/0:1-727 [000] … 96.036033: rtos_queue_send_from_isr_failed: tstamp:3315514506 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 96.036034: rtos_queue_send_from_isr_failed: tstamp:3315514663 queue:0x0bcbc160
kworker/0:1-727 [000] … 96.036036: rtcpu_vinotify_event: tstamp:3315558960 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3017303136 data:0x10000000
kworker/0:1-727 [000] … 96.036038: rtcpu_vinotify_event: tstamp:3315559138 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3017307040 data:0x31000002
kworker/0:1-727 [000] … 96.036039: rtos_queue_send_from_isr_failed: tstamp:3316288583 queue:0x0bcb41f8
kworker/0:1-727 [000] … 96.036040: rtos_queue_send_from_isr_failed: tstamp:3316288743 queue:0x0bcb8a60
kworker/0:1-727 [000] … 96.036041: rtos_queue_send_from_isr_failed: tstamp:3316288904 queue:0x0bcba5e0
kworker/0:1-727 [000] … 96.036042: rtos_queue_send_from_isr_failed: tstamp:3316289061 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 96.036043: rtos_queue_send_from_isr_failed: tstamp:3316289215 queue:0x0bcbc160
kworker/0:1-727 [000] … 96.092028: rtos_queue_send_from_isr_failed: tstamp:3317061085 queue:0x0bcb41f8
kworker/0:1-727 [000] … 96.092031: rtos_queue_send_from_isr_failed: tstamp:3317061247 queue:0x0bcb8a60
kworker/0:1-727 [000] … 96.092032: rtos_queue_send_from_isr_failed: tstamp:3317061408 queue:0x0bcba5e0
kworker/0:1-727 [000] … 96.092033: rtos_queue_send_from_isr_failed: tstamp:3317061584 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 96.092034: rtos_queue_send_from_isr_failed: tstamp:3317061743 queue:0x0bcbc160
kworker/0:1-727 [000] … 96.148025: rtos_queue_peek_from_isr_failed: tstamp:3319993996 queue:0x0bcbcf78
kworker/0:1-727 [000] … 96.316029: rtos_queue_peek_from_isr_failed: tstamp:3324993999 queue:0x0bcbcf78
kworker/0:1-727 [000] … 96.483998: rtos_queue_peek_from_isr_failed: tstamp:3329993998 queue:0x0bcbcf78
kworker/0:1-727 [000] … 96.652003: rtos_queue_peek_from_isr_failed: tstamp:3334993998 queue:0x0bcbcf78
kworker/0:1-727 [000] … 96.819998: rtos_queue_peek_from_isr_failed: tstamp:3339993998 queue:0x0bcbcf78
kworker/0:1-727 [000] … 96.988000: rtos_queue_peek_from_isr_failed: tstamp:3344993995 queue:0x0bcbcf78
kworker/0:1-727 [000] … 97.156030: rtos_queue_peek_from_isr_failed: tstamp:3349993994 queue:0x0bcbcf78
kworker/0:1-727 [000] … 97.268004: rtos_queue_peek_from_isr_failed: tstamp:3354994000 queue:0x0bcbcf78
kworker/0:1-727 [000] … 97.435999: rtos_queue_peek_from_isr_failed: tstamp:3359993996 queue:0x0bcbcf78
kworker/0:1-727 [000] … 97.604000: rtos_queue_peek_from_isr_failed: tstamp:3364993998 queue:0x0bcbcf78
kworker/0:1-727 [000] … 97.772001: rtos_queue_peek_from_isr_failed: tstamp:3369993998 queue:0x0bcbcf78
kworker/0:1-727 [000] … 97.940001: rtos_queue_peek_from_isr_failed: tstamp:3374994000 queue:0x0bcbcf78
kworker/0:1-727 [000] … 98.108003: rtos_queue_peek_from_isr_failed: tstamp:3379993998 queue:0x0bcbcf78
kworker/0:1-727 [000] … 98.276023: rtos_queue_peek_from_isr_failed: tstamp:3384993998 queue:0x0bcbcf78
kworker/0:1-727 [000] … 98.387998: rtos_queue_peek_from_isr_failed: tstamp:3389993998 queue:0x0bcbcf78
kworker/0:1-727 [000] … 98.556021: rtos_queue_peek_from_isr_failed: tstamp:3394993996 queue:0x0bcbcf78
kworker/0:1-727 [000] … 98.672503: rtos_queue_send_from_isr_failed: tstamp:3398740285 queue:0x0bcb41f8
kworker/0:1-727 [000] … 98.672538: rtos_queue_send_from_isr_failed: tstamp:3398740447 queue:0x0bcb8a60
kworker/0:1-727 [000] … 98.672540: rtos_queue_send_from_isr_failed: tstamp:3398740608 queue:0x0bcba5e0
kworker/0:1-727 [000] … 98.672541: rtos_queue_send_from_isr_failed: tstamp:3398740765 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 98.672542: rtos_queue_send_from_isr_failed: tstamp:3398740921 queue:0x0bcbc160
kworker/0:1-727 [000] … 98.728050: rtos_queue_peek_from_isr_failed: tstamp:3399993996 queue:0x0bcbcf78
kworker/0:1-727 [000] … 98.848025: rtos_queue_send_from_isr_failed: tstamp:3403087458 queue:0x0bcb41f8
kworker/0:1-727 [000] … 98.848030: rtos_queue_send_from_isr_failed: tstamp:3403087623 queue:0x0bcb8a60
kworker/0:1-727 [000] … 98.848032: rtos_queue_send_from_isr_failed: tstamp:3403087785 queue:0x0bcba5e0
kworker/0:1-727 [000] … 98.848033: rtos_queue_send_from_isr_failed: tstamp:3403087955 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 98.848034: rtos_queue_send_from_isr_failed: tstamp:3403088111 queue:0x0bcbc160
kworker/0:1-727 [000] … 98.848035: rtos_queue_send_from_isr_failed: tstamp:3404123273 queue:0x0bcb41f8
kworker/0:1-727 [000] … 98.848037: rtos_queue_send_from_isr_failed: tstamp:3404123433 queue:0x0bcb8a60
kworker/0:1-727 [000] … 98.848038: rtos_queue_send_from_isr_failed: tstamp:3404123594 queue:0x0bcba5e0
kworker/0:1-727 [000] … 98.848039: rtos_queue_send_from_isr_failed: tstamp:3404123751 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 98.848040: rtos_queue_send_from_isr_failed: tstamp:3404123908 queue:0x0bcbc160
kworker/0:1-727 [000] … 98.848041: rtos_queue_send_from_isr_failed: tstamp:3404296387 queue:0x0bcb41f8
kworker/0:1-727 [000] … 98.848042: rtos_queue_send_from_isr_failed: tstamp:3404296548 queue:0x0bcb8a60
kworker/0:1-727 [000] … 98.848044: rtos_queue_send_from_isr_failed: tstamp:3404296708 queue:0x0bcba5e0
kworker/0:1-727 [000] … 98.848046: rtos_queue_send_from_isr_failed: tstamp:3404296866 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 98.848047: rtos_queue_send_from_isr_failed: tstamp:3404297021 queue:0x0bcbc160
kworker/0:1-727 [000] … 98.848049: rtcpu_nvcsi_intr: tstamp:3404302676 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:1-727 [000] … 98.848051: rtcpu_nvcsi_intr: tstamp:3404302676 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:1-727 [000] … 98.848052: rtcpu_nvcsi_intr: tstamp:3404304161 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000000
kworker/0:1-727 [000] … 98.904099: rtos_queue_send_from_isr_failed: tstamp:3404672273 queue:0x0bcb41f8
kworker/0:1-727 [000] … 98.904103: rtos_queue_send_from_isr_failed: tstamp:3404672439 queue:0x0bcb8a60
kworker/0:1-727 [000] … 98.904104: rtos_queue_send_from_isr_failed: tstamp:3404672602 queue:0x0bcba5e0
kworker/0:1-727 [000] … 98.904106: rtos_queue_send_from_isr_failed: tstamp:3404672762 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 98.904107: rtos_queue_send_from_isr_failed: tstamp:3404672920 queue:0x0bcbc160
kworker/0:1-727 [000] … 98.904109: rtcpu_string: tstamp:3404673376 id:0x04010000 str:"Configuring VI GoS.
kworker/0:1-727 [000] … 98.904121: rtcpu_string: tstamp:3404673570 id:0x04010000 str:"VM GOS[#0 ] addr=0xc2100000
kworker/0:1-727 [000] … 98.904126: rtcpu_string: tstamp:3404673835 id:0x04010000 str:"VM GOS[#1 ] addr=0xc2101000
kworker/0:1-727 [000] … 98.904130: rtcpu_string: tstamp:3404674122 id:0x04010000 str:"VM GOS[#2 ] addr=0xc2102000
kworker/0:1-727 [000] … 98.904135: rtcpu_string: tstamp:3404674365 id:0x04010000 str:"VM GOS[#3 ] addr=0xc2103000
kworker/0:1-727 [000] … 98.904139: rtcpu_string: tstamp:3404674608 id:0x04010000 str:"VM GOS[#4 ] addr=0xc2104000
kworker/0:1-727 [000] … 98.904143: rtcpu_string: tstamp:3404674852 id:0x04010000 str:"VM GOS[#5 ] addr=0xc2105000
kworker/0:1-727 [000] … 98.904147: rtos_queue_send_from_isr_failed: tstamp:3404683278 queue:0x0bcb41f8
kworker/0:1-727 [000] … 98.904148: rtos_queue_send_from_isr_failed: tstamp:3404683439 queue:0x0bcb8a60
kworker/0:1-727 [000] … 98.904149: rtos_queue_send_from_isr_failed: tstamp:3404683602 queue:0x0bcba5e0
kworker/0:1-727 [000] … 98.904150: rtos_queue_send_from_isr_failed: tstamp:3404683759 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 98.904151: rtos_queue_send_from_isr_failed: tstamp:3404683915 queue:0x0bcbc160
kworker/0:1-727 [000] … 98.904154: rtcpu_vinotify_event: tstamp:3404765071 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1575751840 data:0x10000000
kworker/0:1-727 [000] … 98.904156: rtcpu_vinotify_event: tstamp:3404765251 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1575755648 data:0x31000001
kworker/0:1-727 [000] … 98.904157: rtcpu_vinotify_event: tstamp:3404765403 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:1575756640 data:0x07020001
kworker/0:1-727 [000] … 98.904158: rtcpu_vinotify_event: tstamp:3404765573 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1575793280 data:0x10000000
kworker/0:1-727 [000] … 98.904159: rtcpu_vinotify_event: tstamp:3404765718 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1575797184 data:0x31000002
kworker/0:1-727 [000] … 98.904161: rtos_queue_peek_from_isr_failed: tstamp:3404994000 queue:0x0bcbcf78
kworker/0:1-727 [000] … 99.068076: rtos_queue_peek_from_isr_failed: tstamp:3409993996 queue:0x0bcbcf78
kworker/0:1-727 [000] … 99.236067: rtos_queue_peek_from_isr_failed: tstamp:3414993996 queue:0x0bcbcf78
kworker/0:1-727 [000] … 99.348059: rtos_queue_peek_from_isr_failed: tstamp:3419993996 queue:0x0bcbcf78
kworker/0:1-727 [000] … 99.516026: rtos_queue_peek_from_isr_failed: tstamp:3424993996 queue:0x0bcbcf78
kworker/0:1-727 [000] … 99.684038: rtos_queue_peek_from_isr_failed: tstamp:3429993999 queue:0x0bcbcf78
kworker/0:1-727 [000] … 99.740053: rtos_queue_send_from_isr_failed: tstamp:3430856783 queue:0x0bcb41f8
kworker/0:1-727 [000] … 99.740060: rtos_queue_send_from_isr_failed: tstamp:3430856949 queue:0x0bcb8a60
kworker/0:1-727 [000] … 99.740061: rtos_queue_send_from_isr_failed: tstamp:3430857112 queue:0x0bcba5e0
kworker/0:1-727 [000] … 99.740062: rtos_queue_send_from_isr_failed: tstamp:3430857269 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 99.740063: rtos_queue_send_from_isr_failed: tstamp:3430857426 queue:0x0bcbc160
kworker/0:1-727 [000] … 99.852072: rtos_queue_peek_from_isr_failed: tstamp:3434994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 100.020040: rtos_queue_peek_from_isr_failed: tstamp:3439994003 queue:0x0bcbcf78
kworker/0:0-4 [000] … 100.188044: rtos_queue_peek_from_isr_failed: tstamp:3444993998 queue:0x0bcbcf78
kworker/0:0-4 [000] … 100.356061: rtos_queue_peek_from_isr_failed: tstamp:3449993998 queue:0x0bcbcf78
kworker/0:0-4 [000] … 100.472065: rtos_queue_send_from_isr_failed: tstamp:3454789370 queue:0x0bcb41f8
kworker/0:0-4 [000] … 100.472070: rtos_queue_send_from_isr_failed: tstamp:3454789568 queue:0x0bcb8a60
kworker/0:0-4 [000] … 100.472072: rtos_queue_send_from_isr_failed: tstamp:3454789730 queue:0x0bcba5e0
kworker/0:0-4 [000] … 100.472073: rtos_queue_send_from_isr_failed: tstamp:3454789887 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 100.472074: rtos_queue_send_from_isr_failed: tstamp:3454790044 queue:0x0bcbc160
kworker/0:0-4 [000] … 100.472076: rtos_queue_peek_from_isr_failed: tstamp:3454993996 queue:0x0bcbcf78
kworker/0:0-4 [000] … 100.640041: rtos_queue_peek_from_isr_failed: tstamp:3459994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 100.808050: rtos_queue_peek_from_isr_failed: tstamp:3464994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 100.976022: rtos_queue_peek_from_isr_failed: tstamp:3469994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 101.144007: rtos_queue_peek_from_isr_failed: tstamp:3474994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 101.312030: rtos_queue_peek_from_isr_failed: tstamp:3479994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 101.424027: rtos_queue_peek_from_isr_failed: tstamp:3484993999 queue:0x0bcbcf78
kworker/0:0-4 [000] … 101.480046: rtos_queue_send_from_isr_failed: tstamp:3486703537 queue:0x0bcb41f8
kworker/0:0-4 [000] … 101.480049: rtos_queue_send_from_isr_failed: tstamp:3486703699 queue:0x0bcb8a60
kworker/0:0-4 [000] … 101.480051: rtos_queue_send_from_isr_failed: tstamp:3486703860 queue:0x0bcba5e0
kworker/0:0-4 [000] … 101.480052: rtos_queue_send_from_isr_failed: tstamp:3486704017 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 101.480053: rtos_queue_send_from_isr_failed: tstamp:3486704174 queue:0x0bcbc160
kworker/0:0-4 [000] … 101.536066: rtos_queue_send_from_isr_failed: tstamp:3487231854 queue:0x0bcb41f8
kworker/0:0-4 [000] … 101.536072: rtos_queue_send_from_isr_failed: tstamp:3487232015 queue:0x0bcb8a60
kworker/0:0-4 [000] … 101.536073: rtos_queue_send_from_isr_failed: tstamp:3487232176 queue:0x0bcba5e0
kworker/0:0-4 [000] … 101.536074: rtos_queue_send_from_isr_failed: tstamp:3487232334 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 101.536076: rtos_queue_send_from_isr_failed: tstamp:3487232492 queue:0x0bcbc160
kworker/0:0-4 [000] … 101.536077: rtos_queue_send_from_isr_failed: tstamp:3488272094 queue:0x0bcb41f8
kworker/0:0-4 [000] … 101.536078: rtos_queue_send_from_isr_failed: tstamp:3488272254 queue:0x0bcb8a60
kworker/0:0-4 [000] … 101.536079: rtos_queue_send_from_isr_failed: tstamp:3488272416 queue:0x0bcba5e0
kworker/0:0-4 [000] … 101.536080: rtos_queue_send_from_isr_failed: tstamp:3488272575 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 101.536081: rtos_queue_send_from_isr_failed: tstamp:3488272732 queue:0x0bcbc160
kworker/0:0-4 [000] … 101.536082: rtos_queue_send_from_isr_failed: tstamp:3488427103 queue:0x0bcb41f8
kworker/0:0-4 [000] … 101.536083: rtos_queue_send_from_isr_failed: tstamp:3488427265 queue:0x0bcb8a60
kworker/0:0-4 [000] … 101.536085: rtos_queue_send_from_isr_failed: tstamp:3488427426 queue:0x0bcba5e0
kworker/0:0-4 [000] … 101.536086: rtos_queue_send_from_isr_failed: tstamp:3488427583 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 101.536087: rtos_queue_send_from_isr_failed: tstamp:3488427738 queue:0x0bcbc160
kworker/0:0-4 [000] … 101.536089: rtcpu_nvcsi_intr: tstamp:3488513012 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000000
kworker/0:0-4 [000] … 101.536091: rtcpu_nvcsi_intr: tstamp:3488528944 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:0-4 [000] … 101.536092: rtcpu_nvcsi_intr: tstamp:3488528944 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:0-4 [000] … 101.592099: rtos_queue_send_from_isr_failed: tstamp:3488824240 queue:0x0bcb41f8
kworker/0:0-4 [000] … 101.592105: rtos_queue_send_from_isr_failed: tstamp:3488824402 queue:0x0bcb8a60
kworker/0:0-4 [000] … 101.592106: rtos_queue_send_from_isr_failed: tstamp:3488824565 queue:0x0bcba5e0
kworker/0:0-4 [000] … 101.592107: rtos_queue_send_from_isr_failed: tstamp:3488824722 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 101.592108: rtos_queue_send_from_isr_failed: tstamp:3488824879 queue:0x0bcbc160
kworker/0:0-4 [000] … 101.592111: rtcpu_string: tstamp:3488825356 id:0x04010000 str:"Configuring VI GoS.
kworker/0:0-4 [000] … 101.592138: rtcpu_string: tstamp:3488825548 id:0x04010000 str:"VM GOS[#0 ] addr=0xc2100000
kworker/0:0-4 [000] … 101.592145: rtcpu_string: tstamp:3488825817 id:0x04010000 str:"VM GOS[#1 ] addr=0xc2101000
kworker/0:0-4 [000] … 101.592152: rtcpu_string: tstamp:3488826098 id:0x04010000 str:"VM GOS[#2 ] addr=0xc2102000
kworker/0:0-4 [000] … 101.592158: rtcpu_string: tstamp:3488826345 id:0x04010000 str:"VM GOS[#3 ] addr=0xc2103000
kworker/0:0-4 [000] … 101.592164: rtcpu_string: tstamp:3488826588 id:0x04010000 str:"VM GOS[#4 ] addr=0xc2104000
kworker/0:0-4 [000] … 101.592170: rtcpu_string: tstamp:3488826831 id:0x04010000 str:"VM GOS[#5 ] addr=0xc2105000
kworker/0:0-4 [000] … 101.592177: rtos_queue_peek_from_isr_failed: tstamp:3489993998 queue:0x0bcbcf78
kworker/0:0-4 [000] … 101.760038: rtos_queue_peek_from_isr_failed: tstamp:3494994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 101.872057: rtos_queue_send_from_isr_failed: tstamp:3498111669 queue:0x0bcb41f8
kworker/0:0-4 [000] … 101.872063: rtos_queue_send_from_isr_failed: tstamp:3498111845 queue:0x0bcb8a60
kworker/0:0-4 [000] … 101.872065: rtos_queue_send_from_isr_failed: tstamp:3498112007 queue:0x0bcba5e0
kworker/0:0-4 [000] … 101.872066: rtos_queue_send_from_isr_failed: tstamp:3498112165 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 101.872067: rtos_queue_send_from_isr_failed: tstamp:3498112322 queue:0x0bcbc160
kworker/0:0-4 [000] … 101.872070: rtcpu_vinotify_event: tstamp:3498353235 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4565459840 data:0x10000000
kworker/0:0-4 [000] … 101.872071: rtcpu_vinotify_event: tstamp:3498353414 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4565463680 data:0x31000001
kworker/0:0-4 [000] … 101.872072: rtcpu_vinotify_event: tstamp:3498353589 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4565464672 data:0x07020001
kworker/0:0-4 [000] … 101.928040: rtos_queue_peek_from_isr_failed: tstamp:3499994001 queue:0x0bcbcf78
kworker/0:0-4 [000] … 102.096050: rtos_queue_peek_from_isr_failed: tstamp:3504994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 102.264025: rtos_queue_peek_from_isr_failed: tstamp:3509994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 102.432048: rtos_queue_peek_from_isr_failed: tstamp:3514994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 102.544029: rtos_queue_peek_from_isr_failed: tstamp:3519994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 102.656045: rtos_queue_send_from_isr_failed: tstamp:3521873898 queue:0x0bcb41f8
kworker/0:0-4 [000] … 102.656051: rtos_queue_send_from_isr_failed: tstamp:3521874074 queue:0x0bcb8a60
kworker/0:0-4 [000] … 102.656052: rtos_queue_send_from_isr_failed: tstamp:3521874236 queue:0x0bcba5e0
kworker/0:0-4 [000] … 102.656053: rtos_queue_send_from_isr_failed: tstamp:3521874393 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 102.656054: rtos_queue_send_from_isr_failed: tstamp:3521874549 queue:0x0bcbc160
kworker/0:0-4 [000] … 102.656058: rtcpu_vinotify_event: tstamp:3522141508 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:5325853248 data:0x10000000
kworker/0:0-4 [000] … 102.656060: rtcpu_vinotify_event: tstamp:3522141689 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:5325857152 data:0x31000002
kworker/0:0-4 [000] … 102.712049: rtos_queue_peek_from_isr_failed: tstamp:3524994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 102.880029: rtos_queue_peek_from_isr_failed: tstamp:3529994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 103.048033: rtos_queue_peek_from_isr_failed: tstamp:3534994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 103.216067: rtos_queue_peek_from_isr_failed: tstamp:3539993995 queue:0x0bcbcf78
kworker/0:0-4 [000] … 103.384050: rtos_queue_peek_from_isr_failed: tstamp:3544993995 queue:0x0bcbcf78
kworker/0:0-4 [000] … 103.552055: rtos_queue_send_from_isr_failed: tstamp:3549901260 queue:0x0bcb41f8
kworker/0:0-4 [000] … 103.552062: rtos_queue_send_from_isr_failed: tstamp:3549901435 queue:0x0bcb8a60
kworker/0:0-4 [000] … 103.552063: rtos_queue_send_from_isr_failed: tstamp:3549901631 queue:0x0bcba5e0
kworker/0:0-4 [000] … 103.552065: rtos_queue_send_from_isr_failed: tstamp:3549901788 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 103.552066: rtos_queue_send_from_isr_failed: tstamp:3549901945 queue:0x0bcbc160
kworker/0:0-4 [000] … 103.552069: rtos_queue_peek_from_isr_failed: tstamp:3549993996 queue:0x0bcbcf78
kworker/0:0-4 [000] … 103.664275: rtos_queue_peek_from_isr_failed: tstamp:3554994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 103.832039: rtos_queue_peek_from_isr_failed: tstamp:3559994013 queue:0x0bcbcf78
kworker/0:0-4 [000] … 104.000030: rtos_queue_peek_from_isr_failed: tstamp:3564994009 queue:0x0bcbcf78
kworker/0:0-4 [000] … 104.168049: rtos_queue_peek_from_isr_failed: tstamp:3569994030 queue:0x0bcbcf78
kworker/0:0-4 [000] … 104.280018: rtos_queue_send_from_isr_failed: tstamp:3573779186 queue:0x0bcb41f8
kworker/0:0-4 [000] … 104.280024: rtos_queue_send_from_isr_failed: tstamp:3573779350 queue:0x0bcb8a60
kworker/0:0-4 [000] … 104.280025: rtos_queue_send_from_isr_failed: tstamp:3573779511 queue:0x0bcba5e0
kworker/0:0-4 [000] … 104.280026: rtos_queue_send_from_isr_failed: tstamp:3573779668 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 104.280028: rtos_queue_send_from_isr_failed: tstamp:3573779824 queue:0x0bcbc160
kworker/0:0-4 [000] … 104.336021: rtos_queue_peek_from_isr_failed: tstamp:3574994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 104.504037: rtos_queue_peek_from_isr_failed: tstamp:3579994031 queue:0x0bcbcf78
kworker/0:0-4 [000] … 104.560395: rtos_queue_send_from_isr_failed: tstamp:3582705165 queue:0x0bcb41f8
kworker/0:0-4 [000] … 104.560400: rtos_queue_send_from_isr_failed: tstamp:3582705342 queue:0x0bcb8a60
kworker/0:0-4 [000] … 104.560402: rtos_queue_send_from_isr_failed: tstamp:3582705503 queue:0x0bcba5e0
kworker/0:0-4 [000] … 104.560403: rtos_queue_send_from_isr_failed: tstamp:3582705659 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 104.560404: rtos_queue_send_from_isr_failed: tstamp:3582705815 queue:0x0bcbc160
kworker/0:0-4 [000] … 104.616442: rtos_queue_send_from_isr_failed: tstamp:3583254192 queue:0x0bcb41f8
kworker/0:0-4 [000] … 104.616448: rtos_queue_send_from_isr_failed: tstamp:3583254354 queue:0x0bcb8a60
kworker/0:0-4 [000] … 104.616449: rtos_queue_send_from_isr_failed: tstamp:3583254515 queue:0x0bcba5e0
kworker/0:0-4 [000] … 104.616451: rtos_queue_send_from_isr_failed: tstamp:3583254672 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 104.616452: rtos_queue_send_from_isr_failed: tstamp:3583254827 queue:0x0bcbc160
kworker/0:0-4 [000] … 104.616453: rtos_queue_send_from_isr_failed: tstamp:3584284180 queue:0x0bcb41f8
kworker/0:0-4 [000] … 104.616454: rtos_queue_send_from_isr_failed: tstamp:3584284344 queue:0x0bcb8a60
kworker/0:0-4 [000] … 104.616455: rtos_queue_send_from_isr_failed: tstamp:3584284503 queue:0x0bcba5e0
kworker/0:0-4 [000] … 104.616456: rtos_queue_send_from_isr_failed: tstamp:3584284660 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 104.616458: rtos_queue_send_from_isr_failed: tstamp:3584284817 queue:0x0bcbc160
kworker/0:0-4 [000] … 104.616459: rtos_queue_send_from_isr_failed: tstamp:3584443169 queue:0x0bcb41f8
kworker/0:0-4 [000] … 104.616460: rtos_queue_send_from_isr_failed: tstamp:3584443331 queue:0x0bcb8a60
kworker/0:0-4 [000] … 104.616461: rtos_queue_send_from_isr_failed: tstamp:3584443493 queue:0x0bcba5e0
kworker/0:0-4 [000] … 104.616462: rtos_queue_send_from_isr_failed: tstamp:3584443650 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 104.616463: rtos_queue_send_from_isr_failed: tstamp:3584443807 queue:0x0bcbc160
kworker/0:0-4 [000] … 104.616466: rtcpu_nvcsi_intr: tstamp:3584449546 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:0-4 [000] … 104.616468: rtcpu_nvcsi_intr: tstamp:3584449546 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:0-4 [000] … 104.616469: rtcpu_nvcsi_intr: tstamp:3584451035 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000000
kworker/0:0-4 [000] … 104.672077: rtos_queue_send_from_isr_failed: tstamp:3584828111 queue:0x0bcb41f8
kworker/0:0-4 [000] … 104.672083: rtos_queue_send_from_isr_failed: tstamp:3584828277 queue:0x0bcb8a60
kworker/0:0-4 [000] … 104.672084: rtos_queue_send_from_isr_failed: tstamp:3584828441 queue:0x0bcba5e0
kworker/0:0-4 [000] … 104.672085: rtos_queue_send_from_isr_failed: tstamp:3584828599 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 104.672087: rtos_queue_send_from_isr_failed: tstamp:3584828759 queue:0x0bcbc160
kworker/0:0-4 [000] … 104.672089: rtcpu_string: tstamp:3584829224 id:0x04010000 str:"Configuring VI GoS.
kworker/0:0-4 [000] … 104.672112: rtcpu_string: tstamp:3584829416 id:0x04010000 str:"VM GOS[#0 ] addr=0xc2100000
kworker/0:0-4 [000] … 104.672147: rtcpu_string: tstamp:3584829682 id:0x04010000 str:"VM GOS[#1 ] addr=0xc2101000
kworker/0:0-4 [000] … 104.672154: rtcpu_string: tstamp:3584829966 id:0x04010000 str:"VM GOS[#2 ] addr=0xc2102000
kworker/0:0-4 [000] … 104.672160: rtcpu_string: tstamp:3584830207 id:0x04010000 str:"VM GOS[#3 ] addr=0xc2103000
kworker/0:0-4 [000] … 104.672166: rtcpu_string: tstamp:3584830452 id:0x04010000 str:"VM GOS[#4 ] addr=0xc2104000
kworker/0:0-4 [000] … 104.672172: rtcpu_string: tstamp:3584830695 id:0x04010000 str:"VM GOS[#5 ] addr=0xc2105000
kworker/0:0-4 [000] … 104.672179: rtos_queue_peek_from_isr_failed: tstamp:3584994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 104.784043: rtos_queue_peek_from_isr_failed: tstamp:3589994031 queue:0x0bcbcf78
kworker/0:0-4 [000] … 104.952044: rtos_queue_peek_from_isr_failed: tstamp:3594994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 105.064027: rtos_queue_send_from_isr_failed: tstamp:3597778767 queue:0x0bcb41f8
kworker/0:0-4 [000] … 105.064033: rtos_queue_send_from_isr_failed: tstamp:3597778933 queue:0x0bcb8a60
kworker/0:0-4 [000] … 105.064034: rtos_queue_send_from_isr_failed: tstamp:3597779096 queue:0x0bcba5e0
kworker/0:0-4 [000] … 105.064035: rtos_queue_send_from_isr_failed: tstamp:3597779254 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 105.064036: rtos_queue_send_from_isr_failed: tstamp:3597779411 queue:0x0bcbc160
kworker/0:0-4 [000] … 105.064039: rtcpu_vinotify_event: tstamp:3597781422 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3459839552 data:0x10000000
kworker/0:0-4 [000] … 105.064066: rtcpu_vinotify_event: tstamp:3598076272 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3459852288 data:0x31000001
kworker/0:0-4 [000] … 105.064067: rtcpu_vinotify_event: tstamp:3598076426 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3459853248 data:0x07020001
kworker/0:0-4 [000] … 105.120072: rtos_queue_peek_from_isr_failed: tstamp:3599994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 105.288007: rtos_queue_peek_from_isr_failed: tstamp:3604994012 queue:0x0bcbcf78
kworker/0:0-4 [000] … 105.456020: rtos_queue_peek_from_isr_failed: tstamp:3609994009 queue:0x0bcbcf78
kworker/0:0-4 [000] … 105.624007: rtos_queue_peek_from_isr_failed: tstamp:3614994005 queue:0x0bcbcf78
kworker/0:0-4 [000] … 105.792059: rtos_queue_peek_from_isr_failed: tstamp:3619994005 queue:0x0bcbcf78
kworker/0:0-4 [000] … 105.848025: rtos_queue_send_from_isr_failed: tstamp:3621670873 queue:0x0bcb41f8
kworker/0:0-4 [000] … 105.848056: rtos_queue_send_from_isr_failed: tstamp:3621671037 queue:0x0bcb8a60
kworker/0:0-4 [000] … 105.848057: rtos_queue_send_from_isr_failed: tstamp:3621671199 queue:0x0bcba5e0
kworker/0:0-4 [000] … 105.848058: rtos_queue_send_from_isr_failed: tstamp:3621671356 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 105.848060: rtos_queue_send_from_isr_failed: tstamp:3621671513 queue:0x0bcbc160
kworker/0:0-4 [000] … 105.848063: rtcpu_vinotify_event: tstamp:3621864589 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4224389120 data:0x10000000
kworker/0:0-4 [000] … 105.848064: rtcpu_vinotify_event: tstamp:3621864746 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4224392992 data:0x31000002
kworker/0:0-4 [000] … 105.904010: rtos_queue_peek_from_isr_failed: tstamp:3624994013 queue:0x0bcbcf78
kworker/0:0-4 [000] … 106.076013: rtos_queue_peek_from_isr_failed: tstamp:3629994000 queue:0x0bcbcf78
kworker/0:0-4 [000] … 106.244007: rtos_queue_peek_from_isr_failed: tstamp:3634994031 queue:0x0bcbcf78
kworker/0:0-4 [000] … 106.412018: rtos_queue_peek_from_isr_failed: tstamp:3639993999 queue:0x0bcbcf78
kworker/0:1-727 [000] … 106.580039: rtos_queue_peek_from_isr_failed: tstamp:3644994001 queue:0x0bcbcf78
kworker/0:1-727 [000] … 106.692083: rtos_queue_send_from_isr_failed: tstamp:3649250503 queue:0x0bcb41f8
kworker/0:1-727 [000] … 106.692089: rtos_queue_send_from_isr_failed: tstamp:3649250666 queue:0x0bcb8a60
kworker/0:1-727 [000] … 106.692090: rtos_queue_send_from_isr_failed: tstamp:3649250831 queue:0x0bcba5e0
kworker/0:1-727 [000] … 106.692091: rtos_queue_send_from_isr_failed: tstamp:3649250988 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 106.692093: rtos_queue_send_from_isr_failed: tstamp:3649251144 queue:0x0bcbc160
kworker/0:1-727 [000] … 106.748068: rtos_queue_peek_from_isr_failed: tstamp:3649994009 queue:0x0bcbcf78
kworker/0:1-727 [000] … 106.916020: rtos_queue_peek_from_isr_failed: tstamp:3654994001 queue:0x0bcbcf78
kworker/0:1-727 [000] … 107.028002: rtos_queue_peek_from_isr_failed: tstamp:3659994030 queue:0x0bcbcf78
kworker/0:1-727 [000] … 107.196000: rtos_queue_peek_from_isr_failed: tstamp:3664994012 queue:0x0bcbcf78
kworker/0:1-727 [000] … 107.364000: rtos_queue_peek_from_isr_failed: tstamp:3669994009 queue:0x0bcbcf78
kworker/0:1-727 [000] … 107.476033: rtos_queue_send_from_isr_failed: tstamp:3672544048 queue:0x0bcb41f8
kworker/0:1-727 [000] … 107.476038: rtos_queue_send_from_isr_failed: tstamp:3672544215 queue:0x0bcb8a60
kworker/0:1-727 [000] … 107.476039: rtos_queue_send_from_isr_failed: tstamp:3672544377 queue:0x0bcba5e0
kworker/0:1-727 [000] … 107.476040: rtos_queue_send_from_isr_failed: tstamp:3672544536 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 107.476041: rtos_queue_send_from_isr_failed: tstamp:3672544694 queue:0x0bcbc160
kworker/0:1-727 [000] … 107.532036: rtos_queue_peek_from_isr_failed: tstamp:3674994011 queue:0x0bcbcf78
kworker/0:1-727 [000] … 107.588040: rtos_queue_send_from_isr_failed: tstamp:3675958428 queue:0x0bcb41f8
kworker/0:1-727 [000] … 107.588045: rtos_queue_send_from_isr_failed: tstamp:3675958625 queue:0x0bcb8a60
kworker/0:1-727 [000] … 107.588046: rtos_queue_send_from_isr_failed: tstamp:3675958790 queue:0x0bcba5e0
kworker/0:1-727 [000] … 107.588048: rtos_queue_send_from_isr_failed: tstamp:3675958947 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 107.588049: rtos_queue_send_from_isr_failed: tstamp:3675959103 queue:0x0bcbc160
kworker/0:1-727 [000] … 107.588050: rtos_queue_send_from_isr_failed: tstamp:3676383712 queue:0x0bcb41f8
kworker/0:1-727 [000] … 107.588051: rtos_queue_send_from_isr_failed: tstamp:3676383874 queue:0x0bcb8a60
kworker/0:1-727 [000] … 107.588052: rtos_queue_send_from_isr_failed: tstamp:3676384035 queue:0x0bcba5e0
kworker/0:1-727 [000] … 107.588053: rtos_queue_send_from_isr_failed: tstamp:3676384192 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 107.588054: rtos_queue_send_from_isr_failed: tstamp:3676384348 queue:0x0bcbc160
kworker/0:1-727 [000] … 107.588055: rtos_queue_send_from_isr_failed: tstamp:3677417418 queue:0x0bcb41f8
kworker/0:1-727 [000] … 107.588057: rtos_queue_send_from_isr_failed: tstamp:3677417580 queue:0x0bcb8a60
kworker/0:1-727 [000] … 107.588058: rtos_queue_send_from_isr_failed: tstamp:3677417742 queue:0x0bcba5e0
kworker/0:1-727 [000] … 107.588059: rtos_queue_send_from_isr_failed: tstamp:3677417899 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 107.588060: rtos_queue_send_from_isr_failed: tstamp:3677418056 queue:0x0bcbc160
kworker/0:1-727 [000] … 107.588061: rtos_queue_send_from_isr_failed: tstamp:3677576767 queue:0x0bcb41f8
kworker/0:1-727 [000] … 107.588062: rtos_queue_send_from_isr_failed: tstamp:3677576929 queue:0x0bcb8a60
kworker/0:1-727 [000] … 107.588063: rtos_queue_send_from_isr_failed: tstamp:3677577090 queue:0x0bcba5e0
kworker/0:1-727 [000] … 107.588064: rtos_queue_send_from_isr_failed: tstamp:3677577248 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 107.588100: rtos_queue_send_from_isr_failed: tstamp:3677577404 queue:0x0bcbc160
kworker/0:1-727 [000] … 107.588103: rtcpu_nvcsi_intr: tstamp:3677584145 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:1-727 [000] … 107.588104: rtcpu_nvcsi_intr: tstamp:3677584145 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000100
kworker/0:1-727 [000] … 107.588105: rtcpu_nvcsi_intr: tstamp:3677585379 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000000
kworker/0:1-727 [000] … 107.644060: rtos_queue_send_from_isr_failed: tstamp:3677970163 queue:0x0bcb41f8
kworker/0:1-727 [000] … 107.644068: rtos_queue_send_from_isr_failed: tstamp:3677970328 queue:0x0bcb8a60
kworker/0:1-727 [000] … 107.644070: rtos_queue_send_from_isr_failed: tstamp:3677970490 queue:0x0bcba5e0
kworker/0:1-727 [000] … 107.644071: rtos_queue_send_from_isr_failed: tstamp:3677970648 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 107.644072: rtos_queue_send_from_isr_failed: tstamp:3677970805 queue:0x0bcbc160
kworker/0:1-727 [000] … 107.644076: rtcpu_string: tstamp:3677971276 id:0x04010000 str:"Configuring VI GoS.
kworker/0:1-727 [000] … 107.644090: rtcpu_string: tstamp:3677971468 id:0x04010000 str:"VM GOS[#0 ] addr=0xc2100000
kworker/0:1-727 [000] … 107.644096: rtcpu_string: tstamp:3677971736 id:0x04010000 str:"VM GOS[#1 ] addr=0xc2101000
kworker/0:1-727 [000] … 107.644100: rtcpu_string: tstamp:3677972018 id:0x04010000 str:"VM GOS[#2 ] addr=0xc2102000
kworker/0:1-727 [000] … 107.644104: rtcpu_string: tstamp:3677972261 id:0x04010000 str:"VM GOS[#3 ] addr=0xc2103000
kworker/0:1-727 [000] … 107.644108: rtcpu_string: tstamp:3677972504 id:0x04010000 str:"VM GOS[#4 ] addr=0xc2104000
kworker/0:1-727 [000] … 107.644113: rtcpu_string: tstamp:3677972749 id:0x04010000 str:"VM GOS[#5 ] addr=0xc2105000
kworker/0:1-727 [000] … 107.644118: rtos_queue_send_from_isr_failed: tstamp:3679233594 queue:0x0bcb41f8
kworker/0:1-727 [000] … 107.644119: rtos_queue_send_from_isr_failed: tstamp:3679233759 queue:0x0bcb8a60
kworker/0:1-727 [000] … 107.644120: rtos_queue_send_from_isr_failed: tstamp:3679233922 queue:0x0bcba5e0
kworker/0:1-727 [000] … 107.644121: rtos_queue_send_from_isr_failed: tstamp:3679234079 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 107.644123: rtos_queue_send_from_isr_failed: tstamp:3679234236 queue:0x0bcbc160
kworker/0:1-727 [000] … 107.644124: rtos_queue_send_from_isr_failed: tstamp:3679401630 queue:0x0bcb41f8
kworker/0:1-727 [000] … 107.644125: rtos_queue_send_from_isr_failed: tstamp:3679401857 queue:0x0bcb8a60
kworker/0:1-727 [000] … 107.644126: rtos_queue_send_from_isr_failed: tstamp:3679402077 queue:0x0bcba5e0
kworker/0:1-727 [000] … 107.644127: rtos_queue_send_from_isr_failed: tstamp:3679402296 queue:0x0bcbb3a0
kworker/0:1-727 [000] … 107.644128: rtos_queue_send_from_isr_failed: tstamp:3679402514 queue:0x0bcbc160
kworker/0:1-727 [000] … 107.704081: rtos_queue_peek_from_isr_failed: tstamp:3679994035 queue:0x0bcbcf78
kworker/0:1-727 [000] … 107.872032: rtos_queue_peek_from_isr_failed: tstamp:3684994034 queue:0x0bcbcf78
kworker/0:1-727 [000] … 107.984013: rtos_queue_peek_from_isr_failed: tstamp:3689994035 queue:0x0bcbcf78
kworker/0:1-727 [000] … 108.152011: rtos_queue_peek_from_isr_failed: tstamp:3694994079 queue:0x0bcbcf78
kworker/0:1-727 [000] … 108.320014: rtos_queue_peek_from_isr_failed: tstamp:3699994070 queue:0x0bcbcf78
kworker/0:1-727 [000] … 108.488014: rtos_queue_peek_from_isr_failed: tstamp:3704994082 queue:0x0bcbcf78
kworker/0:1-727 [000] … 108.656021: rtos_queue_peek_from_isr_failed: tstamp:3709994071 queue:0x0bcbcf78
kworker/0:1-727 [000] … 108.824014: rtos_queue_peek_from_isr_failed: tstamp:3714994073 queue:0x0bcbcf78
kworker/0:1-727 [000] … 108.992002: rtos_queue_peek_from_isr_failed: tstamp:3719994071 queue:0x0bcbcf78
kworker/0:1-727 [000] … 109.104006: rtos_queue_peek_from_isr_failed: tstamp:3724994071 queue:0x0bcbcf78
kworker/0:1-727 [000] … 109.272015: rtos_queue_peek_from_isr_failed: tstamp:3729994071 queue:0x0bcbcf78
kworker/0:1-727 [000] … 109.440001: rtos_queue_peek_from_isr_failed: tstamp:3734994074 queue:0x0bcbcf78
kworker/0:1-727 [000] … 109.608007: rtos_queue_peek_from_isr_failed: tstamp:3739994069 queue:0x0bcbcf78
kworker/0:1-727 [000] … 109.776002: rtos_queue_peek_from_isr_failed: tstamp:3744994070 queue:0x0bcbcf78
kworker/0:1-727 [000] … 109.944004: rtos_queue_peek_from_isr_failed: tstamp:3749994070 queue:0x0bcbcf78
kworker/0:1-727 [000] … 110.112003: rtos_queue_peek_from_isr_failed: tstamp:3754994070 queue:0x0bcbcf78
kworker/0:1-727 [000] … 110.224010: rtos_queue_peek_from_isr_failed: tstamp:3759994070 queue:0x0bcbcf78
kworker/0:1-727 [000] … 110.392103: rtos_queue_peek_from_isr_failed: tstamp:3764994068 queue:0x0bcbcf78
kworker/0:1-727 [000] … 110.560018: rtos_queue_peek_from_isr_failed: tstamp:3769994068 queue:0x0bcbcf78
kworker/0:1-727 [000] … 110.728005: rtos_queue_peek_from_isr_failed: tstamp:3774994073 queue:0x0bcbcf78
kworker/0:1-727 [000] … 110.896015: rtos_queue_peek_from_isr_failed: tstamp:3779994074 queue:0x0bcbcf78
kworker/0:1-727 [000] … 111.064031: rtos_queue_peek_from_isr_failed: tstamp:3784994082 queue:0x0bcbcf78
kworker/0:1-727 [000] … 111.232011: rtos_queue_peek_from_isr_failed: tstamp:3789994070 queue:0x0bcbcf78
kworker/0:1-727 [000] … 111.344012: rtos_queue_peek_from_isr_failed: tstamp:3794994070 queue:0x0bcbcf78
kworker/0:1-727 [000] … 111.512076: rtos_queue_peek_from_isr_failed: tstamp:3799994066 queue:0x0bcbcf78
kworker/0:1-727 [000] … 111.680031: rtos_queue_peek_from_isr_failed: tstamp:3804994078 queue:0x0bcbcf78
kworker/0:1-727 [000] … 111.848006: rtos_queue_peek_from_isr_failed: tstamp:3809994066 queue:0x0bcbcf78
kworker/0:0-4 [000] … 112.016062: rtos_queue_peek_from_isr_failed: tstamp:3814994062 queue:0x0bcbcf78
kworker/0:0-4 [000] … 112.184008: rtos_queue_peek_from_isr_failed: tstamp:3819994070 queue:0x0bcbcf78
kworker/0:0-4 [000] … 112.352006: rtos_queue_peek_from_isr_failed: tstamp:3824994066 queue:0x0bcbcf78
kworker/0:0-4 [000] … 112.464046: rtos_queue_peek_from_isr_failed: tstamp:3829994070 queue:0x0bcbcf78
kworker/0:0-4 [000] … 112.632016: rtos_queue_peek_from_isr_failed: tstamp:3834994068 queue:0x0bcbcf78
kworker/0:0-4 [000] … 112.800006: rtos_queue_peek_from_isr_failed: tstamp:3839994070 queue:0x0bcbcf78
kworker/0:0-4 [000] … 112.967998: rtos_queue_peek_from_isr_failed: tstamp:3844994070 queue:0x0bcbcf78
kworker/0:0-4 [000] … 113.136007: rtos_queue_peek_from_isr_failed: tstamp:3849994073 queue:0x0bcbcf78
kworker/0:0-4 [000] … 113.304008: rtos_queue_peek_from_isr_failed: tstamp:3854677744 queue:0x0bcbcf78
What’s the sensor output size? Did you configure as 3 lanes?
ray_lo
June 23, 2020, 4:19am
8
Yes, you can see our setting in DT.
The size is 8000x6016.
Could you check the “dmesg | grep -i iso”
And it’s better to have smaller resolution to try.
ray_lo
June 23, 2020, 5:41am
10
We can capture image on Tx2 with this setting.
So I think this resolution should be fine on Xavier.
root@localhost:~# dmesg | grep -i iso
[ 0.792607] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.842101] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.842819] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.843423] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[ 0.846432] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 1.483429] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=6250000, vi_iso_bw=1875000, max_bw=6250000
[ 1.640173] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
Did you run the v4l2-ctl to capture the data?
ray_lo
June 23, 2020, 6:52am
12
I tried to use following command and get same trace log.
v4l2-ctl -d /dev/video0 --set-fmt-video=width=8000,height=6016,pixelformat=RAW10 --stream-mmap --stream-count=1 --stream-to=image1.raw0
Hi ShaneCCC,
In NVIDIA Jetson AGX Xavier Developer Kit Carrier Board Specification (version 2.0, release at January 14, 2020)
Section 3.2, I found a note say that the carrier board does NOT supported C-PHY.
Here’s the screen shot of that section:
But in this post, it said C-PHY has been validated:
hello CalmCar,
you might check the Jetson AGX Xavier Software Features for validate use-cases.
for more details, please also access [Xavier Series (SoC) Technical Reference Manual] from Jetson Download Center ,
please refer to [Multimedia Complex]-> [Camera Subsystem]-> [Image Data Types],
and check the [Performance] session for the NVCSI maximum bandwidth.
BTW, we had also validate CPHY sensor with 5488x4112 at 30-fps.
please refer to
$TOP/public_sources/hardware/nvidia/platform/t19x/com…
Combine these information, does it mean that module itself had validated C-PHY but carrier board did not so I can’t use carrier board to test C-PHY?
kayccc
July 9, 2020, 6:22am
16
Hence we are closing this topic. If need further support, please open a new one. Thanks
HI ray_lo,
Has issue been clarified and fixed?
Any result can be shared?
