Xavier cannot enter into the ubuntu system
Hello, when I turn on my Jatson Xavier I found it cannot enter into the ubuntu system, and when the command “Started User Manager for UID 120” appear the process cannot be continued, and the screen flash all the time. I tried to enter into the tty but because of the flash I cannot input anything through the keyboard. And I cannot enter into the recovery mode through any shortcut. Do you have any experience or solution for this issue?
This should be posted in the Jetson Xavier category. I will move it over for you.
Best,
Tom K
Press the button on the board to enter the recovery mode.
hello, just press the recovery button?
If the board is already powered on, then
press and hold recovery button → press reset button → release reset → release rec.
If the board is not yet powered on, then replace above “reset” to “power button”.
