Sorry to reply late, last week was holiday in my country.
I’m not sure which information you exactly want, so I copy all thing about ‘dmesg’.
[ 4.163989] Actions configured
[ 4.164051] Initializing XFRM netlink socket
[ 4.164557] NET: Registered protocol family 10
[ 4.165207] NET: Registered protocol family 17
[ 4.165220] NET: Registered protocol family 15
[ 4.165266] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.165357] Bluetooth: RFCOMM socket layer initialized
[ 4.165371] Bluetooth: RFCOMM ver 1.11
[ 4.165376] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.165380] Bluetooth: HIDP socket layer initialized
[ 4.165394] 9pnet: Installing 9P2000 support
[ 4.165427] Key type dns_resolver registered
[ 4.165669] Registered cp15_barrier emulation handler
[ 4.165691] Registered setend emulation handler
[ 4.167137] registered taskstats version 1
[ 4.167544] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[ 4.168538] OF: PCI: host bridge /pcie@14180000 ranges:
[ 4.168557] OF: PCI: IO 0x38100000…0x381fffff -> 0x38100000
[ 4.168565] OF: PCI: MEM 0x1b40000000…0x1bffffffff -> 0x40000000
[ 4.168570] OF: PCI: MEM 0x1800000000…0x1b3fffffff -> 0x1800000000
[ 4.196569] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 4.196573] Extcon HDMI: HPD enabled
[ 4.196592] tegradc 15200000.nvdisplay: hdmi: plugged
[ 4.683618] tegra-pcie-dw 14180000.pcie: link is down
[ 4.683784] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 4.683791] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 4.683798] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 4.683805] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[ 4.683830] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[ 4.683864] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 4.684032] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 4.684272] iommu: Adding device 0000:00:00.0 to group 62
[ 4.684605] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 4.684627] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 4.684854] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 4.684861] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
[ 4.684957] aer 0000:00:00.0:pcie002: service driver aer loaded
[ 4.685110] pcie_pme 0000:00:00.0:pcie001: unloading service driver pcie_pme
[ 4.685152] aer 0000:00:00.0:pcie002: unloading service driver aer
[ 4.685227] pci_bus 0000:01: busn_res: [bus 01-ff] is released
[ 4.685371] iommu: Removing device 0000:00:00.0 from group 62
[ 4.685448] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[ 4.687148] tegra-pcie-dw 14180000.pcie: PCIe link is not up…!
[ 4.687749] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[ 4.688584] OF: PCI: host bridge /pcie@14100000 ranges:
[ 4.688600] OF: PCI: IO 0x30100000…0x301fffff -> 0x30100000
[ 4.688608] OF: PCI: MEM 0x1230000000…0x123fffffff -> 0x40000000
[ 4.688619] OF: PCI: MEM 0x1200000000…0x122fffffff -> 0x1200000000
[ 4.799553] tegra-pcie-dw 14100000.pcie: link is up
[ 4.799811] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[ 4.799817] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 4.799825] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 4.799830] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[ 4.799834] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[ 4.799862] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 4.800008] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 4.800192] iommu: Adding device 0001:00:00.0 to group 62
[ 4.800518] pci 0001:01:00.0: [1b4b:9171] type 00 class 0x010601
[ 4.800623] pci 0001:01:00.0: reg 0x10: [io 0x8000-0x8007]
[ 4.800686] pci 0001:01:00.0: reg 0x14: [io 0x8040-0x8043]
[ 4.800748] pci 0001:01:00.0: reg 0x18: [io 0x8100-0x8107]
[ 4.800809] pci 0001:01:00.0: reg 0x1c: [io 0x8140-0x8143]
[ 4.800871] pci 0001:01:00.0: reg 0x20: [io 0x800000-0x80000f]
[ 4.800934] pci 0001:01:00.0: reg 0x24: [mem 0x00900000-0x009001ff]
[ 4.800996] pci 0001:01:00.0: reg 0x30: [mem 0xd0000000-0xd000ffff pref]
[ 4.801324] pci 0001:01:00.0: PME# supported from D3hot
[ 4.801532] iommu: Adding device 0001:01:00.0 to group 63
[ 4.813229] pci 0001:00:00.0: BAR 14: assigned [mem 0x1230000000-0x12300fffff]
[ 4.813235] pci 0001:00:00.0: BAR 13: assigned [io 0x100000-0x100fff]
[ 4.813243] pci 0001:01:00.0: BAR 6: assigned [mem 0x1230000000-0x123000ffff pref]
[ 4.813247] pci 0001:01:00.0: BAR 5: assigned [mem 0x1230010000-0x12300101ff]
[ 4.813312] pci 0001:01:00.0: BAR 4: assigned [io 0x100000-0x10000f]
[ 4.813372] pci 0001:01:00.0: BAR 0: assigned [io 0x100010-0x100017]
[ 4.813437] pci 0001:01:00.0: BAR 2: assigned [io 0x100018-0x10001f]
[ 4.813515] pci 0001:01:00.0: BAR 1: assigned [io 0x100020-0x100023]
[ 4.813578] pci 0001:01:00.0: BAR 3: assigned [io 0x100024-0x100027]
[ 4.813640] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 4.813645] pci 0001:00:00.0: bridge window [io 0x100000-0x100fff]
[ 4.813652] pci 0001:00:00.0: bridge window [mem 0x1230000000-0x12300fffff]
[ 4.813671] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 4.813766] pci 0001:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 4.814015] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[ 4.814019] pci 0001:01:00.0: Signaling PME through PCIe PME interrupt
[ 4.814026] pcie_pme 0001:00:00.0:pcie001: service driver pcie_pme loaded
[ 4.814152] aer 0001:00:00.0:pcie002: service driver aer loaded
[ 4.814511] ahci 0001:01:00.0: version 3.0
[ 4.814946] ahci 0001:01:00.0: AHCI 0001.0000 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 4.814953] ahci 0001:01:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 4.815587] scsi host1: ahci
[ 4.815889] ata1: SATA max UDMA/133 abar m512@0x1230010000 port 0x1230010100 irq 564
[ 4.815998] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[ 4.816752] OF: PCI: host bridge /pcie@14140000 ranges:
[ 4.816767] OF: PCI: IO 0x34100000…0x341fffff -> 0x34100000
[ 4.816782] OF: PCI: MEM 0x12b0000000…0x12bfffffff -> 0x40000000
[ 4.816788] OF: PCI: MEM 0x1280000000…0x12afffffff -> 0x1280000000
[ 5.131013] ata1: SATA link down (SStatus 0 SControl 300)
[ 5.332076] tegra-pcie-dw 14140000.pcie: link is down
[ 5.332255] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0003:00
[ 5.332262] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 5.332269] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 5.332277] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[ 5.332280] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[ 5.332309] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 5.332477] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.332645] iommu: Adding device 0003:00:00.0 to group 64
[ 5.332912] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 5.332934] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.333145] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.333156] pcie_pme 0003:00:00.0:pcie001: service driver pcie_pme loaded
[ 5.333260] aer 0003:00:00.0:pcie002: service driver aer loaded
[ 5.333410] pcie_pme 0003:00:00.0:pcie001: unloading service driver pcie_pme
[ 5.333452] aer 0003:00:00.0:pcie002: unloading service driver aer
[ 5.333511] pci_bus 0003:01: busn_res: [bus 01-ff] is released
[ 5.333575] iommu: Removing device 0003:00:00.0 from group 64
[ 5.333659] pci_bus 0003:00: busn_res: [bus 00-ff] is released
[ 5.334848] tegra-pcie-dw 14140000.pcie: PCIe link is not up…!
[ 5.335430] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 5.336527] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 5.336542] OF: PCI: IO 0x3a100000…0x3a1fffff -> 0x3a100000
[ 5.336550] OF: PCI: MEM 0x1f40000000…0x1fffffffff -> 0x40000000
[ 5.336556] OF: PCI: MEM 0x1c00000000…0x1f3fffffff -> 0x1c00000000
[ 5.847740] tegra-pcie-dw 141a0000.pcie: link is down
[ 5.847906] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 5.847913] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 5.847919] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 5.847925] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 5.847929] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 5.847953] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 5.848088] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.848266] iommu: Adding device 0005:00:00.0 to group 64
[ 5.848515] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 5.848535] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.848752] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.848759] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 5.848889] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 5.849045] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[ 5.849107] aer 0005:00:00.0:pcie002: unloading service driver aer
[ 5.849166] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 5.849291] iommu: Removing device 0005:00:00.0 from group 64
[ 5.849363] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 5.850715] tegra-pcie-dw 141a0000.pcie: PCIe link is not up…!
[ 5.864277] tegra-cbb 14040000.cv-noc: noc_secure_irq = 99, noc_nonsecure_irq = 98>
[ 5.868692] tegra194-isp5 14800000.isp: initialized
[ 5.874462] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 5.877109] tegra194-vi5 15c10000.vi: initialized
[ 5.881075] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@0/endpoint.
[ 5.881081] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@1/endpoint.
[ 5.883218] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 5.883223] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 5.883785] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 5.883806] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 5.883862] tegradc 15210000.nvdisplay: DT parsed successfully
[ 5.883884] tegradc 15210000.nvdisplay: Display dc.ffffff800fcd0000 registered with id=1
[ 5.885209] tegradc 15210000.nvdisplay: vblank syncpt # 15 for dc 1
[ 5.885214] tegradc 15210000.nvdisplay: vpulse3 syncpt # 16 for dc 1
[ 5.887086] tegra-xusb 3610000.xhci: extcon 0: ffffffc3d9b1d400 id
[ 5.887686] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 5.887717] tegra-xudc-new 3550000.xudc: device count: 1
[ 5.888575] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 5.888582] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 5.889177] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 5.889358] tegra-xudc-new 3550000.xudc: entering ELPG
[ 5.889600] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 5.889994] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 5.890023] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.890036] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 5.890730] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 5.890753] tegra-xusb 3610000.xhci: irq 473, io mem 0x03610000
[ 5.890866] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.890871] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.890874] usb usb1: Product: xHCI Host Controller
[ 5.890878] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 5.890881] usb usb1: SerialNumber: 3610000.xhci
[ 5.891135] hub 1-0:1.0: USB hub found
[ 5.891162] hub 1-0:1.0: 4 ports detected
[ 5.891366] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.891373] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 5.891379] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 5.891585] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 5.891590] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.891594] usb usb2: Product: xHCI Host Controller
[ 5.891597] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 5.891600] usb usb2: SerialNumber: 3610000.xhci
[ 5.891868] hub 2-0:1.0: USB hub found
[ 5.891891] hub 2-0:1.0: 4 ports detected
[ 5.894894] tegradc 15210000.nvdisplay: probed
[ 5.895049] tegradc 15210000.nvdisplay: fb registered
[ 5.898305] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 5.898312] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 5.898320] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 5.898332] tegradc 15210000.nvdisplay: blank - powerdown
[ 5.898358] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 5.898362] Extcon DP: HPD disabled
[ 5.898364] hpd: hpd_switch 0
[ 5.898368] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 5.898375] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 5.898380] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.898522] tegradc 15220000.nvdisplay: disp2 connected to head2->/host1x/sor1
[ 5.898555] tegradc 15220000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 5.898653] tegradc 15220000.nvdisplay: DT parsed successfully
[ 5.898680] tegradc 15220000.nvdisplay: Display dc.ffffff800ff50000 registered with id=2
[ 5.898836] tegradc 15220000.nvdisplay: vblank syncpt # 17 for dc 2
[ 5.898842] tegradc 15220000.nvdisplay: vpulse3 syncpt # 18 for dc 2
[ 5.906128] tegradc 15220000.nvdisplay: probed
[ 5.906300] tegradc 15220000.nvdisplay: fb registered
[ 5.909541] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 5.909546] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 5.909553] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 5.909561] tegradc 15220000.nvdisplay: blank - powerdown
[ 5.909569] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 5.909572] Extcon DP: HPD disabled
[ 5.909574] hpd: hpd_switch 0
[ 5.909577] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 5.909584] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 5.909589] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.964451] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 5.964795] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 5.964962] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 5.965102] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 5.965433] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 5.965487] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 5.965642] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (71)
[ 5.965646] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 5.966610] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 5.966998] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 5.967066] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 5.967180] input: gpio-keys as /devices/gpio-keys/input/input5
[ 6.000704] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:16 UTC (946688416)
[ 6.001208] mmcblk mmc0:0001: Card claimed for testing.
[ 6.043976] bpmp: mounted debugfs mirror
[ 6.049970] vdd-1v8-cvb: disabling
[ 6.049976] vdd-1v8-sd: disabling
[ 6.049979] vdd-epb-1v0: disabling
[ 6.049982] avdd-cam-2v8: disabling
[ 6.049986] vdd-sata-1v5: disabling
[ 6.049989] vdd-3v3-slt: disabling
[ 6.049992] vdd-fan: disabling
[ 6.049995] vdd_sys_en: disabling
[ 6.050005] ALSA device list:
[ 6.050009] #0: tegra-hda-galen-t194 at 0x3518000 irq 70
[ 6.050012] #1: tegra-snd-t19x-mobile-rt565x
[ 6.051669] Freeing unused kernel memory: 8576K
[ 6.083942] Root device found: mmcblk0p1
[ 6.085020] Found dev node: /dev/mmcblk0p1
[ 6.140211] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.141030] Rootfs mounted over mmcblk0p1
[ 6.159015] Switching from initrd to actual rootfs
[ 6.215541] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 6.237082] usb 1-2: New USB device found, idVendor=0bda, idProduct=8176
[ 6.237092] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.237096] usb 1-2: Product: 802.11n WLAN Adapter
[ 6.237099] usb 1-2: Manufacturer: Realtek
[ 6.237119] usb 1-2: SerialNumber: 00e04c000001
[ 6.253026] systemd[1]: System time before build time, advancing clock.
[ 6.276440] ip_tables: © 2000-2006 Netfilter Core Team
[ 6.279473] cgroup: cgroup2: unknown option “nsdelegate”
[ 6.286074] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 6.286722] systemd[1]: Detected architecture arm64.
[ 6.292803] systemd[1]: Set hostname to .
[ 6.355550] usb 1-4: new full-speed USB device number 3 using tegra-xusb
[ 6.379383] usb 1-4: New USB device found, idVendor=046d, idProduct=c534
[ 6.379392] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.379396] usb 1-4: Product: USB Receiver
[ 6.379399] usb 1-4: Manufacturer: Logitech
[ 6.382185] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-4/1-4:1.0/0003:046D:C534.0001/input/input6
[ 6.394417] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 6.394429] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.440239] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-4/input0
[ 6.443717] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-4/1-4:1.1/0003:046D:C534.0002/input/input7
[ 6.503999] hid-generic 0003:046D:C534.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-4/input1
[ 6.531028] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.533838] systemd[1]: Created slice User and Session Slice.
[ 6.534012] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.534820] systemd[1]: Created slice System Slice.
[ 6.534888] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.535255] systemd[1]: Listening on Journal Socket.
[ 6.538049] systemd[1]: Mounting POSIX Message Queue File System…
[ 6.541545] systemd[1]: Starting Set the console keyboard layout…
[ 6.567476] gpio tegra-gpio wake44 for gpio=192(Y:0)
[ 6.577525] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.626758] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 6.876679] systemd-journald[2479]: Received request to flush runtime journal from PID 1
[ 7.661427] random: crng init done
[ 7.661564] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.687981] using random self ethernet address
[ 7.688195] using random host ethernet address
[ 8.246485] Mass Storage Function, version: 2009/09/11
[ 8.246496] LUN: removable file: (no medium)
[ 8.253199] using random self ethernet address
[ 8.253367] using random host ethernet address
[ 8.274922] rndis0: HOST MAC 1e:49:64:d3:5e:5c
[ 8.275184] rndis0: MAC 1e:49:64:d3:5e:5d
[ 8.276327] usb0: HOST MAC 1e:49:64:d3:5e:5e
[ 8.276361] usb0: MAC 1e:49:64:d3:5e:5f
[ 8.276379] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 8.277135] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 8.277150] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.277189] tegra-xudc-new 3550000.xudc: entering ELPG
[ 8.277381] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 8.277401] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 8.277843] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 8.277865] tegra-xudc-new 3550000.xudc: entering ELPG
[ 8.278040] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 8.283070] l4tbr0: port 1(rndis0) entered blocking state
[ 8.283078] l4tbr0: port 1(rndis0) entered disabled state
[ 8.283247] device rndis0 entered promiscuous mode
[ 8.289994] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 8.296157] l4tbr0: port 2(usb0) entered blocking state
[ 8.296165] l4tbr0: port 2(usb0) entered disabled state
[ 8.296299] device usb0 entered promiscuous mode
[ 8.314222] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.580160] ras_fhi_disable: FHI 482 disabled
[ 8.580649] CPU4: shutdown
[ 8.599764] psci: Retrying again to check for CPU kill
[ 8.599778] psci: CPU4 killed.
[ 8.677269] ras_fhi_disable: FHI 483 disabled
[ 8.691659] CPU5: shutdown
[ 8.691675] psci: CPU5 killed.
[ 8.741789] ras_fhi_disable: FHI 484 disabled
[ 8.743380] CPU6: shutdown
[ 8.759592] psci: Retrying again to check for CPU kill
[ 8.759647] psci: CPU6 killed.
[ 8.797022] ras_fhi_disable: FHI 485 disabled
[ 8.805681] CPU7: shutdown
[ 8.823562] psci: Retrying again to check for CPU kill
[ 8.823578] psci: CPU7 killed.
[ 8.825403] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 9.035017] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.276692] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 9.283436] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.066496] Wake76 for irq=199
[ 10.066508] Wake77 for irq=199
[ 10.066511] Wake78 for irq=199
[ 10.066514] Wake79 for irq=199
[ 10.066517] Wake80 for irq=199
[ 10.066519] Wake81 for irq=199
[ 10.066522] Wake82 for irq=199
[ 10.066591] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 10.066595] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 10.156297] rtl8192cu: Chip version 0x10
[ 10.167904] usb usb2: usb_suspend_both: status 0
[ 10.205721] rtl8192cu: Board Type 0
[ 10.205863] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 10.206052] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[ 10.206686] ieee80211 phy0: Selected rate control algorithm ‘rtl_rc’
[ 10.207570] usbcore: registered new interface driver rtl8192cu
[ 10.214597] usbcore: registered new interface driver rtl8xxxu
[ 10.249017] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.250777] rtl8192cu: MAC auto ON okay!
[ 10.269924] rtl8192cu: Tx queue select: 0x05
[ 10.668120] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.751431] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 12.570553] zram: Added device: zram0
[ 12.575354] zram: Added device: zram1
[ 12.576032] zram: Added device: zram2
[ 12.576414] zram: Added device: zram3
[ 12.601787] zram0: detected capacity change from 0 to 2072862720
[ 12.623381] Adding 2024276k swap on /dev/zram0. Priority:5 extents:1 across:2024276k SS
[ 12.626448] zram1: detected capacity change from 0 to 2072862720
[ 12.642860] Adding 2024276k swap on /dev/zram1. Priority:5 extents:1 across:2024276k SS
[ 12.647108] zram2: detected capacity change from 0 to 2072862720
[ 12.662696] Adding 2024276k swap on /dev/zram2. Priority:5 extents:1 across:2024276k SS
[ 12.666025] zram3: detected capacity change from 0 to 2072862720
[ 12.678490] Adding 2024276k swap on /dev/zram3. Priority:5 extents:1 across:2024276k SS
[ 13.514069] tegradc 15200000.nvdisplay: blank - powerdown
[ 13.575875] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 13.575880] Extcon AUX2(HDMI) disable
[ 13.609016] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 13.612595] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 13.618367] tegradc 15200000.nvdisplay: unblank
[ 13.622869] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 13.623039] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 13.631729] Parent Clock set for DC plld3
[ 13.637462] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 13.639021] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 13.639037] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 13.675712] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 13.675716] Extcon AUX2(HDMI) enable
[ 13.679125] tegradc 15200000.nvdisplay: unblank
[ 13.679136] tegradc 15210000.nvdisplay: blank - powerdown
[ 13.679143] tegradc 15220000.nvdisplay: blank - powerdown
[ 39.565835] wlan0: authenticate with 6c:71:0d:fd:46:c0
[ 39.577272] wlan0: send auth to 6c:71:0d:fd:46:c0 (try 1/3)
[ 39.578656] wlan0: authenticated
[ 39.583620] wlan0: associate with 6c:71:0d:fd:46:c0 (try 1/3)
[ 39.611958] wlan0: RX AssocResp from 6c:71:0d:fd:46:c0 (capab=0x1431 status=0 aid=2)
[ 39.628467] wlan0: associated
[ 39.629631] wlan0: Limiting TX power to 17 (20 - 3) dBm as advertised by 6c:71:0d:fd:46:c0
[ 39.639334] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 39.976839] tegradc 15200000.nvdisplay: blank - powerdown
[ 40.040212] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 40.040218] Extcon AUX2(HDMI) disable
[ 40.067490] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 40.068804] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 40.069068] tegradc 15210000.nvdisplay: blank - powerdown
[ 40.069181] tegradc 15220000.nvdisplay: blank - powerdown
[ 40.189879] tegradc 15200000.nvdisplay: blank - powerdown
[ 40.189926] tegradc 15200000.nvdisplay: unblank
[ 40.190901] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 40.191093] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 40.194289] Parent Clock set for DC plld3
[ 40.202631] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 40.204105] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 40.204113] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 40.241982] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 40.241985] Extcon AUX2(HDMI) enable
[ 40.243581] tegradc 15200000.nvdisplay: unblank
[ 40.243596] tegradc 15210000.nvdisplay: blank - powerdown
[ 40.243604] tegradc 15220000.nvdisplay: blank - powerdown
[ 42.670311] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 42.670327] Bluetooth: BNEP socket layer initialized
[ 43.066609] fuse init (API version 7.26)
[ 43.266153] tegradc 15200000.nvdisplay: unblank
[ 43.266166] tegradc 15210000.nvdisplay: blank - powerdown
[ 43.266174] tegradc 15220000.nvdisplay: blank - powerdown
[ 822.216681] wlan0: deauthenticating from 6c:71:0d:fd:46:c0 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 824.300552] wlan0: authenticate with 6c:71:0d:fd:46:c0
[ 824.319590] wlan0: send auth to 6c:71:0d:fd:46:c0 (try 1/3)
[ 824.424386] wlan0: send auth to 6c:71:0d:fd:46:c0 (try 2/3)
[ 824.528419] wlan0: send auth to 6c:71:0d:fd:46:c0 (try 3/3)
[ 824.632379] wlan0: authentication with 6c:71:0d:fd:46:c0 timed out
[ 825.706320] wlan0: authenticate with 6c:71:0d:fd:46:c0
[ 825.723940] wlan0: send auth to 6c:71:0d:fd:46:c0 (try 1/3)
[ 825.824352] wlan0: send auth to 6c:71:0d:fd:46:c0 (try 2/3)
[ 825.926452] wlan0: authenticated
[ 825.928435] wlan0: associate with 6c:71:0d:fd:46:c0 (try 1/3)
[ 826.032374] wlan0: associate with 6c:71:0d:fd:46:c0 (try 2/3)
[ 826.050224] wlan0: RX AssocResp from 6c:71:0d:fd:46:c0 (capab=0x1431 status=0 aid=1)
[ 826.069047] wlan0: associated
[ 826.128604] wlan0: Limiting TX power to 17 (20 - 3) dBm as advertised by 6c:71:0d:fd:46:c0
[ 829.209028] wlan0: disassociated from 6c:71:0d:fd:46:c0 (Reason: 15)
[ 835.670659] wlan0: authenticate with 6c:71:0d:fd:46:c0
[ 835.698283] wlan0: send auth to 6c:71:0d:fd:46:c0 (try 1/3)
[ 835.713603] wlan0: authenticated
[ 835.716334] wlan0: associate with 6c:71:0d:fd:46:c0 (try 1/3)
[ 835.762069] wlan0: RX AssocResp from 6c:71:0d:fd:46:c0 (capab=0x1431 status=0 aid=1)
[ 835.763358] wlan0: associated
[ 835.856219] wlan0: Limiting TX power to 17 (20 - 3) dBm as advertised by 6c:71:0d:fd:46:c0
[ 870.968928] usb 1-2: USB disconnect, device number 2
[ 870.984381] wlan0: deauthenticating from 6c:71:0d:fd:46:c0 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 870.988998] rtl_usb: reg 0x102, usbctrl_vendorreq TimeOut! status:0xffffffed value=0x69543425
[ 870.989198] rtl_usb: reg 0x422, usbctrl_vendorreq TimeOut! status:0xffffffed value=0x3f80fbe
[ 870.989346] rtl_usb: reg 0x542, usbctrl_vendorreq TimeOut! status:0xffffffed value=0x290402
[ 870.989490] rtl_usb: reg 0x1cc, usbctrl_vendorreq TimeOut! status:0xffffffed value=0x25
[ 876.068424] usb 1-2: new high-speed USB device number 4 using tegra-xusb
[ 876.090221] usb 1-2: New USB device found, idVendor=0bda, idProduct=8176
[ 876.090263] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 876.090312] usb 1-2: Product: 802.11n WLAN Adapter
[ 876.090320] usb 1-2: Manufacturer: Realtek
[ 876.090326] usb 1-2: SerialNumber: 00e04c000001
[ 876.092260] rtl8192cu: Chip version 0x10
[ 876.152831] rtl8192cu: Board Type 0
[ 876.153019] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 876.153273] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[ 876.154516] ieee80211 phy1: Selected rate control algorithm ‘rtl_rc’
[ 876.253448] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 876.255225] rtl8192cu: MAC auto ON okay!
[ 876.289809] rtl8192cu: Tx queue select: 0x05
[ 876.681972] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 876.745818] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 877.788636] wlan0: authenticate with 6c:71:0d:fd:46:c0
[ 877.801877] wlan0: send auth to 6c:71:0d:fd:46:c0 (try 1/3)
[ 877.803722] wlan0: authenticated
[ 877.808786] wlan0: associate with 6c:71:0d:fd:46:c0 (try 1/3)
[ 877.830178] wlan0: RX AssocResp from 6c:71:0d:fd:46:c0 (capab=0x1431 status=0 aid=1)
[ 877.834944] wlan0: associated
[ 877.838729] wlan0: Limiting TX power to 17 (20 - 3) dBm as advertised by 6c:71:0d:fd:46:c0
[ 877.852065] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
