Hi everyone,
As title says, does xavier have hardware limit like amplitude, jitter, skew?
JetPack version: 4.6.1
thanks.
syan
Hi everyone,
thanks.
syan
Hi, what do you mean ‘capture signal limit’? Are you talking about interface SI test? If so, that tests should follow the spec of specific interface you want to test. For example, if you want to test USB port, you should follow the USB protocol/spec to do that, also you can refer to the application note of high speed interface tuning/compliance test in DLC like below doc "Jetson AGX Xavier Series Tuning and Compliance Guide Application Note ":
https://developer.nvidia.com/jetson-agx-xavier-series-tuning-and-compliance-guide-application-note
Then you can refer to MIPI spec for that.
