Xavier Computer Vision Install Fails in sdkmanager
Just received my Xavier. Excited to get started. The sdkmanager makes the process so much easier than on Nano. OS installed, all the SDKs installed except Computer Vision. Here are the errors. TIA
07:19:31 INFO : OpenCV on Host : exec_command: sudo dpkg -i ‘/home/parallels/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb’
07:19:35 INFO : OpenCV on Host : (Reading database … 274071 files and directories currently installed.)
07:19:35 INFO : OpenCV on Host : Preparing to unpack …/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb …
07:19:35 INFO : OpenCV on Host : Unpacking libopencv (3.3.1-2-gb3f86dcd5) …
07:19:36 ERROR : OpenCV on Host : dpkg: error processing archive /home/parallels/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb (–install):
07:19:36 INFO : OpenCV on Host : trying to overwrite ‘/usr/bin/opencv_version’, which is also in package libopencv-dev 3.2.0+dfsg-4ubuntu0.1
07:19:36 ERROR : OpenCV on Host : Errors were encountered while processing:
07:19:36 INFO : OpenCV on Host : /home/parallels/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb
07:19:36 INFO : OpenCV on Host : exec_command: sudo apt-get check
07:19:37 INFO : OpenCV on Host : Reading package lists…
07:19:37 INFO : OpenCV on Host : Building dependency tree…
07:19:37 INFO : OpenCV on Host : Reading state information…
07:19:37 INFO : OpenCV on Host : exec_command: dpkg-query -W -f=’{db:Status-abbrev} {Version}’ libopencv
07:19:37 INFO : OpenCV on Host : [ Package Install Finished with Error ]
07:19:37 INFO : OpenCV on Host : [ 56.00 KB used. Disk Avail: 14.64 GB ]
07:19:37 INFO : OpenCV on Host : [ NV_OPENCV_HOST_COMP Install took 8s ]
07:19:37 ERROR : OpenCV on Host : package [{libopencv 3.3.1-2-gb3f86dcd5}] not installed
07:19:37 ERROR : OpenCV on Host : command terminated with error
The error occurs when the SDK manager tries to install OpenCV on your host.
It looks like your host already has an OpenCV package installed, which stop the JetPack’s OpenCV from installing.
If you already have one OpenCV on your host, you don’t need to install it again.
Makes sense. Thank you very much.
@AastaLLL do you mean we should continue flash the Xaiver even I have the opencv installation error? So opencv3.2 will be installed on my Xaiver?
The process for host and device are separate.
You don’t need to install the packages for the host if you just want to set up the Xavier environment.
Thank you @AastaLLL
