Xavier connect FDLINK camera
Check the kernel message to know if the ar231 was loaded and probe normally.
Also below is incorrect even it not relative for the video0 created. Should be 8-0018
devname = “ar231 80-0018”
Let me modify the DTS for this bug,but I’m not sure how to modify it, just change “ar231 80-0018” to“ar231 8-0018” in the dts file ?
BTW,where did the V4l2 test tools (like v4l2-compliance v4l2-ctl, I not find them in nvidia system)in the documentation come from?
Thank you very much!
BR,
You may install package v4l-utils:
sudo apt-get update
sudo apt-get install v4l-utils
Hi Honey_Patouceul,
      Thank you for your replay!
      In follwing log has a "nvcsi--1",but  CSI 2 and 3 are used in our hardware(following picture). How can we modify DTS to send data to CSI 2 and 3?
Our DTS is in the reply above.
==========log============
cheese-20482 [001] … 640.467565: tegra_channel_open: vi-output, ar231 8-0018
cheese-20482 [001] … 640.469815: tegra_channel_set_power: ar231 8-0018 : 0x1
cheese-20482 [001] … 640.469897: camera_common_s_power: status : 0x1
cheese-20482 [001] … 640.470546: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x1
cheese-20482 [001] … 640.470551: csi_s_power: enable : 0x1
cheese-20482 [001] … 640.472201: tegra_channel_close: vi-output, ar231 8-0018
cheese-20482 [001] … 640.472209: tegra_channel_set_power: ar231 8-0018 : 0x0
cheese-20482 [001] … 640.472219: camera_common_s_power: status : 0x0
cheese-20482 [001] … 640.472424: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x0
cheese-20482 [001] … 640.472426: csi_s_power: enable : 0x0
cheese-20488 [003] … 640.478755: tegra_channel_open: vi-output, ar231 8-0018
cheese-20488 [003] … 640.478781: tegra_channel_set_power: ar231 8-0018 : 0x1
cheese-20488 [003] … 640.478798: camera_common_s_power: status : 0x1
cheese-20488 [003] … 640.479714: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x1
cheese-20488 [003] … 640.479720: csi_s_power: enable : 0x1
cheese-20488 [003] … 640.480242: tegra_channel_close: vi-output, ar231 8-0018
cheese-20488 [003] … 640.480250: tegra_channel_set_power: ar231 8-0018 : 0x0
cheese-20488 [003] … 640.480260: camera_common_s_power: status : 0x0
cheese-20488 [003] … 640.480475: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x0
cheese-20488 [003] … 640.480479: csi_s_power: enable : 0x0
cheese-20562 [002] … 884.968616: tegra_channel_open: vi-output, ar231 8-0018
cheese-20562 [002] … 884.970917: tegra_channel_set_power: ar231 8-0018 : 0x1
cheese-20562 [002] … 884.970989: camera_common_s_power: status : 0x1
cheese-20562 [002] … 884.971775: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x1
cheese-20562 [002] … 884.971782: csi_s_power: enable : 0x1
cheese-20562 [002] … 884.973561: tegra_channel_close: vi-output, ar231 8-0018
cheese-20562 [002] … 884.973572: tegra_channel_set_power: ar231 8-0018 : 0x0
cheese-20562 [002] … 884.973593: camera_common_s_power: status : 0x0
cheese-20562 [002] … 884.973942: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x0
cheese-20562 [002] … 884.973948: csi_s_power: enable : 0x0
cheese-20568 [000] … 884.979948: tegra_channel_open: vi-output, ar231 8-0018
cheese-20568 [000] … 884.979965: tegra_channel_set_power: ar231 8-0018 : 0x1
cheese-20568 [000] … 884.979981: camera_common_s_power: status : 0x1
cheese-20568 [000] … 884.980575: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x1
cheese-20568 [000] … 884.980582: csi_s_power: enable : 0x1
cheese-20568 [000] … 884.981181: tegra_channel_close: vi-output, ar231 8-0018
cheese-20568 [000] … 884.981189: tegra_channel_set_power: ar231 8-0018 : 0x0
cheese-20568 [000] … 884.981206: camera_common_s_power: status : 0x0
cheese-20568 [000] … 884.981413: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x0
cheese-20568 [000] … 884.981417: csi_s_power: enable : 0x0
gst-plugin-scan-20614 [000] … 995.395039: tegra_channel_open: vi-output, ar231 8-0018
gst-plugin-scan-20614 [000] … 995.396886: tegra_channel_set_power: ar231 8-0018 : 0x1
gst-plugin-scan-20614 [000] … 995.396908: camera_common_s_power: status : 0x1
gst-plugin-scan-20614 [000] … 995.397651: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x1
gst-plugin-scan-20614 [000] … 995.397658: csi_s_power: enable : 0x1
gst-plugin-scan-20614 [000] … 995.399328: tegra_channel_close: vi-output, ar231 8-0018
gst-plugin-scan-20614 [000] … 995.399336: tegra_channel_set_power: ar231 8-0018 : 0x0
gst-plugin-scan-20614 [000] … 995.399387: camera_common_s_power: status : 0x0
gst-plugin-scan-20614 [000] … 995.399564: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x0
gst-plugin-scan-20614 [000] … 995.399567: csi_s_power: enable : 0x0
gst-launch-1.0-20613 [003] … 996.498756: tegra_channel_open: vi-output, ar231 8-0018
gst-launch-1.0-20613 [000] … 996.500868: tegra_channel_set_power: ar231 8-0018 : 0x1
gst-launch-1.0-20613 [000] … 996.500908: camera_common_s_power: status : 0x1
gst-launch-1.0-20613 [000] … 996.501630: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x1
gst-launch-1.0-20613 [000] … 996.501637: csi_s_power: enable : 0x1
gst-launch-1.0-20613 [000] … 996.503344: tegra_channel_close: vi-output, ar231 8-0018
gst-launch-1.0-20613 [000] … 996.503352: tegra_channel_set_power: ar231 8-0018 : 0x0
gst-launch-1.0-20613 [000] … 996.503368: camera_common_s_power: status : 0x0
gst-launch-1.0-20613 [000] … 996.503584: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x0
gst-launch-1.0-20613 [000] … 996.503587: csi_s_power: enable : 0x0
gst-launch-1.0-20627 [000] … 1012.097542: tegra_channel_open: vi-output, ar231 8-0018
gst-launch-1.0-20627 [000] … 1012.102706: tegra_channel_set_power: ar231 8-0018 : 0x1
gst-launch-1.0-20627 [000] … 1012.102754: camera_common_s_power: status : 0x1
gst-launch-1.0-20627 [000] … 1012.103829: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x1
gst-launch-1.0-20627 [000] … 1012.103842: csi_s_power: enable : 0x1
gst-launch-1.0-20627 [000] … 1012.106020: tegra_channel_close: vi-output, ar231 8-0018
gst-launch-1.0-20627 [000] … 1012.106033: tegra_channel_set_power: ar231 8-0018 : 0x0
gst-launch-1.0-20627 [000] … 1012.106048: camera_common_s_power: status : 0x0
gst-launch-1.0-20627 [000] … 1012.106401: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x0
gst-launch-1.0-20627 [000] … 1012.106404: csi_s_power: enable : 0x0
gst-launch-1.0-20685 [002] … 1052.092141: tegra_channel_open: vi-output, ar231 8-0018
gst-launch-1.0-20685 [000] … 1052.096832: tegra_channel_set_power: ar231 8-0018 : 0x1
gst-launch-1.0-20685 [000] … 1052.096977: camera_common_s_power: status : 0x1
gst-launch-1.0-20685 [000] … 1052.098134: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x1
gst-launch-1.0-20685 [000] … 1052.098147: csi_s_power: enable : 0x1
gst-launch-1.0-20685 [000] … 1052.100621: tegra_channel_close: vi-output, ar231 8-0018
gst-launch-1.0-20685 [000] … 1052.100642: tegra_channel_set_power: ar231 8-0018 : 0x0
gst-launch-1.0-20685 [000] … 1052.100659: camera_common_s_power: status : 0x0
gst-launch-1.0-20685 [000] … 1052.101082: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x0
gst-launch-1.0-20685 [000] … 1052.101086: csi_s_power: enable : 0x0
gst-launch-1.0-20685 [000] … 1052.228096: tegra_channel_open: vi-output, ar231 8-0018
gst-launch-1.0-20685 [000] … 1052.228131: tegra_channel_set_power: ar231 8-0018 : 0x1
gst-launch-1.0-20685 [000] … 1052.228157: camera_common_s_power: status : 0x1
gst-launch-1.0-20685 [000] … 1052.228977: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x1
gst-launch-1.0-20685 [000] … 1052.228983: csi_s_power: enable : 0x1
gst-launch-1.0-20685 [000] … 1052.237227: tegra_channel_close: vi-output, ar231 8-0018
gst-launch-1.0-20685 [000] … 1052.237245: tegra_channel_set_power: ar231 8-0018 : 0x0
gst-launch-1.0-20685 [000] … 1052.237276: camera_common_s_power: status : 0x0
gst-launch-1.0-20685 [000] … 1052.237674: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x0
gst-launch-1.0-20685 [000] … 1052.237681: csi_s_power: enable : 0x0
So how we can change the CSI ID and become to other channel? Thanks
The port-index to configure which CSI lanes.
0 map to CSI-A …
                vi@15c10000 {
                        num-channels = <1>;
                        ports {
                                #address-cells = <1>;
                                #size-cells = <0>;
                                port@0 {
                                        reg = <0>;
                                        e3326_vi_in0: endpoint {
                                                port-index = <2>;
                                                bus-width = <2>;
                                                remote-endpoint = <&e3326_csi_out0>;
                nvcsi@15a00000 {
                        num-channels = <1>;
                        #size-cells = <0>;
                        channel@0 {
                                reg = <0>;
                                ports {
                                        #size-cells = <0>;
                                        port@0 {
                                                reg = <0>;
                                                e3326_csi_in0: endpoint@0 {
                                                        port-index = <2>;
                                                        bus-width = <2>;
                                                        remote-endpoint = <&e3326_ov5693_out0>;
                                        port@1 {
                                                reg = <1>;
                                                e3326_csi_out0: endpoint@1 {
                                                        remote-endpoint = <&e3326_vi_in0>;
Hi ShaneCCC,
Thank you very much for your replay!
I’m going to close the question.
Bellow link in order to describe our intention in more detail,help us to check please!
The Xavier csi inside use 4 lanes ( CSI2+CSI3 combine);so how we can set the CSI2 and CSI3 to one 4lanes gorup?thanks
Set the port-index to 2 and bus-width to 4
so as our set is as the picture ,is right? thanks
as the picture of attache,what is the mean X1,X2,X4 ;it is said:CSI0 can connect 4 cameras and have four virtual channels ?but CSI1 only support 2 cameras ,most support two virtual channels?thanks
That tells you can use it as 1 lane 2 lanes or 4 lanes configure depend on the sensor output configure.
You may need to consult to vendor to know the sensor configure is 1/2/4 lanes configure to set the DT to match it.
