We design custom carrier board for Nvidia Xavier
At bring up stage we immediately encounter system boot failure.
The first error is being wuote as following:
[0008.463] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (user@Yehoubu15221) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) ) #1 SMP PREEMPT Wed Mar 10 10:26:05 IST 2021
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06a0000
[ 0.000000] Found lut_mem: 00002008@a069a000
[ 1.811152] ufs_tegra 2450000.ufshci: dme-link-startup: error code 1
[ 1.923159] ufs_tegra 2450000.ufshci: dme-link-startup: error code 1
[ 2.035154] ufs_tegra 2450000.ufshci: dme-link-startup: error code 1
[ 2.147148] ufs_tegra 2450000.ufshci: dme-link-startup: error code 1
[ 2.158998] ufs_tegra 2450000.ufshci: link startup failed 1
[ 2.253296] CPU2: SError detected, daif=1c0, spsr=0xc000c5, mpidr=80000100, esr=be000000
[ 2.253302] CPU3: SError detected, daif=1c0, spsr=0x8000c5, mpidr=80000101, esr=be000000
[ 2.253308] CPU0: SError detected, daif=1c0, spsr=0x60c00045, mpidr=80000000, esr=be000000
[ 2.253314] CPU1: SError detected, daif=1c0, spsr=0xc000c5, mpidr=80000001, esr=be000000
[ 2.253340] CPU6: SError detected, daif=1c0, spsr=0x8000c5, mpidr=80000300, esr=be000000
גsafereg_poll_timer_cb: poll interval 130 above target 100
ב[ 2.253345] CPU7: SError detected, daif=1c0, spsr=0x8000c5, mpidr=80000301, esr=be000000
[ 2.253354] CPU4: SError detected, daif=1c0, spsr=0x8000c5, mpidr=80000200, esr=be000000
[ 2.253360] CPU5: SError detected, daif=1c0, spsr=0x20800045, mpidr=80000201, esr=be000000
I was looking for over the internet but I couldn’t find any information about those errors.
What does the error means and how can I analysis the root cause for the error ?
It is HW issue or Kernel configuration Issue or other thing??
TegraLog.log (125.8 KB)
