Xavier doesn’t boot after Secure Boot flash (JetPack 5.1.2 / L4T R35.4.1)
Hi, I would like to have secureboot with encrypted rootfs on AGX XAVIER. I’m using ubuntu 20.04, I’ve burned fuses Kek0, Kek1, Kek2,PublicKeyHash SecureBootKey, BootSecurityInfo 0x6.
I can read the fuses with ./odmfuseread.sh -i 0x19 -k ${KEYS_DIR}/key.pem -S ${KEYS_DIR}/SBK.key cti/xavier/rogue/base without any issue.
See the attached picture. (I blacked out the keys, they are the same as I burned).
I generate EKS image
python3 gen_ekb.py -chip t194 -kek2_key kek2.key -fv fv.txt
-in_sym_key sym1_t194.key -in_sym_key2 sym2_t194.key -out eks_t194.img
cp eks_t194.img bootloader/eks_t194.img
I flash the device with command sudo ROOTFS_ENC=1 ./flash.sh -u ${KEYS_DIR}/key.pem -v ${KEYS_DIR}/SBK.key -i ${KEYS_DIR}/sym2_t194.key cti/xavier/rogue/base mmcblk0p1
The flash.sh ends
[ 363.7768 ] Flashing completed
[ 363.7770 ] Coldbooting the device
[ 363.7807 ] tegrarcm_v2 --ismb2
[ 363.9057 ] tegradevflash_v2 --reboot coldboot
[ 363.9080 ] Bootloader version 01.00.0000
But the device after reboot stays in recovery mode no UART or HDMI output.
Is it issue that I burned kek0,kek1 too?
Any help would be appreciated. Thanks!
hello pwaadm7,
it looks you did not enable security mode. (i.e. ODM_PRODUCTION)
FYI, the recommended way (especially for Xavier series) is to burn all fuses together instead of burning fuses step-by-step.
Thank you for your previous response. I thought that AGX would boot even if it is not in production mode. Could you please confirm if that is the case? I would like to have JTAG disabled in production mode, but if I do that now, I will lose the ability to use it.
hello pwaadm7,
please see-also Topic 158361, please burn all fuses together.
you may refer to developer guide, Secure Boot — NVIDIA Jetson Linux Developer Guide.
re-cap as below.
NVIDIA recommends burning all the fuses you need in a single operation.
I will definitely burn the fuses at once for the production devices. But now I would like to know If I can fix the device with missing ODM_PRODUCTION fuse, and if it is the issue why the jetson doesnt boot, as I dont have any messages in debug console.
hello pwaadm7,
you may do partial fuse burning to program ODM_PRODUCTION on that target.
hi @JerryChang, please advice what’s the best way to partial burn to production mode ?
  1. sudo ./odmfuse.sh -i 0x19 -k ${KEYS_DIR}/key.pem -S ${KEYS_DIR}/SBK.key -p cti/xavier/rogue/base
or
  1. sudo ./odmfuse.sh -X ${KEYS_DIR}/fuse_config_agx_xavier.xml -i 0x19 -k ${KEYS_DIR}/key.pem -S ${KEYS_DIR}/SBK.key cti/xavier/rogue/base
where fuse_config_agx_xavier.xml
< genericfuse MagicId=“0x45535546” version=“1.0.0”>
< fuse name=“SecurityMode” size=“4” value=“0x1”/>
< /genericfuse>
hello pwaadm7,
either use-p to sets production mode, or, set SecurityMode through fuse configuration file. both of them all okay to partial burn for enabling production mode.
