H,
In the DRM interface, I submitted the following CRTC timing configuration.
drmModeModeInfo mode;
mode.vrefresh = 60;
mode.clock = 533280;
mode.hdisplay = 3840;
mode.hsync_start = 3888;
mode.hsync_end = 3920;
mode.htotal = 4000;
mode.vdisplay = 2160;
mode.vsync_start = 2160;
mode.vsync_end = 2168;
mode.vtotal = 2222;
drmModeCreatePropertyBlob(m_res.drm_fd, &mode, sizeof(mode), &blob_id);
req = drmModeAtomicAlloc();
drmModeAtomicAddProperty(req, crtc_id, property_active, 1);
drmModeAtomicAddProperty(req, crtc_id, property_mode_id, blob_id);
drmModeAtomicAddProperty(req, conn_id, property_crtc_id, crtc_id);
drmModeAtomicCommit(m_res.drm_fd, req, DRM_MODE_ATOMIC_ALLOW_MODESET, NULL); //提交设置
drmModeAtomicFree(req);
After setting the mode.clock to 533280KHz and the frame rate to 60, when I use the “fbset” command to view the current mode, it shows that the mode is set to:
root@avcit-desktop:/usr/bin# fbset
mode “3840x2160-60”
# D: 533.333 MHz, H: 133.333 kHz, V: 60.006 Hz
geometry 3840 2160 3840 2160 32
timings 1875 80 48 54 3 32 5
rgba 8/16,8/8,8/0,8/24
endmode
Can you tell me why the pixel clock is 533333KHz and the frame rate is 60.006Hz instead of the frame rate of 60Hz and the pixel clock of 533280KHz that I submitted?
