I try the xaiver image-based ota update from 32.3 to 32.7.2, then to 35.1. The process all are successfully. But in the process from 32.7.2 to 35.1, the updated 35.1 desktop can be entered with hdmi, but the serial output is blocked. The following is the serial output. If I burn the xavier of version 32.7.2 with flash.sh and update to 35.1 with image-based ota, the serial is not blocked and I can login on in the serail.The attachment is the log. 32.7.2-to-35.1-succeded.log (6.2 KB)
**WARNING: Test Key is used. **
L4TLauncher: Attempting GRUB Boot L4TLauncher: Attempting Direct Boot ��I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot I/TC: Secondary CPU 2 initializing I/TC: Secondary CPU 2 switching to normal world boot I/TC: Secondary CPU 3 initializing I/TC: Secondary CPU 3 switching to normal world boot I/TC: Secondary CPU 4 initializing I/TC: Secondary CPU 4 switching to normal world boot I/TC: Secondary CPU 5 initializing I/TC: Secondary CPU 5 switching to normal world boot I/TC: Secondary CPU 6 initializing I/TC: Secondary CPU 6 switching to normal world boot I/TC: Secondary CPU 7 initializing I/TC: Secondary CPU 7 switching to normal world boot ��debugfs initialized ��[ 25.939747] Camera-FW on t194-rce-safe started TCU early console enabled. [ 26.007534] Camera-FW on t194-rce-safe ready SHA1=d48f1e27 (crt 0.775 ms, total boot 68.591 ms) ��WARNING: clock_disable: clk_power_ungate on gated domain 27 for gpcclk
interesting, could you please check APPEND, do you have console=ttyTCU0,115200 included in your bootargs?
you may also remove quiet from the bootargs in order to gather more logs.
thanks
Hi, carolyuu
I have followed the topic workaround to update from 32.7.2 to 35.1.
And I have tested 32.6.1 to 32.7.2 and then to 35.1, and the result is that the serial works rightly.
This topic which has error is updating xavier from 32.3 to 32.7.2 and then to 35.1.
Please add console=ttyTCU0,115200 in APPEND with r32.3.
File path: Linux_for_Tegra/rootfs/boot/extlinux/extlinux.conf
Then start image-based OTA update.
Do you mean adding console=ttyTCU0,115200 in 32.3, or the ota package from 32.3 to 32.7.2, or the bootloader ota package from 32.3 to 32.7.2, or the ota package from 32.7.2 to 35.1?
