Xavier industrial no disaply spi node
I configured spi functionality on a custom carrier board, However, the system does not display the SPI node.
spi@c260000 {
//status = “disabled”;
status = “okay”;
spi@0 {
compatible = “tegra-spidev”;
reg = <0x0>;
spi-max-frequency = <33000000>;
controller-data {
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x11>;
    spi@3210000 {
            //status = "okay";
            status = "disabled";
            /*spi@0 {
                    compatible = "tegra-spidev";
                    reg = <0x0>;
                    controller-data {
            spi@1 {
                    reg = <0x1>;
                    controller-data {
Try below command after boot to system.
sudo modprobe spidev.ko
Thank you very much. After loading the driver, the node is displayed.
In jetpack 4.6 previous versions, this driver is loaded automatically. What happens to this version (jetpack 4.6)?
