My Jetson xavier can’t be detected in recovery mode and is stuck in an infinite boot loop otherwise. Occasionally it will provide the following error message. It’s around 7 months old. Any ideas?
If your board was able to boot/ enter recovery mode but it starts to fail recently, then it is possible hardware issue…
Could you describe why it cannot go into recovery mode? No response? Have you tried some cross comparison between different hardware? For example, if you have 2 xavier, swap the carrier board and see if it can help.
Also, it is not a good idea to paste a photo for such issue. Please use the UART to dump serial log and paste the full log.
Was a bad USB cable! I was able to resolve. Thank you.
