Xavier int8 inference driver error
Description
I modify the sample code and run inference with our model in FP32 correctly.
But I tried to run the application in ./test --int8, it gives error below:
Input filename: …/samples/sampleSEGNET/Model.onnx
ONNX IR version: 0.0.6
Opset version: 9
Producer name: pytorch
Producer version: 1.7
Domain:
Model version: 0
Doc string:
[02/02/2021-12:27:31] [W] [TRT] Calibrator is not being used. Users must provide dynamic range for all tensors that are not Int32.
[02/02/2021-12:27:31] [I] [TRT]
[02/02/2021-12:27:31] [I] [TRT] --------------- Layers running on DLA:
[02/02/2021-12:27:31] [I] [TRT] --------------- Layers running on GPU:
[02/02/2021-12:27:31] [I] [TRT] (Unnamed Layer* 0) [Constant] + (Unnamed Layer* 1) [Shuffle] + Add_1, Conv_2 + Relu_3, Conv_4 + Relu_5, Conv_6, Conv_7 + Relu_8, Add_9, Conv_50 + Relu_51 || Conv_10 + Relu_11, Conv_12, Conv_13 + Relu_14, Add_15, Conv_16 + Relu_17, Conv_18 + Relu_19, Conv_20 + Relu_21, Add_22, Conv_23 + Relu_24, Add_25, Conv_26 + Relu_27, Conv_28 + Relu_29, Add_30…
terminate called after throwing an instance of ‘pwgen::PwgenException’
what(): Driver error:
Aborted
Is this problem caused by wrong driver version?
Shall I upgrade/downgrade something?
Thank you.
Environment
TensorRT Version: 7.1.3
GPU Type: Xavier
Nvidia Driver Version: Package:nvidia-jetpack, Version: 4.4.1-b50
CUDA Version: 10.2.89
CUDNN Version: 8.0.0
Operating System + Version: Ubuntu 18.04
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Steps To Reproduce
Please include:
  • Exact steps/commands to build your repro
  • Exact steps/commands to run your repro
  • Full traceback of errors encountered
Hi @disculus2012,
Could you please provide us more info like issue reproduce scripts, onnx model, trtexec or other command you tried. Which helps us to debug better.
Thank you.
Thank you for reply on this.
I was told that I can’t share the model I used.
Here’s the command I run
./trtexec_debug --onnx=…/samples/sampleSEGNET/APA_FS_Model.onnx --explicitBatch --int8 --verbose 1>log.txt
log.txt (450.6 KB)
Forget to mention that I can run in FP32 and INT8 version on V100 GPU using same onnx model.
But on Xavier it will give the Driver error.
I found it has error after conv_47.
If I only use previous layer it can finish with driver error.
Is anything I can check for this error?
Thank you,
We have built another model that same driver error will occur.
Can you give me a e-mail address for sending onnx model file to?
Thank you,
Hi @disculus2012,
There are no errors in the log. Please DM model and issue reproduce steps which helps us to debug better.
Thank you.
Hi @disculus2012,
Thanks for sharing the model. I tried reproducing the issue. But I didn’t get any problem in running. This looks like Jetson issue.
Please post your query in related forum.
Thank you.
