Xavier Module boot failed: "LOADER: Could not read membct"
We design our own mother board where “Xavier module” is inserted in. There are two versions of our mother borad, called A version and B version. The hardwre difference between them is small. The xavier module works fine in A version and failed in B version. The error log from uart (B version) is:
[0000.052] I> MB1 (prd-version: 1.1.0.0-t194-41334769-514a1108)
[0000.058] I> Boot-mode: L1 coldboot
[0000.061] I> Chip revision : A02
[0000.064] I> Bootrom patch version : 7 (correctly patched)
[0000.069] I> ATE fuse revision : 0x200
[0000.072] I> Ram repair fuse : 0x0
[0000.076] I> Ram Code : 0xc
[0000.078] I> rst_source : 0xb
[0000.081] I> rst_level : 0x1
[0000.084] I> Boot-device: eMMC
[0000.087] W> DEVICE_PROD: device prod is not initialized.
[0000.092] W> DEVICE_PROD: device prod is not initialized.
[0000.109] I> sdmmc DDR50 mode
[0000.113] W> DEVICE_PROD: device prod is not initialized.
[0000.118] W> No valid slot number is found in scratch register
[0000.124] W> Return default slot: _a
[0000.127] I> Active Boot chain : 0
[0000.130] I> Boot-device: eMMC
[0000.134] E> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.140] E> MB1_PLATFORM_CONFIG: Failed to initialize device prod.
[0000.146] I> Temperature = 36500
[0000.149] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.153] W> Skipping boost for clk: BPMP_APB
[0000.157] W> Skipping boost for clk: AXI_CBB
[0000.161] W> Skipping boost for clk: AON_CPU_NIC
[0000.166] W> Skipping boost for clk: CAN1
[0000.169] W> Skipping boost for clk: CAN2
[0000.174] I> Boot-device: eMMC
[0000.176] I> Boot-device: eMMC
[0000.186] I> Sdmmc: HS400 mode enabled
[0000.193] E> LOADER: binary membct not found in comp list 1.
[0000.199] C> LOADER: Could not read membct.
[0000.202] C> Fail to load mem-bct bin
[0000.206] E> Task 28 failed (err: 0x1d1d0b0d)
[0000.210] E> Top caller module: LOADER, error module: LOADER, reason: 0x0d, aux_info: 0x0b
[0000.218] I> MB1(1.1.0.0-t194-41334769-514a1108) BIT boot status dump :
I think the real problem happens here:
So my question is which kind of change in hardware can raise this problem?
Looks like ram code strapping issue, please check strapping pins status.
Since board A worked, why don’t you compare B to A to find possible hardware issue?
