Tech support directed me to this forum…
I have previously been using the Xavier development kit but recently purchased the bare Xavier module to integrate into a product. I attached it to a heatsink that my mechanical engineer assures me is sufficient to keep it passively cooled. (It’s twice as big as the module itself) Anyway, upon initial power up, the only thing that happens is that a white indicator light comes on. I’m still using the dev board’s carrier board so the only thing that has changed is that I now have a new Xavier module.
I figured that maybe it just comes unflashed. I needed to reflash the dev board Xavier to work with my cameras so I have tried to do that today by using flash.sh as recommended by the camera vendor. This went smoothly with the dev kit Xavier but I am getting errors from flash.sh:
The first time that I run it:
L4T BSP Information:
R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t186ref, EABI: aarch64,
DATE: Wed Mar 13 07:41:08 UTC 2019
Target Board Information:
Name: jetson-xavier, Board Family: t186ref, SoC: Tegra 194,
OpMode: production, Boot Authentication: NS,
./flash.sh: line 347: systems: command not found
If I run it a second time it pauses for a bit and then gives me this:
Error: probing the target board failed.
Make sure the target board is connected through
USB port and is in recovery mode.
lsusb give me the following:
Bus 002 Device 003: ID 154b:6008 PNY
Bus 002 Device 002: ID 05e3:0612 Genesys Logic, Inc.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 21a9:1001
Bus 001 Device 009: ID 0955:7019 NVidia Corp.
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 005: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Bus 001 Device 003: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Because of this, I know that the computer can see the module.
Did I get a dead on arrival module or is there some sort of trick to get this thing running?
