Hi, I’m currently porting a project to Jetpack 5.1.1 from Jetpack 4.6. On the project we use iio to monitor ina3221 to check for power, voltages and currents. We enabled the CONFIG_INA3221 on tegra_defconfig and made a couple of changes so the driver was able to compile, but the attributes do not show up, not sure if the path is the same as JP4, I’m looking on /sys/bus/i2c/drivers/ina3221x, the folder does show up after said changes but the attributes are not there. The changes are:
Change 1:
static const struct iio_info ina3221_info = {
.attrs = &ina3221_groups,
/*.driver_module = THIS_MODULE, removed this */
.read_raw = &ina3221_read_raw,
Change 2:
indio_dev->dev.parent = &client->dev;
indio_dev->modes = INDIO_DIRECT_MODE;
indio_dev->driver_module = THIS_MODULE; // Added this on the ina3221_probe method
ret = devm_iio_device_register(chip->dev, indio_dev);
if (ret < 0) {
Also upon checking the Kconfig I see that it’s deprecated:
config INA3221
tristate "[DEPRECATED] TI INA3221 3-Channel Shunt and Bus Voltage Monitor"
depends on I2C
help
TI INA3221 is Triple-Channel, High-Side Measurement, Shunt and Bus
Voltage Monitor with I2C Interface
Say Y here if you have INA3221 hooked to a I2C bus.
It there a replacement or something similar or something else that I can do to enable the attributes, or do we need to implement our own driver attributes? Also not sure if it’s as simple as I’m looking on the wrong path, since I know that the normal drivers attributes paths did change a bit with the new kernel.
Regards,
Andres
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.c om/
Website: www.ridgerun.com
hello andres.artavia,
Jetson Xavier NX series has one INA3221 power monitor at I2C address 0x40
the node is under… /sys/bus/i2c/drivers/ina3221/7-0040/hwmon/hwmon<x>
BTW,
I’ve also check a Xavier NX flashed with JP-5.1.1,
INA3221 is default enabled. it’s able to check for power, voltages and currents via INA3221.
for example,
root@tegra-ubuntu:~# cat /etc/nv_tegra_release
# R35 (release), REVISION: 3.1, GCID: 32827747, BOARD: t186ref, EABI: aarch64, DATE: Sun Mar 19 15:19:21 UTC 2023
root@tegra-ubuntu:~# cd /sys/bus/i2c/drivers/ina3221/7-0040/hwmon/hwmon5
root@tegra-ubuntu:/sys/bus/i2c/drivers/ina3221/7-0040/hwmon/hwmon5# cat
curr1_crit curr2_max curr4_crit_alarm in2_label in7_label subsystem/
curr1_crit_alarm curr2_max_alarm curr4_input in3_enable name uevent
curr1_input curr3_crit device/ in3_input of_node/ update_interval
curr1_max curr3_crit_alarm in1_enable in3_label power/
curr1_max_alarm curr3_input in1_input in4_input samples
curr2_crit curr3_max in1_label in5_input shunt1_resistor
curr2_crit_alarm curr3_max_alarm in2_enable in6_input shunt2_resistor
curr2_input curr4_crit in2_input in7_input shunt3_resistor
root@tegra-ubuntu:/sys/bus/i2c/drivers/ina3221/7-0040/hwmon/hwmon5# cat in1_input
5120
Hi, thanks for the response.
Got it so its enabled by default, and the path is different. But in case I want/need to add another attribute to said driver, where should I do it?
Regards Andres.
there’re already current, voltage…etc, you may refer to developer guide, Software-Based Power Consumption Modeling.
may I know what’s the actual use-case, thanks
Hi, @JerryChang, actually that link you just sent has the info that I need, I was going to get into the driver and check what each attribute was, but that link has the table with what I need. Thanks
