Once I started to install it, pip goes on an endless loop trying to install scipy with this message:
INFO: pip is looking at multiple versions of scipy to determine which version is compatible with other requirements. This could take a while.
For curiosity’s sake, I removed scipy from the required packages but the I get this error:
ERROR: Cannot install object-detection because these package versions have conflicting dependencies.
The conflict is caused by:
tf-models-official 2.4.0 depends on tensorflow-addons
tf-models-official 2.3.0 depends on tensorflow-addons
tf-models-official 2.2.2 depends on tensorflow-addons
tf-models-official 2.2.1 depends on tensorflow-addons
tf-models-official 2.2.0 depends on tensorflow-addons
To fix this you could try to:
loosen the range of package versions you’ve specified
remove package versions to allow pip attempt to solve the dependency conflict
Hi @ig-j, it’s because this is a base container that was built for x86, not aarch64. You will encounter “exec format error” when you try to run an x86 binary on aarch64 (or vice versa)
On Jetson, it’s recommended to use the l4t-tensorflow or l4t-ml container as base.
Hi @ig-j, sorry for the delay - you will want to change the FROM statement at the top of that Dockerfile to one of the l4t-tensorflow or l4t-ml containers. Then it will use an aarch64 base container instead of x86_64 base container.
BTW you will want to pick one of the l4t-tensorflow/l4t-ml containers that has the same L4T version as you are running (which you can check with cat /etc/nv_tegra_release). For example, if you are running L4T R32.5.0 or R32.5.1, you can use nvcr.io/nvidia/l4t-tensorflow:r32.5.0-tf2.3-py3
@dusty_nv, no worries, I was able to run the Dockerfile all the way the the very end but I get the same issue as before. Pip kept on installing multiple version of scipy. Should I let it run?
Sorry for the delay - I’ve not yet updated these containers for the TF2.4 wheels, but if you wanted you could build the containers for TF2.4. Essentially you would replace the URL/filename of the TF2.3 wheel with the TF2.4 wheel here:
Hi i have been trying to do the same thing, running TFOD on jetson xavier. I also came across the same issue of mutiple installation of scipy. Did u find a way around this, and are u able to get TF object detection up and running on ur jetson?
