Randomly on Xavier NX’s running Jetpack 4.4.1 I will get the following kernel panic:
[ 14.284339] trusty-irq trusty:irq: trusty_panic_notify: trusty crashed, disabling trusty irqs
[ 14.294304] Unable to handle kernel NULL pointer dereference at virtual address 00000028
[ 14.294458] Mem abort info:
[ 14.294519] ESR = 0x96000005
[ 14.294590] Exception class = DABT (current EL), IL = 32 bits
[ 14.294698] SET = 0, FnV = 0
[ 14.294758] EA = 0, S1PTW = 0
[ 14.294821] Data abort info:
[ 14.294883] ISV = 0, ISS = 0x00000005
[ 14.294958] CM = 0, WnR = 0
[ 14.295023] [0000000000000028] user address but active_mm is swapper
[ 14.295146] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 14.295251] Modules linked in:
[ 14.295336] CPU: 5 PID: 0 Comm: swapper/5 Tainted: G W 4.9.140-tegra #1
[ 14.295477] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[ 14.295595] task: ffffffc1f6b76200 task.stack: ffffffc1f6ba0000
[ 14.295731] PC is at trusty_irq_handler+0x40/0x160
[ 14.296092] LR is at trusty_irq_handler+0x3c/0x160
[ 14.296475] pc : [<ffffff8008cb3400>] lr : [<ffffff8008cb33fc>] pstate: 604001c5
[ 14.297054] sp : ffffffc1ffda2f20
[ 14.297908] x29: ffffffc1ffda2f20 x28: ffffffc1f6b76200
[ 14.303433] x27: ffffffc1ffdac190 x26: ffffffc1ffda3050
[ 14.308944] x25: ffffffc1ffd9f060 x24: 0000000000000001
[ 14.314793] x23: 00000041f63ef000 x22: 0000000000000000
[ 14.320395] x21: 0000000000000002 x20: ffffffc1ee9fd180
[ 14.326081] x19: ffffffc1ffdb5c58 x18: 00000000fffffffe
[ 14.331768] x17: 00000000003d05fd x16: 0000000000306093
[ 14.337206] x15: 0000000000000000 x14: 0000000000000001
[ 14.342981] x13: 00000000000002ff x12: 071c71c71c71c71c
[ 14.348744] x11: 0000000000000040 x10: ffffff8009f07b80
[ 14.354343] x9 : ffffffc1f6545220 x8 : ffffffc1f6400028
[ 14.360118] x7 : 0000000000000000 x6 : ffffffc1f6400000
[ 14.365382] x5 : ffffffc1f6400038 x4 : ffffffc1f6804c00
[ 14.370969] x3 : 0000000000000020 x2 : 0000000000000000
[ 14.376306] x1 : ffffffc1f6b76200 x0 : 0000000000010001
[ 14.381394]
[ 14.382794] Process swapper/5 (pid: 0, stack limit = 0xffffffc1f6ba0000)
[ 14.389435] Call trace:
[ 14.391543] [<ffffff8008cb3400>] trusty_irq_handler+0x40/0x160
[ 14.397405] [<ffffff800814c8d0>] handle_percpu_devid_irq+0x90/0x2a0
[ 14.403006] [<ffffff80081470f4>] generic_handle_irq+0x34/0x50
[ 14.408343] [<ffffff80081477cc>] __handle_domain_irq+0x6c/0xc0
[ 14.414200] [<ffffff8008080d24>] gic_handle_irq+0x54/0xa8
[ 14.419017] [<ffffff8008082c28>] el1_irq+0xe8/0x194
[ 14.423828] [<ffffff8008b77af0>] cpuidle_enter_state+0xb8/0x380
[ 14.429426] [<ffffff8008b77e2c>] cpuidle_enter+0x34/0x48
[ 14.434502] [<ffffff8008138458>] call_cpuidle+0x40/0x70
[ 14.439055] [<ffffff800813876c>] cpu_startup_entry+0x154/0x210
[ 14.444916] [<ffffff80080929cc>] secondary_start_kernel+0x124/0x160
[ 14.450868] [<0000000080e911a4>] 0x80e911a4
[ 14.455074] ---[ end trace 4ee2154b8679fb40 ]---
[ 14.467815] Kernel panic - not syncing: Fatal exception in interrupt
Any ideas as to what could be causing this?
