Dear,
I have a problem about the image data when I capture image data via Xavier NX with sdk 32.4.2 version.
The image is 1008x2000@50fps with YUYV 16bit(YUV422) format. Our board connect as follows :
FPGA → TC358748 → Xavier NX.
We connect tc358748 4 lanes with Xavier nx CSI A/B port.
When set dtb to capture 1080p video as follows, it works well.
I can capture 1080p@60fps with format YUYV 16bit when tc358748 set parameter as 1080p@60fps.
But, when I config dtb parameter as follows to capture 1008x2000 video, there is something wrong with the video data.
We config the image parameter : 1320 pixels one line, 2250 lines in one frame.
so, the pix_clk_hz is 148500000(1320x2250x50), this get from the webset:
The error data is : it loses 16 bytes data at the end of odd lines and the start of even lines, then it fills 32 bytes 0 data at the end of even lines. The video data I capture one frame as follows:
video0-1-1008x2000-2021-10-20-171428.yuv (3.8 MB)
I do not know where I ignore. The 1080P@60 image that I can capture, means the NX can capture 1008x2000@50. So I think there is something wrong with the driver.
I make another try: we have a board connect fpga ==> tc358748 ==> hi3559av100, the same fpga program ,the same tc358748 configuration , but my program on hi3559av100 can get the right data. So I think the problem is at Xavier NX program.
The media-ctl information is:
root@nx-desktop:/home/nx# media-ctl -p -d /dev/media0
Media controller API version 0.1.0
Media device information
driver tegra194-vi5
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 0.0.0
Device topology
entity 1: imx219 9-0010 (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev0
pad0: Source
[fmt:YUYV8_1X16/1008x2000 field:none colorspace:srgb]
→ “15a00000.nvcsi–3”:0 [ENABLED] -
entity 3: 15a00000.nvcsi–3 (2 pads, 2 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev1
pad0: Sink
← “imx219 9-0010”:0 [ENABLED]
pad1: Source
→ “vi-output, imx219 9-0010”:0 [ENABLED] -
entity 6: vi-output, imx219 9-0010 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
← “15a00000.nvcsi–3”:1 [ENABLED] -
entity 18: imx219 10-0010 (1 pad, 1 link)
device node name /dev/v4l-subdev2
pad0: Source
→ “15a00000.nvcsi–2”:0 [ENABLED] -
entity 20: 15a00000.nvcsi–2 (2 pads, 2 links)
device node name /dev/v4l-subdev3
pad0: Sink
← “imx219 10-0010”:0 [ENABLED]
pad1: Source
→ “vi-output, imx219 10-0010”:0 [ENABLED] -
entity 23: vi-output, imx219 10-0010 (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
← “15a00000.nvcsi–2”:1 [ENABLED] -
entity 35: imx219 11-0010 (1 pad, 1 link)
device node name /dev/v4l-subdev4
pad0: Source
→ “15a00000.nvcsi–1”:0 [ENABLED] -
entity 37: 15a00000.nvcsi–1 (2 pads, 2 links)
device node name /dev/v4l-subdev5
pad0: Sink
← “imx219 11-0010”:0 [ENABLED]
pad1: Source
→ “vi-output, imx219 11-0010”:0 [ENABLED] -
entity 40: vi-output, imx219 11-0010 (1 pad, 1 link)
device node name /dev/video2
pad0: Sink
← “15a00000.nvcsi–1”:1 [ENABLED]
The v4lt-ctl information is as follows:
root@nx-desktop:/home/nx# v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘YUYV’
Size: Discrete 1008x2000
Interval: Discrete 0.020s (50.000 fps)Index : 1
So, can you help me to solve the problem?
Thank you very much.
