Hi, I have been using Adafruit IMU (Adafruit 9-DOF Absolute Orientation IMU Fusion Breakout - BNO055 : ID 2472 : $34.95 : Adafruit Industries, Unique & fun DIY electronics and kits ) with Jetson TX2 and it worked very well. Now, I am trying to use it with Xavier NX but it did not seem to work. The imu was linked to NX by GPIO i2c pins. I use the pin 27 and 28 for SDA and SCL, which are for bus 1. However, when I do
sudo i2cdetect -y -r 1
It did not show anything.
Can anyone help?
hello AutoCar,
there’re two sets, pin-3/pin-5 and pin-27/pin-28 as I2C SDA and SCL on the [J12] 40-pin expansion header.
is this Adafruit IMU a 3.3V or 1.8V I2C device?
please check Jetson Xavier NX Product Design Guide of [Figure 12-1. I2C Connections] for reference,
thanks
@JerryChang Thank you for your post.
This is 3.3v.
I have tried both 3/5 and 27/29 pin with bus 1 and bus 8. They did not work.
Please not this device works fine on TX2. I am wonder what the difference is.
hello AutoCar,
may I know if there any error messages reported by kernel side?
please setup serial console and gather the logs in detail for reference, thanks
I2C0: SDA: 27, SCL: 28
I2C1: SDA: 3, SCL: 5
did you get any logs?
@JerryChang Could you tell me how to gather the logs?
Thanks,
hello AutoCar,
please refer to NVIDIA Jetson Xavier NX GPIO Header Pinout – JetsonHacks , you should setup a serial console via pin-8/10 with your host machine, the default baud-rate is 115200/8n1, please enable a terminal to gather the logs;
you may also check Jetson Nano Style – Serial Console – JetsonHacks for reference, thanks
system
closed
March 30, 2022, 3:51am
#10
