[Xavier NX] CAN validate with customize Carrier Board
Dear All,
I’ve follow the developer guide to validate the CAN in our carrier boards.
CAN of developer guide
There is our hardware mapping for validate
  1. We’ve been follow the loopback test and the result seems same as the
    CAN loopback test
Sorry, there is no log now, I will prepare a loopback log if you need.
root@lanner-desktop:~# cat /sys/kernel/debug/tegra_pinctrl_reg | grep can0
Bank: 1 Reg: 0x0c303010 Val: 0x0000c400 -> can0_dout_paa2
Bank: 1 Reg: 0x0c303018 Val: 0x0000c450 -> can0_din_paa3
Bank: 1 Reg: 0x0c303020 Val: 0x0000c414 -> can0_stb_paa4
Bank: 1 Reg: 0x0c303028 Val: 0x0000c000 -> can0_en_paa5
Bank: 1 Reg: 0x0c303030 Val: 0x0000c414 -> can0_wake_paa6
Bank: 1 Reg: 0x0c303038 Val: 0x0000c414 -> can0_err_paa7
root@lanner-desktop:~# busybox devmem 0x0c303018 w 0x458
root@lanner-desktop:~# busybox devmem 0x0c303010 w 0x400
root@lanner-desktop:~# cat /proc/device-tree/mttcan\@c310000/status
okayroot@lanner-desktop:~# modprobe can
root@lanner-desktop:~# modprobe can_raw
root@lanner-desktop:~# modprobe mttcan
root@lanner-desktop:~# ip link set can0 type can bitrate 500000 loopback on
root@lanner-desktop:~# ip link set can0 up
root@lanner-desktop:~# ifconfig can0
can0: flags=193<UP,RUNNING,NOARP>  mtu 16
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 10  (UNSPEC)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 64
root@lanner-desktop:~# candump can0 &
[1] 9169
root@lanner-desktop:~# cansend can0 123#abcdabcd
  can0  123   [4]  AB CD AB CD
  1. Start to validate CAN with two Carrier Board.
    One is transmitter with cansend.
    One is receiver with candump.
    This attachment is the log which our operate flow in transmitter.
    As the log show, it will issue the huge message as below after ‘cansend’.
    Those message will stop after I remove/umount/rmmod the ‘mttcan’ module.
    This log also include the dmesg in the before/after of ‘cansend’
 mttcan c310000.mttcan can0: Stuff Error Detected
Xavier_NX_CAN0_001_20220512_1044.log (383.4 KB)
We also add the ‘ifconfig can0’ in this log below for check packet transmit/receive status,
it seems only increase the RX packet, the TX packet is always 0.
Xavier_NX_CAN0_001_20220512_1102.log (214.9 KB)
This packet status is same in the receiver/candump side.
We’re curious
  1. Why there is the stuff error, what is that meaning?
  2. Why this validation only increase RX packet in transmitter/receiver. the TX is always be zero.
  3. Is that possible to fixed it or find out the root cause?
Please give us some advice for these kindly, thanks a lot.
Best Regards,
MOMO Chen
Sorry for the late response, our team will do the investigation and provide suggestions soon. Thanks
Dear kaycc,
Roger that, please let us know if there is any info further.
Best Regards,
MOMO Chen
Dear Kayccc,
Sorry to bother you, According our Hardware Engineer remind.
It need a resistance between CAN_H and CAN_L.
Those error we got before that is validate with no resistance configuration.
Apologize for that. Hope this post could remind other guys.
Best Regards,
MOMO Chen
Glad to know issue got resolved. Thanks for your sharing to the community!
