Xavier NX capture error from IMX390
hi
I am testing my own IMX390 sensor board with Xavier NX. I have set it as 2 lanes 30fps output, but it returns error.
Here is error output after running “v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw --verbose”
[ 825.502902] imx390 9-001a: imx390_start_streaming.
[ 825.538048] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 16384
[ 825.575496] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 825.613177] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
Here is output from “v4l2-ctl --all”
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, imx390 9-001a
Bus info : platform:15c10000.vi:0
Driver version: 4.9.201
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: ok)
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : ‘RG12’
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Camera Controls
                 group_hold 0x009a2003 (bool)   : default=0 value=0 flags=execute-on-write
                sensor_mode 0x009a2008 (int64)  : min=0 max=0 step=0 default=0 value=0 flags=slider
                       gain 0x009a2009 (int64)  : min=0 max=0 step=0 default=0 value=0 flags=slider
                   exposure 0x009a200a (int64)  : min=0 max=0 step=0 default=0 value=59 flags=slider
                 frame_rate 0x009a200b (int64)  : min=0 max=0 step=0 default=0 value=30000000 flags=slider
       sensor_configuration 0x009a2032 (u32)    : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
     sensor_mode_i2c_packet 0x009a2033 (u32)    : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
  sensor_control_i2c_packet 0x009a2034 (u32)    : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
                bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
            override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
               height_align 0x009a2066 (int)    : min=1 max=16 step=1 default=1 value=1
                 size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
           write_isp_format 0x009a2068 (int)    : min=1 max=1 step=1 default=1 value=1
   sensor_signal_properties 0x009a2069 (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
    sensor_image_properties 0x009a206a (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
  sensor_control_properties 0x009a206b (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
          sensor_dv_timings 0x009a206c (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
           low_latency_mode 0x009a206d (bool)   : default=0 value=0
           preferred_stride 0x009a206e (int)    : min=0 max=65535 step=1 default=0 value=0
               sensor_modes 0x009a2082 (int)    : min=0 max=30 step=1 default=30 value=1 flags=read-only
Here is output from trace:
tracer: nop
entries-in-buffer/entries-written: 19/19 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
    v4l2-ctl-8793  [001] ....   825.373444: tegra_channel_open: vi-output, imx390 9-001a
    v4l2-ctl-8793  [000] ....   825.375966: tegra_channel_set_power: imx390 9-001a : 0x1
    v4l2-ctl-8793  [000] ....   825.375979: camera_common_s_power: status : 0x1
    v4l2-ctl-8793  [000] ....   825.484140: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
    v4l2-ctl-8793  [000] ....   825.484148: csi_s_power: enable : 0x1
    v4l2-ctl-8793  [000] ....   825.493774: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
    v4l2-ctl-8793  [002] ....   825.498174: tegra_channel_set_stream: enable : 0x1
    v4l2-ctl-8793  [000] ....   825.502561: tegra_channel_set_stream: 15a00000.nvcsi--2 : 0x1
    v4l2-ctl-8793  [000] ....   825.502567: csi_s_stream: enable : 0x1
    v4l2-ctl-8793  [000] ....   825.502577: tegra_channel_set_stream: imx390 9-001a : 0x1
    v4l2-ctl-8793  [000] ....   830.071815: tegra_channel_close: vi-output, imx390 9-001a
    v4l2-ctl-8793  [003] ....   830.075767: tegra_channel_set_stream: enable : 0x0
    v4l2-ctl-8793  [003] ....   830.075773: tegra_channel_set_stream: imx390 9-001a : 0x0
    v4l2-ctl-8793  [003] ....   830.087958: tegra_channel_set_stream: 15a00000.nvcsi--2 : 0x0
    v4l2-ctl-8793  [003] ....   830.087965: csi_s_stream: enable : 0x0
    v4l2-ctl-8793  [000] ....   830.094186: tegra_channel_set_power: imx390 9-001a : 0x0
    v4l2-ctl-8793  [000] ....   830.094200: camera_common_s_power: status : 0x0
    v4l2-ctl-8793  [000] ....   830.094535: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
    v4l2-ctl-8793  [000] ....   830.094538: csi_s_power: enable : 0x0
Please help to advise where is the issue.
Thanks in advance.
Hal.
Did you confirm with vendor for the 2 lane initial i2c REG table?
And looks like didn’t enable the trace log.
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
hi ShaneCCC,
Thanks for your reply.
I got an example code to initial IMX390 register as 2 lane output, but not sure if it is correct or not.
In Sony’s IMX390 application document, it doesn’t show which register to set to switch between 2lane and 4lane.
If you have any advice about this, it will be greatly appreciated.
As Xavier NX only has 2 lane CSI input, I do need to use 2lane format.
For your suggestion about trace log, here is output after run
$ v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG12 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=imx390.raw -d /dev/video0
tracer: nop
entries-in-buffer/entries-written: 1016/1016 #P:4
_-----=> irqs-off
||| / delay
    v4l2-ctl-9546  [000] ....   418.393347: tegra_channel_open: vi-output, imx390 9-001a
    v4l2-ctl-9546  [001] ....   418.395948: tegra_channel_set_power: imx390 9-001a : 0x1
    v4l2-ctl-9546  [001] ....   418.395962: camera_common_s_power: status : 0x1
    v4l2-ctl-9546  [001] ....   418.502230: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
    v4l2-ctl-9546  [001] ....   418.502238: csi_s_power: enable : 0x1
    v4l2-ctl-9546  [000] ....   418.510529: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
    v4l2-ctl-9546  [000] ....   418.516786: tegra_channel_set_stream: enable : 0x1
    v4l2-ctl-9546  [000] ....   418.519434: tegra_channel_set_stream: 15a00000.nvcsi--2 : 0x1
    v4l2-ctl-9546  [000] ....   418.519438: csi_s_stream: enable : 0x1
    v4l2-ctl-9546  [000] ....   418.519446: tegra_channel_set_stream: imx390 9-001a : 0x1
 kworker/0:4-1899  [000] ....   418.538254: rtos_queue_peek_from_isr_failed: tstamp:13492311209 queue:0x0bcbcf78
 kworker/0:4-1899  [000] ....   418.538260: rtcpu_start: tstamp:13492313544
 kworker/0:4-1899  [000] ....   418.538262: rtos_queue_send_from_isr_failed: tstamp:13492328753 queue:0x0bcb41f8
 kworker/0:4-1899  [000] ....   418.538263: rtos_queue_send_from_isr_failed: tstamp:13492328905 queue:0x0bcb8a60
 kworker/0:4-1899  [000] ....   418.538263: rtos_queue_send_from_isr_failed: tstamp:13492329055 queue:0x0bcba5e0
 kworker/0:4-1899  [000] ....   418.538264: rtos_queue_send_from_isr_failed: tstamp:13492329203 queue:0x0bcbb3a0
 kworker/0:4-1899  [000] ....   418.538265: rtos_queue_send_from_isr_failed: tstamp:13492329350 queue:0x0bcbc160
 kworker/0:4-1899  [000] ....   418.538266: rtcpu_string: tstamp:13492329794 id:0x04010000 str:"Configuring VI GoS.
kworker/0:4-1899 [000] … 418.538278: rtcpu_string: tstamp:13492329972 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:4-1899 [000] … 418.538284: rtcpu_string: tstamp:13492330229 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:4-1899 [000] … 418.538288: rtcpu_string: tstamp:13492330500 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:4-1899 [000] … 418.538293: rtcpu_string: tstamp:13492330732 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:4-1899 [000] … 418.538298: rtcpu_string: tstamp:13492330964 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:4-1899 [000] … 418.538302: rtcpu_string: tstamp:13492331197 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:4-1899 [000] … 418.538335: rtcpu_string: tstamp:13492339574 id:0x04010000 str:“vi5_hwinit: firmware CL2018101701 protocol vers”
kworker/0:4-1899 [000] … 418.538338: rtcpu_string: tstamp:13492339706 id:0x04010000 str:"on 2.2
kworker/0:4-1899 [000] … 418.538344: rtos_queue_send_from_isr_failed: tstamp:13492353942 queue:0x0bcb41f8
kworker/0:4-1899 [000] … 418.538344: rtos_queue_send_from_isr_failed: tstamp:13492354112 queue:0x0bcb8a60
kworker/0:4-1899 [000] … 418.538345: rtos_queue_send_from_isr_failed: tstamp:13492354269 queue:0x0bcba5e0
kworker/0:4-1899 [000] … 418.538346: rtos_queue_send_from_isr_failed: tstamp:13492354416 queue:0x0bcbb3a0
kworker/0:4-1899 [000] … 418.538346: rtos_queue_send_from_isr_failed: tstamp:13492354562 queue:0x0bcbc160
kworker/0:4-1899 [000] … 418.538347: rtcpu_string: tstamp:13492355445 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:4-1899 [000] … 418.538352: rtos_queue_send_from_isr_failed: tstamp:13492441519 queue:0x0bcb41f8
kworker/0:4-1899 [000] … 418.538353: rtos_queue_send_from_isr_failed: tstamp:13492441668 queue:0x0bcb8a60
kworker/0:4-1899 [000] … 418.538353: rtos_queue_send_from_isr_failed: tstamp:13492441821 queue:0x0bcba5e0
kworker/0:4-1899 [000] … 418.538354: rtos_queue_send_from_isr_failed: tstamp:13492441966 queue:0x0bcbb3a0
kworker/0:4-1899 [000] … 418.538354: rtos_queue_send_from_isr_failed: tstamp:13492442112 queue:0x0bcbc160
kworker/0:4-1899 [000] … 418.538356: rtcpu_vinotify_error: tstamp:13492450759 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:13492447901
kworker/0:4-1899 [000] … 418.538357: rtos_queue_send_from_isr_failed: tstamp:13492613827 queue:0x0bcb41f8
kworker/0:4-1899 [000] … 418.538358: rtos_queue_send_from_isr_failed: tstamp:13492613980 queue:0x0bcb8a60
kworker/0:4-1899 [000] … 418.538358: rtos_queue_send_from_isr_failed: tstamp:13492614132 queue:0x0bcba5e0
kworker/0:4-1899 [000] … 418.538359: rtos_queue_send_from_isr_failed: tstamp:13492614278 queue:0x0bcbb3a0
kworker/0:4-1899 [000] … 418.538359: rtos_queue_send_from_isr_failed: tstamp:13492614426 queue:0x0bcbc160
kworker/0:4-1899 [000] … 418.538360: rtcpu_vinotify_event: tstamp:13492857398 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15143586656 0
kworker/0:4-1899 [000] … 418.538363: rtcpu_vinotify_event: tstamp:13492857543 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15143594976 1
kworker/0:4-1899 [000] … 418.538363: rtcpu_vinotify_event: tstamp:13492857704 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15143597120 1
kworker/0:4-1899 [000] … 418.538364: rtcpu_vinotify_event: tstamp:13492857840 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15143631008 0
kworker/0:4-1899 [000] … 418.538365: rtcpu_vinotify_event: tstamp:13492857997 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15143639424 2
kworker/0:4-1899 [000] … 418.538365: rtcpu_vinotify_event: tstamp:13492858141 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:13492447901
kworker/0:4-1899 [000] … 418.538366: rtcpu_vinotify_event: tstamp:13492858299 tag:FS channel:0x00 frame:249 vi_tstamp:13492598988 data:0x0
kworker/0:4-1899 [000] … 418.538366: rtcpu_vinotify_event: tstamp:13492858439 tag:ATOMP_FS channel:0x00 frame:249 vi_tstamp:13492598991 d0
kworker/0:4-1899 [000] … 418.538367: rtcpu_vinotify_event: tstamp:13492858596 tag:CHANSEL_FAULT channel:0x23 frame:249 vi_tstamp:134925994
kworker/0:4-1899 [000] … 418.538368: rtcpu_vinotify_event: tstamp:13492858731 tag:RESERVED_19 channel:0x23 frame:249 vi_tstamp:15151379841
kworker/0:4-1899 [000] … 418.538369: rtcpu_vinotify_event: tstamp:13492858885 tag:CHANSEL_NOMATCH channel:0x01 frame:249 vi_tstamp:1349269
kworker/0:4-1899 [000] … 418.538369: rtcpu_vinotify_event: tstamp:13492859022 tag:CHANSEL_FAULT channel:0x23 frame:249 vi_tstamp:134926131
kworker/0:4-1899 [000] … 418.538370: rtcpu_vinotify_event: tstamp:13492859180 tag:RESERVED_19 channel:0x23 frame:249 vi_tstamp:15151813181
kworker/0:4-1899 [000] … 418.594222: rtcpu_vinotify_event: tstamp:13493741388 tag:CHANSEL_FAULT channel:0x23 frame:249 vi_tstamp:134937382
kworker/0:4-1899 [000] … 418.594225: rtcpu_vinotify_event: tstamp:13493741550 tag:RESERVED_19 channel:0x23 frame:249 vi_tstamp:15187809151
kworker/0:4-1899 [000] … 418.594226: rtcpu_vinotify_event: tstamp:13493741689 tag:ATOMP_FRAME_DONE channel:0x23 frame:249 vi_tstamp:134930
kworker/0:4-1899 [000] … 418.594228: rtos_queue_send_from_isr_failed: tstamp:13493786498 queue:0x0bcb41f8
kworker/0:4-1899 [000] … 418.594229: rtos_queue_send_from_isr_failed: tstamp:13493786668 queue:0x0bcb8a60
kworker/0:4-1899 [000] … 418.594230: rtos_queue_send_from_isr_failed: tstamp:13493786821 queue:0x0bcba5e0
kworker/0:4-1899 [000] … 418.594231: rtos_queue_send_from_isr_failed: tstamp:13493786969 queue:0x0bcbb3a0
kworker/0:4-1899 [000] … 418.594232: rtos_queue_send_from_isr_failed: tstamp:13493787117 queue:0x0bcbc160
(repeat similar message …]
Thanks,
hal.
Lost copy the data information. Have reference to below like to check the CHANSEL_FAULT error.
https://elinux.org/Jetson_TX2_Camera_BringUp
hi ShaneCCC,
Sorry for lost data info in last post. Here is updated log:
I have a look at the above link. It is for TX2. From the log, I saw some CHANSEL_FAULT, but not sure what is exactly it related to my design. Any suggestions?
tracer: nop
entries-in-buffer/entries-written: 765/765 #P:4
_-----=> irqs-off
||| / delay
    v4l2-ctl-9830  [000] ....  1453.509497: tegra_channel_open: vi-output, imx390 9-001a
    v4l2-ctl-9830  [000] ....  1453.510801: tegra_channel_set_power: imx390 9-001a : 0x1
    v4l2-ctl-9830  [000] ....  1453.510811: camera_common_s_power: status : 0x1
    v4l2-ctl-9830  [000] ....  1453.619245: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
    v4l2-ctl-9830  [000] ....  1453.619253: csi_s_power: enable : 0x1
    v4l2-ctl-9830  [000] ....  1453.628256: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
    v4l2-ctl-9830  [003] ....  1453.634299: tegra_channel_set_stream: enable : 0x1
    v4l2-ctl-9830  [000] ....  1453.636858: tegra_channel_set_stream: 15a00000.nvcsi--2 : 0x1
    v4l2-ctl-9830  [000] ....  1453.636862: csi_s_stream: enable : 0x1
    v4l2-ctl-9830  [000] ....  1453.636871: tegra_channel_set_stream: imx390 9-001a : 0x1
 kworker/0:2-9731  [000] ....  1453.683233: rtos_queue_peek_from_isr_failed: tstamp:45840404286 queue:0x0bcbcf78
 kworker/0:2-9731  [000] ....  1453.683239: rtcpu_start: tstamp:45840406956
 kworker/0:2-9731  [000] ....  1453.683242: rtos_queue_send_from_isr_failed: tstamp:45840423297 queue:0x0bcb41f8
 kworker/0:2-9731  [000] ....  1453.683243: rtos_queue_send_from_isr_failed: tstamp:45840423449 queue:0x0bcb8a60
 kworker/0:2-9731  [000] ....  1453.683244: rtos_queue_send_from_isr_failed: tstamp:45840423599 queue:0x0bcba5e0
 kworker/0:2-9731  [000] ....  1453.683246: rtos_queue_send_from_isr_failed: tstamp:45840423746 queue:0x0bcbb3a0
 kworker/0:2-9731  [000] ....  1453.683247: rtos_queue_send_from_isr_failed: tstamp:45840423892 queue:0x0bcbc160
 kworker/0:2-9731  [000] ....  1453.683249: rtcpu_string: tstamp:45840424342 id:0x04010000 str:"Configuring VI GoS.
kworker/0:2-9731 [000] … 1453.683286: rtcpu_string: tstamp:45840424520 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:2-9731 [000] … 1453.683300: rtcpu_string: tstamp:45840424793 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:2-9731 [000] … 1453.683313: rtcpu_string: tstamp:45840425066 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:2-9731 [000] … 1453.683325: rtcpu_string: tstamp:45840425299 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:2-9731 [000] … 1453.683337: rtcpu_string: tstamp:45840425531 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:2-9731 [000] … 1453.683349: rtcpu_string: tstamp:45840425763 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:2-9731 [000] … 1453.683361: rtcpu_string: tstamp:45840434480 id:0x04010000 str:“vi5_hwinit: firmware CL2018101701 protocol vers”
kworker/0:2-9731 [000] … 1453.683364: rtcpu_string: tstamp:45840434599 id:0x04010000 str:"on 2.2
kworker/0:2-9731 [000] … 1453.683377: rtos_queue_send_from_isr_failed: tstamp:45840450177 queue:0x0bcb41f8
kworker/0:2-9731 [000] … 1453.683378: rtos_queue_send_from_isr_failed: tstamp:45840450347 queue:0x0bcb8a60
kworker/0:2-9731 [000] … 1453.683380: rtos_queue_send_from_isr_failed: tstamp:45840450505 queue:0x0bcba5e0
kworker/0:2-9731 [000] … 1453.683381: rtos_queue_send_from_isr_failed: tstamp:45840450652 queue:0x0bcbb3a0
kworker/0:2-9731 [000] … 1453.683382: rtos_queue_send_from_isr_failed: tstamp:45840450797 queue:0x0bcbc160
kworker/0:2-9731 [000] … 1453.683383: rtcpu_string: tstamp:45840451662 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:2-9731 [000] … 1453.683397: rtos_queue_send_from_isr_failed: tstamp:45840533274 queue:0x0bcb41f8
kworker/0:2-9731 [000] … 1453.683398: rtos_queue_send_from_isr_failed: tstamp:45840533424 queue:0x0bcb8a60
kworker/0:2-9731 [000] … 1453.683399: rtos_queue_send_from_isr_failed: tstamp:45840533577 queue:0x0bcba5e0
kworker/0:2-9731 [000] … 1453.683400: rtos_queue_send_from_isr_failed: tstamp:45840533724 queue:0x0bcbb3a0
kworker/0:2-9731 [000] … 1453.683402: rtos_queue_send_from_isr_failed: tstamp:45840533870 queue:0x0bcbc160
kworker/0:2-9731 [000] … 1453.683404: rtcpu_vinotify_error: tstamp:45840542917 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:45840540068 data:0x00000001
kworker/0:2-9731 [000] … 1453.683406: rtcpu_vinotify_event: tstamp:45840941377 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45260314304 data:0x10000000
kworker/0:2-9731 [000] … 1453.683408: rtcpu_vinotify_event: tstamp:45840941522 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45260322592 data:0x31000001
kworker/0:2-9731 [000] … 1453.683409: rtcpu_vinotify_event: tstamp:45840941680 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:45260324800 data:0x07020001
kworker/0:2-9731 [000] … 1453.683410: rtcpu_vinotify_event: tstamp:45840941816 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45260359008 data:0x10000000
kworker/0:2-9731 [000] … 1453.683411: rtcpu_vinotify_event: tstamp:45840941973 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45260367456 data:0x31000002
kworker/0:2-9731 [000] … 1453.683412: rtcpu_vinotify_event: tstamp:45840942117 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:45840540068 data:0x00000001
kworker/0:2-9731 [000] … 1453.683414: rtos_queue_send_from_isr_failed: tstamp:45841064548 queue:0x0bcb41f8
kworker/0:2-9731 [000] … 1453.683415: rtos_queue_send_from_isr_failed: tstamp:45841064704 queue:0x0bcb8a60
kworker/0:2-9731 [000] … 1453.683416: rtos_queue_send_from_isr_failed: tstamp:45841064857 queue:0x0bcba5e0
kworker/0:2-9731 [000] … 1453.683417: rtos_queue_send_from_isr_failed: tstamp:45841065002 queue:0x0bcbb3a0
kworker/0:2-9731 [000] … 1453.683418: rtos_queue_send_from_isr_failed: tstamp:45841065147 queue:0x0bcbc160
kworker/0:2-9731 [000] … 1453.683419: rtcpu_vinotify_event: tstamp:45841484135 tag:FS channel:0x00 frame:76 vi_tstamp:45841048440 data:0x00000010
kworker/0:2-9731 [000] … 1453.683421: rtcpu_vinotify_event: tstamp:45841484281 tag:ATOMP_FS channel:0x00 frame:76 vi_tstamp:45841048444 data:0x00000000
kworker/0:2-9731 [000] … 1453.683422: rtcpu_vinotify_event: tstamp:45841484443 tag:CHANSEL_FAULT channel:0x23 frame:76 vi_tstamp:45841049443 data:0x00004004
kworker/0:2-9731 [000] … 1453.683423: rtcpu_vinotify_event: tstamp:45841484583 tag:RESERVED_19 channel:0x23 frame:76 vi_tstamp:45279415040 data:0x01020001
kworker/0:2-9731 [000] … 1453.683424: rtcpu_vinotify_event: tstamp:45841484742 tag:CHANSEL_NOMATCH channel:0x01 frame:76 vi_tstamp:45841052567 data:0x000006e9
kworker/0:2-9731 [000] … 1453.683425: rtcpu_vinotify_event: tstamp:45841484879 tag:CHANSEL_FAULT channel:0x23 frame:76 vi_tstamp:45841062985 data:0x00004001
kworker/0:2-9731 [000] … 1453.683426: rtcpu_vinotify_event: tstamp:45841485036 tag:RESERVED_19 channel:0x23 frame:76 vi_tstamp:45279848384 data:0x01020001
kworker/0:2-9731 [000] … 1453.739239: rtcpu_vinotify_event: tstamp:45842190841 tag:CHANSEL_FAULT channel:0x23 frame:76 vi_tstamp:45842187848 data:0x04374182
kworker/0:2-9731 [000] … 1453.739243: rtcpu_vinotify_event: tstamp:45842191003 tag:RESERVED_19 channel:0x23 frame:76 vi_tstamp:45315844320 data:0x01020001
kworker/0:2-9731 [000] … 1453.739245: rtcpu_vinotify_event: tstamp:45842191143 tag:ATOMP_FRAME_DONE channel:0x23 frame:76 vi_tstamp:45842187876 data:0x00000000
kworker/0:2-9731 [000] … 1453.739246: rtcpu_vinotify_event: tstamp:45842237391 tag:RESERVED_19 channel:0x23 frame:76 vi_tstamp:45315855136 data:0x02020001
kworker/0:2-9731 [000] … 1453.739247: rtcpu_vinotify_event: tstamp:45842238274 tag:CHANSEL_FAULT channel:0x23 frame:76 vi_tstamp:45842187985 data:0x043841c0
kworker/0:2-9731 [000] … 1453.739249: rtos_queue_send_from_isr_failed: tstamp:45842237624 queue:0x0bcb41f8
kworker/0:2-9731 [000] … 1453.739251: rtos_queue_send_from_isr_failed: tstamp:45842237765 queue:0x0bcb8a60
kworker/0:2-9731 [000] … 1453.739252: rtos_queue_send_from_isr_failed: tstamp:45842237903 queue:0x0bcba5e0
kworker/0:2-9731 [000] … 1453.739254: rtos_queue_send_from_isr_failed: tstamp:45842238035 queue:0x0bcbb3a0
kworker/0:2-9731 [000] … 1453.739255: rtos_queue_send_from_isr_failed: tstamp:45842238166 queue:0x0bcbc160
kworker/0:2-9731 [000] … 1453.739256: rtcpu_vinotify_event: tstamp:45842238446 tag:RESERVED_19 channel:0x23 frame:76 vi_tstamp:45315864416 data:0x01020001
kworker/0:2-9731 [000] … 1453.739257: rtcpu_vinotify_event: tstamp:45842238586 tag:FE channel:0x00 frame:76 vi_tstamp:45842209836 data:0x00000020
kworker/0:2-9731 [000] … 1453.739258: rtcpu_vinotify_event: tstamp:45842238746 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:76 vi_tstamp:45842209837 data:0x00000000
kworker/0:2-9731 [000] … 1453.739259: rtcpu_vinotify_event: tstamp:45842238882 tag:RESERVED_19 channel:0x23 frame:76 vi_tstamp:45316559264 data:0x01020001
kworker/0:2-9731 [000] … 1453.739261: rtcpu_vinotify_event: tstamp:45842239040 tag:ATOMP_FE channel:0x00 frame:76 vi_tstamp:45842209839 data:0x00000000
kworker/0:2-9731 [000] … 1453.739262: rtcpu_vinotify_event: tstamp:45842239175 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:45316574048 data:0x07020002
kworker/0:2-9731 [000] … 1453.739263: rtcpu_vinotify_event: tstamp:45842239332 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45316637376 data:0x10000000
kworker/0:2-9731 [000] … 1453.739264: rtcpu_vinotify_event: tstamp:45842239465 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45316668576 data:0x31000003
kworker/0:2-9731 [000] … 1453.739265: rtcpu_vinotify_event: tstamp:45842239622 tag:FS channel:0x00 frame:77 vi_tstamp:45842220316 data:0x00000010
kworker/0:2-9731 [000] … 1453.739266: rtcpu_vinotify_event: tstamp:45842239761 tag:ATOMP_FS channel:0x00 frame:77 vi_tstamp:45842220319 data:0x00000000
kworker/0:2-9731 [000] … 1453.739268: rtcpu_vinotify_event: tstamp:45842239918 tag:CHANSEL_FAULT channel:0x23 frame:77 vi_tstamp:45842221317 data:0x00004004
kworker/0:2-9731 [000] … 1453.739269: rtcpu_vinotify_event: tstamp:45842240053 tag:RESERVED_19 channel:0x23 frame:77 vi_tstamp:45316915008 data:0x01020002
kworker/0:2-9731 [000] … 1453.739270: rtcpu_vinotify_event: tstamp:45842240207 tag:CHANSEL_NOMATCH channel:0x01 frame:77 vi_tstamp:45842224443 data:0x000006e9
kworker/0:2-9731 [000] … 1453.739271: rtcpu_vinotify_event: tstamp:45842240342 tag:CHANSEL_FAULT channel:0x23 frame:77 vi_tstamp:45842234860 data:0x00004001
kworker/0:2-9731 [000] … 1453.739272: rtcpu_vinotify_event: tstamp:45842731916 tag:RESERVED_19 channel:0x23 frame:77 vi_tstamp:45317354304 data:0x01020002
kworker/0:2-9731 [000] … 1453.739273: rtcpu_vinotify_event: tstamp:45843399521 tag:CHANSEL_FAULT channel:0x23 frame:77 vi_tstamp:45843359723 data:0x04374182
kworker/0:2-9731 [000] … 1453.739275: rtcpu_vinotify_event: tstamp:45843399683 tag:RESERVED_19 channel:0x23 frame:77 vi_tstamp:45353344352 data:0x01020002
kworker/0:2-9731 [000] … 1453.739276: rtcpu_vinotify_event: tstamp:45843399822 tag:ATOMP_FRAME_DONE channel:0x23 frame:77 vi_tstamp:45843359751 data:0x00000000
kworker/0:2-9731 [000] … 1453.739277: rtcpu_vinotify_event: tstamp:45843399978 tag:RESERVED_19 channel:0x23 frame:77 vi_tstamp:45353349248 data:0x02020002
kworker/0:2-9731 [000] … 1453.739278: rtcpu_vinotify_event: tstamp:45843400115 tag:CHANSEL_FAULT channel:0x23 frame:77 vi_tstamp:45843359860 data:0x043841c0
kworker/0:2-9731 [000] … 1453.739279: rtcpu_vinotify_event: tstamp:45843400269 tag:RESERVED_19 channel:0x23 frame:77 vi_tstamp:45353358496 data:0x01020002
kworker/0:2-9731 [000] … 1453.739280: rtcpu_vinotify_event: tstamp:45843400404 tag:FE channel:0x00 frame:77 vi_tstamp:45843381711 data:0x00000020
kworker/0:2-9731 [000] … 1453.739282: rtcpu_vinotify_event: tstamp:45843400566 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:77 vi_tstamp:45843381711 data:0x00000000
kworker/0:2-9731 [000] … 1453.739312: rtcpu_vinotify_event: tstamp:45843400701 tag:RESERVED_19 channel:0x23 frame:77 vi_tstamp:45354059264 data:0x01020002
kworker/0:2-9731 [000] … 1453.739313: rtcpu_vinotify_event: tstamp:45843400862 tag:ATOMP_FE channel:0x00 frame:77 vi_tstamp:45843381714 data:0x00000000
kworker/0:2-9731 [000] … 1453.739314: rtcpu_vinotify_event: tstamp:45843400997 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:45354074048 data:0x07020003
kworker/0:2-9731 [000] … 1453.739316: rtcpu_vinotify_event: tstamp:45843401155 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45354133344 data:0x10000000
kworker/0:2-9731 [000] … 1453.739317: rtcpu_vinotify_event: tstamp:45843401290 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45354163072 data:0x31000004
kworker/0:2-9731 [000] … 1453.739318: rtcpu_vinotify_event: tstamp:45843401448 tag:FS channel:0x00 frame:78 vi_tstamp:45843392190 data:0x00000010
kworker/0:2-9731 [000] … 1453.739319: rtcpu_vinotify_event: tstamp:45843401588 tag:ATOMP_FS channel:0x00 frame:78 vi_tstamp:45843392193 data:0x00000000
kworker/0:2-9731 [000] … 1453.739320: rtos_queue_send_from_isr_failed: tstamp:45843412711 queue:0x0bcb41f8
kworker/0:2-9731 [000] … 1453.739322: rtos_queue_send_from_isr_failed: tstamp:45843412881 queue:0x0bcb8a60
kworker/0:2-9731 [000] … 1453.739323: rtos_queue_send_from_isr_failed: tstamp:45843413035 queue:0x0bcba5e0
kworker/0:2-9731 [000] … 1453.739325: rtos_queue_send_from_isr_failed: tstamp:45843413182 queue:0x0bcbb3a0
kworker/0:2-9731 [000] … 1453.739326: rtos_queue_send_from_isr_failed: tstamp:45843413328 queue:0x0bcbc160
kworker/0:2-9731 [000] … 1453.795221: rtcpu_vinotify_event: tstamp:45843925216 tag:CHANSEL_FAULT channel:0x23 frame:78 vi_tstamp:45843393193 data:0x00004004
kworker/0:2-9731 [000] … 1453.795226: rtcpu_vinotify_event: tstamp:45843925378 tag:RESERVED_19 channel:0x23 frame:78 vi_tstamp:45354437280 data:0x01020003
kworker/0:2-9731 [000] … 1453.795227: rtcpu_vinotify_event: tstamp:45843925540 tag:CHANSEL_NOMATCH channel:0x01 frame:78 vi_tstamp:45843396317 data:0x000006e9
kworker/0:2-9731 [000] … 1453.795228: rtcpu_vinotify_event: tstamp:45843925679 tag:CHANSEL_FAULT channel:0x23 frame:78 vi_tstamp:45843406736 data:0x00004001
kworker/0:2-9731 [000] … 1453.795229: rtcpu_vinotify_event: tstamp:45843925837 tag:RESERVED_19 channel:0x23 frame:78 vi_tstamp:45354848512 data:0x01020003
kworker/0:2-9731 [000] … 1453.795230: rtcpu_vinotify_event: tstamp:45844557008 tag:CHANSEL_FAULT channel:0x23 frame:78 vi_tstamp:45844531598 data:0x04374182
kworker/0:2-9731 [000] … 1453.795232: rtcpu_vinotify_event: tstamp:45844557172 tag:RESERVED_19 channel:0x23 frame:78 vi_tstamp:45390844384 data:0x01020003
kworker/0:2-9731 [000] … 1453.795233: rtcpu_vinotify_event: tstamp:45844557313 tag:ATOMP_FRAME_DONE channel:0x23 frame:78 vi_tstamp:45844531626 data:0x00000000
kworker/0:2-9731 [000] … 1453.795234: rtcpu_vinotify_event: tstamp:45844557471 tag:RESERVED_19 channel:0x23 frame:78 vi_tstamp:45390849248 data:0x02020003
kworker/0:2-9731 [000] … 1453.795235: rtcpu_vinotify_event: tstamp:45844557607 tag:CHANSEL_FAULT channel:0x23 frame:78 vi_tstamp:45844531735 data:0x043841c0
kworker/0:2-9731 [000] … 1453.795236: rtcpu_vinotify_event: tstamp:45844557764 tag:RESERVED_19 channel:0x23 frame:78 vi_tstamp:45390858496 data:0x01020003
kworker/0:2-9731 [000] … 1453.795269: rtcpu_vinotify_event: tstamp:45844557903 tag:FE channel:0x00 frame:78 vi_tstamp:45844553586 data:0x00000020
kworker/0:2-9731 [000] … 1453.795271: rtcpu_vinotify_event: tstamp:45844558061 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:78 vi_tstamp:45844553587 data:0x00000000
kworker/0:2-9731 [000] … 1453.795272: rtcpu_vinotify_event: tstamp:45844558197 tag:RESERVED_19 channel:0x23 frame:78 vi_tstamp:45391559264 data:0x01020003
kworker/0:2-9731 [000] … 1453.795273: rtcpu_vinotify_event: tstamp:45844558359 tag:ATOMP_FE channel:0x00 frame:78 vi_tstamp:45844553589 data:0x00000000
kworker/0:2-9731 [000] … 1453.795274: rtcpu_vinotify_event: tstamp:45844558496 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:45391574048 data:0x07020004
kworker/0:2-9731 [000] … 1453.795276: rtos_queue_send_from_isr_failed: tstamp:45844580229 queue:0x0bcb41f8
kworker/0:2-9731 [000] … 1453.795278: rtos_queue_send_from_isr_failed: tstamp:45844580383 queue:0x0bcb8a60
kworker/0:2-9731 [000] … 1453.795279: rtos_queue_send_from_isr_failed: tstamp:45844580535 queue:0x0bcba5e0
kworker/0:2-9731 [000] … 1453.795280: rtos_queue_send_from_isr_failed: tstamp:45844580683 queue:0x0bcbb3a0
kworker/0:2-9731 [000] … 1453.795281: rtos_queue_send_from_isr_failed: tstamp:45844580828 queue:0x0bcbc160
kworker/0:2-9731 [000] … 1453.795283: rtcpu_vinotify_event: tstamp:45845064589 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45391682688 data:0x10000000
kworker/0:2-9731 [000] … 1453.795284: rtcpu_vinotify_event: tstamp:45845064731 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45391712416 data:0x31000005
kworker/0:2-9731 [000] … 1453.795285: rtcpu_vinotify_event: tstamp:45845064897 tag:FS channel:0x00 frame:79 vi_tstamp:45844564066 data:0x00000010
kworker/0:2-9731 [000] … 1453.795308: rtcpu_vinotify_event: tstamp:45845065040 tag:ATOMP_FS channel:0x00 frame:79 vi_tstamp:45844564069 data:0x00000000
kworker/0:2-9731 [000] … 1453.795309: rtcpu_vinotify_event: tstamp:45845065198 tag:CHANSEL_FAULT channel:0x23 frame:79 vi_tstamp:45844565067 data:0x00004004
kworker/0:2-9731 [000] … 1453.795311: rtcpu_vinotify_event: tstamp:45845065334 tag:RESERVED_19 channel:0x23 frame:79 vi_tstamp:45391915008 data:0x01020004
kworker/0:2-9731 [000] … 1453.795312: rtcpu_vinotify_event: tstamp:45845065491 tag:CHANSEL_NOMATCH channel:0x01 frame:79 vi_tstamp:45844568193 data:0x000006e9
kworker/0:2-9731 [000] … 1453.795313: rtcpu_vinotify_event: tstamp:45845065626 tag:CHANSEL_FAULT channel:0x23 frame:79 vi_tstamp:45844578610 data:0x00004001
kworker/0:2-9731 [000] … 1453.795314: rtcpu_vinotify_event: tstamp:45845065782 tag:RESERVED_19 channel:0x23 frame:79 vi_tstamp:45392348384 data:0x01020004
kworker/0:2-9731 [000] … 1453.795316: rtos_queue_peek_from_isr_failed: tstamp:45845404661 queue:0x0bcbcf78
kworker/0:2-9731 [000] … 1453.851243: rtcpu_vinotify_event: tstamp:45845728882 tag:CHANSEL_FAULT channel:0x23 frame:79 vi_tstamp:45845703473 data:0x04374182
kworker/0:2-9731 [000] … 1453.851247: rtcpu_vinotify_event: tstamp:45845729050 tag:RESERVED_19 channel:0x23 frame:79 vi_tstamp:45428344384 data:0x01020004
kworker/0:2-9731 [000] … 1453.851249: rtcpu_vinotify_event: tstamp:45845729193 tag:ATOMP_FRAME_DONE channel:0x23 frame:79 vi_tstamp:45845703501 data:0x00000000
kworker/0:2-9731 [000] … 1453.851250: rtcpu_vinotify_event: tstamp:45845729351 tag:RESERVED_19 channel:0x23 frame:79 vi_tstamp:45428349248 data:0x02020004
kworker/0:2-9731 [000] … 1453.851251: rtcpu_vinotify_event: tstamp:45845729486 tag:CHANSEL_FAULT channel:0x23 frame:79 vi_tstamp:45845703610 data:0x043841c0
kworker/0:2-9731 [000] … 1453.851252: rtcpu_vinotify_event: tstamp:45845729643 tag:RESERVED_19 channel:0x23 frame:79 vi_tstamp:45428358528 data:0x01020004
kworker/0:2-9731 [000] … 1453.851253: rtcpu_vinotify_event: tstamp:45845729778 tag:FE channel:0x00 frame:79 vi_tstamp:45845725460 data:0x00000020
kworker/0:2-9731 [000] … 1453.851255: rtos_queue_send_from_isr_failed: tstamp:45845752627 queue:0x0bcb41f8
kworker/0:2-9731 [000] … 1453.851257: rtos_queue_send_from_isr_failed: tstamp:45845752781 queue:0x0bcb8a60
kworker/0:2-9731 [000] … 1453.851258: rtos_queue_send_from_isr_failed: tstamp:45845752933 queue:0x0bcba5e0
kworker/0:2-9731 [000] … 1453.851260: rtos_queue_send_from_isr_failed: tstamp:45845753079 queue:0x0bcbb3a0
kworker/0:2-9731 [000] … 1453.851261: rtos_queue_send_from_isr_failed: tstamp:45845753223 queue:0x0bcbc160
kworker/0:2-9731 [000] … 1453.851262: rtcpu_vinotify_event: tstamp:45846257952 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:79 vi_tstamp:45845725461 data:0x00000000
kworker/0:2-9731 [000] … 1453.851294: rtcpu_vinotify_event: tstamp:45846258095 tag:RESERVED_19 channel:0x23 frame:79 vi_tstamp:45429065152 data:0x01020004
kworker/0:2-9731 [000] … 1453.851295: rtcpu_vinotify_event: tstamp:45846258258 tag:ATOMP_FE channel:0x00 frame:79 vi_tstamp:45845725464 data:0x00000000
kworker/0:2-9731 [000] … 1453.851297: rtcpu_vinotify_event: tstamp:45846258396 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:45429079904 data:0x07020005
kworker/0:2-9731 [000] … 1453.851298: rtcpu_vinotify_event: tstamp:45846258555 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45429202688 data:0x10000000
kworker/0:2-9731 [000] … 1453.851299: rtcpu_vinotify_event: tstamp:45846258690 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45429232448 data:0x31000006
kworker/0:2-9731 [000] … 1453.851300: rtcpu_vinotify_event: tstamp:45846258848 tag:FS channel:0x00 frame:80 vi_tstamp:45845735940 data:0x00000010
kworker/0:2-9731 [000] … 1453.851301: rtcpu_vinotify_event: tstamp:45846258988 tag:ATOMP_FS channel:0x00 frame:80 vi_tstamp:45845735944 data:0x00000000
kworker/0:2-9731 [000] … 1453.851302: rtcpu_vinotify_event: tstamp:45846259145 tag:CHANSEL_FAULT channel:0x23 frame:80 vi_tstamp:45845736943 data:0x00004004
kworker/0:2-9731 [000] … 1453.851304: rtcpu_vinotify_event: tstamp:45846259280 tag:RESERVED_19 channel:0x23 frame:80 vi_tstamp:45429415008 data:0x01020005
kworker/0:2-9731 [000] … 1453.851305: rtcpu_vinotify_event: tstamp:45846259434 tag:CHANSEL_NOMATCH channel:0x01 frame:80 vi_tstamp:45845740067 data:0x000006e9
kworker/0:2-9731 [000] … 1453.851306: rtcpu_vinotify_event: tstamp:45846259569 tag:CHANSEL_FAULT channel:0x23 frame:80 vi_tstamp:45845750485 data:0x00004001
kworker/0:2-9731 [000] … 1453.851307: rtcpu_vinotify_event: tstamp:45846259726 tag:RESERVED_19 channel:0x23 frame:80 vi_tstamp:45429848416 data:0x01020005
kworker/0:2-9731 [000] … 1453.851334: rtcpu_vinotify_event: tstamp:45846878341 tag:CHANSEL_FAULT channel:0x23 frame:80 vi_tstamp:45846875348 data:0x04374182
kworker/0:2-9731 [000] … 1453.851335: rtcpu_vinotify_event: tstamp:45846878503 tag:RESERVED_19 channel:0x23 frame:80 vi_tstamp:45465844352 data:0x01020005
kworker/0:2-9731 [000] … 1453.851336: rtcpu_vinotify_event: tstamp:45846878642 tag:ATOMP_FRAME_DONE channel:0x23 frame:80 vi_tstamp:45846875376 data:0x00000000
kworker/0:2-9731 [000] … 1453.851337: rtcpu_vinotify_event: tstamp:45846924889 tag:RESERVED_19 channel:0x23 frame:80 vi_tstamp:45465855168 data:0x02020005
kworker/0:2-9731 [000] … 1453.851338: rtos_queue_send_from_isr_failed: tstamp:45846925057 queue:0x0bcb41f8
kworker/0:2-9731 [000] … 1453.851340: rtos_queue_send_from_isr_failed: tstamp:45846925214 queue:0x0bcb8a60
kworker/0:2-9731 [000] … 1453.851341: rtos_queue_send_from_isr_failed: tstamp:45846925369 queue:0x0bcba5e0
kworker/0:2-9731 [000] … 1453.851342: rtos_queue_send_from_isr_failed: tstamp:45846925521 queue:0x0bcbb3a0
kworker/0:2-9731 [000] … 1453.851343: rtos_queue_send_from_isr_failed: tstamp:45846925671 queue:0x0bcbc160
kworker/0:2-9731 [000] … 1453.851344: rtcpu_vinotify_event: tstamp:45846925866 tag:CHANSEL_FAULT channel:0x23 frame:80 vi_tstamp:45846875485 data:0x043841c0
kworker/0:2-9731 [000] … 1453.851345: rtcpu_vinotify_event: tstamp:45846926028 tag:RESERVED_19 channel:0x23 frame:80 vi_tstamp:45465864416 data:0x01020005
kworker/0:2-9731 [000] … 1453.851347: rtcpu_vinotify_event: tstamp:45846926167 tag:FE channel:0x00 frame:80 vi_tstamp:45846897336 data:0x00000020
kworker/0:2-9731 [000] … 1453.851348: rtcpu_vinotify_event: tstamp:45846926326 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:80 vi_tstamp:45846897337 data:0x00000000
kworker/0:2-9731 [000] … 1453.851349: rtcpu_vinotify_event: tstamp:45846926462 tag:RESERVED_19 channel:0x23 frame:80 vi_tstamp:45466559264 data:0x01020005
kworker/0:2-9731 [000] … 1453.851350: rtcpu_vinotify_event: tstamp:45846926622 tag:ATOMP_FE channel:0x00 frame:80 vi_tstamp:45846897339 data:0x00000000
kworker/0:2-9731 [000] … 1453.851351: rtcpu_vinotify_event: tstamp:45846926757 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:45466574048 data:0x07020006
kworker/0:2-9731 [000] … 1453.851352: rtcpu_vinotify_event: tstamp:45846926915 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45466637696 data:0x10000000
kworker/0:2-9731 [000] … 1453.851354: rtcpu_vinotify_event: tstamp:45846927048 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45466667424 data:0x31000007
kworker/0:2-9731 [000] … 1453.851355: rtcpu_vinotify_event: tstamp:45846927207 tag:FS channel:0x00 frame:81 vi_tstamp:45846907816 data:0x00000010
kworker/0:2-9731 [000] … 1453.851356: rtcpu_vinotify_event: tstamp:45846927345 tag:ATOMP_FS channel:0x00 frame:81 vi_tstamp:45846907819 data:0x00000000
kworker/0:2-9731 [000] … 1453.851357: rtcpu_vinotify_event: tstamp:45846927502 tag:CHANSEL_FAULT channel:0x23 frame:81 vi_tstamp:45846908817 data:0x00004004
kworker/0:2-9731 [000] … 1453.851358: rtcpu_vinotify_event: tstamp:45846927637 tag:RESERVED_19 channel:0x23 frame:81 vi_tstamp:45466915008 data:0x01020006
kworker/0:2-9731 [000] … 1453.851359: rtcpu_vinotify_event: tstamp:45846927790 tag:CHANSEL_NOMATCH channel:0x01 frame:81 vi_tstamp:45846911943 data:0x000006e9
kworker/0:2-9731 [000] … 1453.851361: rtcpu_vinotify_event: tstamp:45846927925 tag:CHANSEL_FAULT channel:0x23 frame:81 vi_tstamp:45846922360 data:0x00004001
kworker/0:2-9731 [000] … 1453.907261: rtcpu_vinotify_event: tstamp:45847451728 tag:RESERVED_19 channel:0x23 frame:81 vi_tstamp:45467354304 data:0x01020006
kworker/0:2-9731 [000] … 1453.907264: rtcpu_vinotify_event: tstamp:45848087028 tag:CHANSEL_FAULT channel:0x23 frame:81 vi_tstamp:45848047223 data:0x04374182
kworker/0:2-9731 [000] … 1453.907266: rtcpu_vinotify_event: tstamp:45848087191 tag:RESERVED_19 channel:0x23 frame:81 vi_tstamp:45503344384 data:0x01020006
kworker/0:2-9731 [000] … 1453.907267: rtcpu_vinotify_event: tstamp:45848087331 tag:ATOMP_FRAME_DONE channel:0x23 frame:81 vi_tstamp:45848047251 data:0x00000000
kworker/0:2-9731 [000] … 1453.907268: rtcpu_vinotify_event: tstamp:45848087488 tag:RESERVED_19 channel:0x23 frame:81 vi_tstamp:45503349280 data:0x02020006
kworker/0:2-9731 [000] … 1453.907269: rtcpu_vinotify_event: tstamp:45848087624 tag:CHANSEL_FAULT channel:0x23 frame:81 vi_tstamp:45848047361 data:0x043841c0
kworker/0:2-9731 [000] … 1453.907270: rtcpu_vinotify_event: tstamp:45848087782 tag:RESERVED_19 channel:0x23 frame:81 vi_tstamp:45503358528 data:0x01020006
kworker/0:2-9731 [000] … 1453.907272: rtcpu_vinotify_event: tstamp:45848087921 tag:FE channel:0x00 frame:81 vi_tstamp:45848069210 data:0x00000020
kworker/0:2-9731 [000] … 1453.907273: rtcpu_vinotify_event: tstamp:45848088079 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:81 vi_tstamp:45848069211 data:0x00000000
kworker/0:2-9731 [000] … 1453.907274: rtcpu_vinotify_event: tstamp:45848088214 tag:RESERVED_19 channel:0x23 frame:81 vi_tstamp:45504059232 data:0x01020006
kworker/0:2-9731 [000] … 1453.907275: rtcpu_vinotify_event: tstamp:45848088374 tag:ATOMP_FE channel:0x00 frame:81 vi_tstamp:45848069214 data:0x00000000
kworker/0:2-9731 [000] … 1453.907303: rtcpu_vinotify_event: tstamp:45848088508 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:45504074016 data:0x07020007
kworker/0:2-9731 [000] … 1453.907304: rtcpu_vinotify_event: tstamp:45848088665 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45504131584 data:0x10000000
kworker/0:2-9731 [000] … 1453.907305: rtcpu_vinotify_event: tstamp:45848088800 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:45504162688 data:0x31000008
kworker/0:2-9731 [000] … 1453.907306: rtcpu_vinotify_event: tstamp:45848088957 tag:FS channel:0x00 frame:82 vi_tstamp:45848079690 data:0x00000010
kworker/0:2-9731 [000] … 1453.907307: rtcpu_vinotify_event: tstamp:45848089097 tag:ATOMP_FS channel:0x00 frame:82 vi_tstamp:45848079693 data:0x00000000
kworker/0:2-9731 [000] … 1453.907309: rtos_queue_send_from_isr_failed: tstamp:45848100115 queue:0x0bcb41f8
kworker/0:2-9731 [000] … 1453.907311: rtos_queue_send_from_isr_failed: tstamp:45848100267 queue:0x0bcb8a60
kworker/0:2-9731 [000] … 1453.907314: rtos_queue_send_from_isr_failed: tstamp:45848100420 queue:0x0bcba5e0
kworker/0:2-9731 [000] … 1453.907315: rtos_queue_send_from_isr_failed: tstamp:45848100566 queue:0x0bcbb3a0
kworker/0:2-9731 [000] … 1453.907316: rtos_queue_send_from_isr_failed: tstamp:45848100728 queue:0x0bcbc160
(repeat …)
Thanks,
hal.
Looks like sensor output embedded data but dts didn’t define the correct value of mbedded_metadata_height
hi ShaneCCC,
In last version, embedded_metadata_height = 0; It is refered from example project.
If I change it to embedded_metadata_height = 1, the log will show as below:
tracer: nop
entries-in-buffer/entries-written: 932/932 #P:4
_-----=> irqs-off
||| / delay
    v4l2-ctl-8907  [002] ....   461.461934: tegra_channel_open: vi-output, imx390 9-001a
    v4l2-ctl-8907  [000] ....   461.464125: tegra_channel_set_power: imx390 9-001a : 0x1
    v4l2-ctl-8907  [000] ....   461.464142: camera_common_s_power: status : 0x1
    v4l2-ctl-8907  [000] ....   461.573186: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
    v4l2-ctl-8907  [000] ....   461.573194: csi_s_power: enable : 0x1
    v4l2-ctl-8907  [000] ....   461.581650: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
    v4l2-ctl-8907  [003] ....   461.588156: tegra_channel_set_stream: enable : 0x1
    v4l2-ctl-8907  [001] ....   461.592207: tegra_channel_set_stream: 15a00000.nvcsi--2 : 0x1
    v4l2-ctl-8907  [001] ....   461.592213: csi_s_stream: enable : 0x1
    v4l2-ctl-8907  [001] ....   461.592221: tegra_channel_set_stream: imx390 9-001a : 0x1
 kworker/1:1-732   [001] ....   461.613111: rtos_queue_peek_from_isr_failed: tstamp:14842965870 queue:0x0bcbcf78
 kworker/1:1-732   [001] ....   461.613116: rtcpu_start: tstamp:14842967684
 kworker/1:1-732   [001] ....   461.613118: rtos_queue_send_from_isr_failed: tstamp:14842993737 queue:0x0bcb41f8
 kworker/1:1-732   [001] ....   461.613119: rtos_queue_send_from_isr_failed: tstamp:14842993887 queue:0x0bcb8a60
 kworker/1:1-732   [001] ....   461.613121: rtos_queue_send_from_isr_failed: tstamp:14842994039 queue:0x0bcba5e0
 kworker/1:1-732   [001] ....   461.613122: rtos_queue_send_from_isr_failed: tstamp:14842994185 queue:0x0bcbb3a0
 kworker/1:1-732   [001] ....   461.613123: rtos_queue_send_from_isr_failed: tstamp:14842994335 queue:0x0bcbc160
 kworker/1:1-732   [001] ....   461.613124: rtcpu_string: tstamp:14842994792 id:0x04010000 str:"Configuring VI GoS.
kworker/1:1-732 [001] … 461.613155: rtcpu_string: tstamp:14842994967 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/1:1-732 [001] … 461.613170: rtcpu_string: tstamp:14842995221 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/1:1-732 [001] … 461.613218: rtcpu_string: tstamp:14842995491 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/1:1-732 [001] … 461.613231: rtcpu_string: tstamp:14842995723 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/1:1-732 [001] … 461.613243: rtcpu_string: tstamp:14842995955 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/1:1-732 [001] … 461.613255: rtcpu_string: tstamp:14842996186 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/1:1-732 [001] … 461.613267: rtcpu_string: tstamp:14843004993 id:0x04010000 str:“vi5_hwinit: firmware CL2018101701 protocol vers”
kworker/1:1-732 [001] … 461.613269: rtcpu_string: tstamp:14843005111 id:0x04010000 str:"on 2.2
kworker/1:1-732 [001] … 461.613282: rtos_queue_send_from_isr_failed: tstamp:14843019525 queue:0x0bcb41f8
kworker/1:1-732 [001] … 461.613283: rtos_queue_send_from_isr_failed: tstamp:14843019694 queue:0x0bcb8a60
kworker/1:1-732 [001] … 461.613284: rtos_queue_send_from_isr_failed: tstamp:14843019849 queue:0x0bcba5e0
kworker/1:1-732 [001] … 461.613285: rtos_queue_send_from_isr_failed: tstamp:14843019995 queue:0x0bcbb3a0
kworker/1:1-732 [001] … 461.613286: rtos_queue_send_from_isr_failed: tstamp:14843020141 queue:0x0bcbc160
kworker/1:1-732 [001] … 461.613287: rtcpu_string: tstamp:14843021011 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/1:1-732 [001] … 461.613328: rtos_queue_send_from_isr_failed: tstamp:14843150372 queue:0x0bcb41f8
kworker/1:1-732 [001] … 461.613330: rtos_queue_send_from_isr_failed: tstamp:14843150521 queue:0x0bcb8a60
kworker/1:1-732 [001] … 461.613331: rtos_queue_send_from_isr_failed: tstamp:14843150674 queue:0x0bcba5e0
kworker/1:1-732 [001] … 461.613332: rtos_queue_send_from_isr_failed: tstamp:14843150819 queue:0x0bcbb3a0
kworker/1:1-732 [001] … 461.613333: rtos_queue_send_from_isr_failed: tstamp:14843150964 queue:0x0bcbc160
kworker/1:1-732 [001] … 461.613335: rtcpu_vinotify_error: tstamp:14843159469 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:14843156682 data:0x00000001
kworker/1:1-732 [001] … 461.613339: rtcpu_vinotify_event: tstamp:14843384585 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15415213472 data:0x10000000
kworker/1:1-732 [001] … 461.613341: rtcpu_vinotify_event: tstamp:14843384727 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15415221760 data:0x31000001
kworker/1:1-732 [001] … 461.613342: rtcpu_vinotify_event: tstamp:14843384888 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15415223968 data:0x07020001
kworker/1:1-732 [001] … 461.613343: rtcpu_vinotify_event: tstamp:14843385024 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15415251424 data:0x10000000
kworker/1:1-732 [001] … 461.613344: rtcpu_vinotify_event: tstamp:14843385181 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15415259840 data:0x31000002
kworker/1:1-732 [001] … 461.613345: rtcpu_vinotify_event: tstamp:14843385325 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:14843156682 data:0x00000001
kworker/1:1-732 [001] … 461.613346: rtcpu_vinotify_event: tstamp:14843385486 tag:FS channel:0x00 frame:225 vi_tstamp:14843364012 data:0x00000010
kworker/1:1-732 [001] … 461.613347: rtcpu_vinotify_event: tstamp:14843385626 tag:ATOMP_FS channel:0x00 frame:225 vi_tstamp:14843364015 data:0x00000000
kworker/1:1-732 [001] … 461.613348: rtcpu_vinotify_event: tstamp:14843385784 tag:CHANSEL_EMBED_SOF channel:0x23 frame:225 vi_tstamp:14843365014 data:0x00000004
kworker/1:1-732 [001] … 461.613350: rtcpu_vinotify_event: tstamp:14843385922 tag:CHANSEL_EMBED_EOF channel:0x23 frame:225 vi_tstamp:14843365928 data:0x00000008
kworker/1:1-732 [001] … 461.613351: rtcpu_vinotify_event: tstamp:14843386080 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:225 vi_tstamp:14843365956 data:0x00000000
kworker/1:1-732 [001] … 461.613352: rtcpu_vinotify_event: tstamp:14843386213 tag:RESERVED_19 channel:0x23 frame:225 vi_tstamp:15426216896 data:0x03020001
kworker/1:1-732 [001] … 461.613353: rtcpu_vinotify_event: tstamp:14843386370 tag:CHANSEL_NOMATCH channel:0x01 frame:225 vi_tstamp:14843368138 data:0x000006e9
kworker/1:1-732 [001] … 461.613354: rtcpu_vinotify_event: tstamp:14843386505 tag:CHANSEL_PXL_SOF channel:0x23 frame:225 vi_tstamp:14843378558 data:0x00000001
kworker/1:1-732 [001] … 461.613355: rtcpu_vinotify_event: tstamp:14843386662 tag:RESERVED_19 channel:0x23 frame:225 vi_tstamp:15426617440 data:0x08020001
kworker/1:1-732 [001] … 461.613356: rtcpu_vinotify_event: tstamp:14843386796 tag:CHANSEL_FAULT channel:0x23 frame:225 vi_tstamp:14843379461 data:0x00000100
kworker/1:1-732 [001] … 461.613357: rtos_queue_send_from_isr_failed: tstamp:14843396510 queue:0x0bcb41f8
kworker/1:1-732 [001] … 461.613358: rtos_queue_send_from_isr_failed: tstamp:14843396666 queue:0x0bcb8a60
kworker/1:1-732 [001] … 461.613359: rtos_queue_send_from_isr_failed: tstamp:14843396819 queue:0x0bcba5e0
kworker/1:1-732 [001] … 461.613361: rtos_queue_send_from_isr_failed: tstamp:14843396964 queue:0x0bcbb3a0
kworker/1:1-732 [001] … 461.613362: rtos_queue_send_from_isr_failed: tstamp:14843397109 queue:0x0bcbc160
kworker/1:1-732 [001] … 461.669104: rtcpu_vinotify_event: tstamp:14843893625 tag:RESERVED_19 channel:0x23 frame:225 vi_tstamp:15426662336 data:0x01020001
kworker/1:1-732 [001] … 461.669108: rtcpu_vinotify_event: tstamp:14844540728 tag:CHANSEL_FAULT channel:0x23 frame:225 vi_tstamp:14844503419 data:0x04370182
kworker/1:1-732 [001] … 461.669110: rtcpu_vinotify_event: tstamp:14844542383 tag:RESERVED_19 channel:0x23 frame:225 vi_tstamp:15462616736 data:0x01020001
kworker/1:1-732 [001] … 461.669111: rtcpu_vinotify_event: tstamp:14844542523 tag:ATOMP_FRAME_DONE channel:0x23 frame:225 vi_tstamp:14844503448 data:0x00000000
kworker/1:1-732 [001] … 461.669112: rtcpu_vinotify_event: tstamp:14844542684 tag:RESERVED_19 channel:0x23 frame:225 vi_tstamp:15462621632 data:0x02020001
kworker/1:1-732 [001] … 461.669113: rtcpu_vinotify_event: tstamp:14844542819 tag:CHANSEL_FAULT channel:0x23 frame:225 vi_tstamp:14844503557 data:0x043801c0
kworker/1:1-732 [001] … 461.669115: rtcpu_vinotify_event: tstamp:14844542977 tag:RESERVED_19 channel:0x23 frame:225 vi_tstamp:15462630720 data:0x01020001
kworker/1:1-732 [001] … 461.669116: rtcpu_vinotify_event: tstamp:14844543114 tag:FE channel:0x00 frame:225 vi_tstamp:14844525407 data:0x00000020
kworker/1:1-732 [001] … 461.669117: rtcpu_vinotify_event: tstamp:14844543275 tag:ATOMP_FE channel:0x00 frame:225 vi_tstamp:14844525411 data:0x00000000
kworker/1:1-732 [001] … 461.669118: rtcpu_vinotify_event: tstamp:14844543409 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15463328224 data:0x07020002
kworker/1:1-732 [001] … 461.669119: rtcpu_vinotify_event: tstamp:14844543567 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15463390336 data:0x10000000
kworker/1:1-732 [001] … 461.669121: rtcpu_vinotify_event: tstamp:14844543702 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15463420064 data:0x31000003
kworker/1:1-732 [001] … 461.669122: rtcpu_vinotify_event: tstamp:14844543860 tag:FS channel:0x00 frame:226 vi_tstamp:14844535887 data:0x00000010
kworker/1:1-732 [001] … 461.669123: rtcpu_vinotify_event: tstamp:14844544000 tag:ATOMP_FS channel:0x00 frame:226 vi_tstamp:14844535891 data:0x00000000
kworker/1:1-732 [001] … 461.669124: rtcpu_vinotify_event: tstamp:14844544157 tag:CHANSEL_EMBED_SOF channel:0x23 frame:226 vi_tstamp:14844536888 data:0x00000004
kworker/1:1-732 [001] … 461.669150: rtcpu_vinotify_event: tstamp:14844544290 tag:CHANSEL_EMBED_EOF channel:0x23 frame:226 vi_tstamp:14844537804 data:0x00000008
kworker/1:1-732 [001] … 461.669155: rtos_queue_send_from_isr_failed: tstamp:14844564123 queue:0x0bcb41f8
kworker/1:1-732 [001] … 461.669156: rtos_queue_send_from_isr_failed: tstamp:14844564276 queue:0x0bcb8a60
kworker/1:1-732 [001] … 461.669157: rtos_queue_send_from_isr_failed: tstamp:14844564429 queue:0x0bcba5e0
kworker/1:1-732 [001] … 461.669159: rtos_queue_send_from_isr_failed: tstamp:14844564578 queue:0x0bcbb3a0
kworker/1:1-732 [001] … 461.669160: rtos_queue_send_from_isr_failed: tstamp:14844564724 queue:0x0bcbc160
kworker/1:1-732 [001] … 461.669161: rtcpu_vinotify_event: tstamp:14845033214 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:226 vi_tstamp:14844537831 data:0x00000000
kworker/1:1-732 [001] … 461.669162: rtcpu_vinotify_event: tstamp:14845033356 tag:RESERVED_19 channel:0x23 frame:226 vi_tstamp:15463722848 data:0x03020002
kworker/1:1-732 [001] … 461.669163: rtcpu_vinotify_event: tstamp:14845033519 tag:CHANSEL_NOMATCH channel:0x01 frame:226 vi_tstamp:14844540014 data:0x000006e9
kworker/1:1-732 [001] … 461.669165: rtcpu_vinotify_event: tstamp:14845033656 tag:CHANSEL_PXL_SOF channel:0x23 frame:226 vi_tstamp:14844550432 data:0x00000001
kworker/1:1-732 [001] … 461.669166: rtcpu_vinotify_event: tstamp:14845033815 tag:RESERVED_19 channel:0x23 frame:226 vi_tstamp:15464117408 data:0x08020002
kworker/1:1-732 [001] … 461.669167: rtcpu_vinotify_event: tstamp:14845033951 tag:CHANSEL_FAULT channel:0x23 frame:226 vi_tstamp:14844551336 data:0x00000100
kworker/1:1-732 [001] … 461.669168: rtcpu_vinotify_event: tstamp:14845034108 tag:RESERVED_19 channel:0x23 frame:226 vi_tstamp:15464155936 data:0x01020002
kworker/1:1-732 [001] … 461.725144: rtcpu_vinotify_event: tstamp:14845700131 tag:CHANSEL_FAULT channel:0x23 frame:226 vi_tstamp:14845675295 data:0x04370182
kworker/1:1-732 [001] … 461.725147: rtcpu_vinotify_event: tstamp:14845700299 tag:RESERVED_19 channel:0x23 frame:226 vi_tstamp:15500116768 data:0x01020002
kworker/1:1-732 [001] … 461.725149: rtcpu_vinotify_event: tstamp:14845700439 tag:ATOMP_FRAME_DONE channel:0x23 frame:226 vi_tstamp:14845675323 data:0x00000000
kworker/1:1-732 [001] … 461.725150: rtcpu_vinotify_event: tstamp:14845700596 tag:RESERVED_19 channel:0x23 frame:226 vi_tstamp:15500121664 data:0x02020002
kworker/1:1-732 [001] … 461.725151: rtcpu_vinotify_event: tstamp:14845700732 tag:CHANSEL_FAULT channel:0x23 frame:226 vi_tstamp:14845675433 data:0x043801c0
kworker/1:1-732 [001] … 461.725152: rtcpu_vinotify_event: tstamp:14845700889 tag:RESERVED_19 channel:0x23 frame:226 vi_tstamp:15500130752 data:0x01020002
kworker/1:1-732 [001] … 461.725154: rtcpu_vinotify_event: tstamp:14845701028 tag:FE channel:0x00 frame:226 vi_tstamp:14845697282 data:0x00000020
kworker/1:1-732 [001] … 461.725155: rtcpu_vinotify_event: tstamp:14845701191 tag:ATOMP_FE channel:0x00 frame:226 vi_tstamp:14845697285 data:0x00000000
kworker/1:1-732 [001] … 461.725156: rtcpu_vinotify_event: tstamp:14845701326 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15500828224 data:0x07020003
It reports more CHANSEL_FAULT.
Please help to advise.
Thanks,
hal.
Below tell the PIXEL_LONG_LINE it could be the output width doesn’t match the dts declare.
hi ShaneCCC,
Thanks for your advice. After modifying output width, it is working now.
hal
