Dear All,
Apologize to tag the Xavier NX, I don’t know which category could be better to tag this issue. I got the issue while I build the kernel with “CONFIG_COMPILE_TEST” that TI’s codec chip need.
https://www.ti.com/tool/TLV320AIC32X4SW-LINUX
/home/lanner/workspace/nVIDIA/Jetson_Xavier_1.5.1_7814/nx_nvidia/JetPack_4.5.1_Linux_JETSON_XAVIER_NX_DEVKIT/Linux_for_Tegra/sources/kernel/kernel-4.9/drivers/dma/hsu/hsu.c:163:20: error: passing argument 1 of ‘spinlock_check’ from incompatible pointer type [-Werror=incompatible-pointer-types]
spin_lock_irqsave(&hsuc->vchan.lock, flags);
/home/lanner/workspace/nVIDIA/Jetson_Xavier_1.5.1_7814/nx_nvidia/JetPack_4.5.1_Linux_JETSON_XAVIER_NX_DEVKIT/Linux_for_Tegra/sources/kernel/kernel-4.9/drivers/dma/hsu/hsu.c:165:25: error: passing argument 1 of ‘spin_unlock_irqrestore’ from incompatible pointer type [-Werror=incompatible-pointer-types]
spin_unlock_irqrestore(&hsuc->vchan.lock, flags);
/home/lanner/workspace/nVIDIA/Jetson_Xavier_1.5.1_7814/nx_nvidia/JetPack_4.5.1_Linux_JETSON_XAVIER_NX_DEVKIT/Linux_for_Tegra/sources/kernel/kernel-4.9/drivers/dma/hsu/hsu.c:217:20: error: passing argument 1 of ‘spinlock_check’ from incompatible pointer type [-Werror=incompatible-pointer-types]
/home/lanner/workspace/nVIDIA/Jetson_Xavier_1.5.1_7814/nx_nvidia/JetPack_4.5.1_Linux_JETSON_XAVIER_NX_DEVKIT/Linux_for_Tegra/sources/kernel/kernel-4.9/drivers/dma/hsu/hsu.c:230:25: error: passing argument 1 of ‘spin_unlock_irqrestore’ from incompatible pointer type [-Werror=incompatible-pointer-types]
/home/lanner/workspace/nVIDIA/Jetson_Xavier_1.5.1_7814/nx_nvidia/JetPack_4.5.1_Linux_JETSON_XAVIER_NX_DEVKIT/Linux_for_Tegra/sources/kernel/kernel-4.9/drivers/dma/hsu/hsu.c:396:20: error: passing argument 1 of ‘spinlock_check’ from incompatible pointer type [-Werror=incompatible-pointer-types]
/home/lanner/workspace/nVIDIA/Jetson_Xavier_1.5.1_7814/nx_nvidia/JetPack_4.5.1_Linux_JETSON_XAVIER_NX_DEVKIT/Linux_for_Tegra/sources/kernel/kernel-4.9/drivers/dma/hsu/hsu.c:405:25: error: passing argument 1 of ‘spin_unlock_irqrestore’ from incompatible pointer type [-Werror=incompatible-pointer-types]
the sources version which I download by source_sync.sh is the tegra-l4t-r32.5.1, the Linaro GCC version is 7.3.1 20180425(gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu.tar.xz).
I’m curious Is there any one been met this problem as I got? Then how fixed that? change the compile tool/sources? or add some argument to ignore it?
Would you mind to give me some suggestion for better? Many Thanks.
Best Regards,
MOMO Chen
