Xavier NX control GPIO
How can I use Xavier NX’s GPIO using APIS. For instance, what’s the header file I need to include?
When I use the function named gpioSetDirection, it shows that “Permission denied”.
hello VastStar ,
please try below method to access GPIOs.
for example,
Generate gpio220 name under the path of GPIOs
echo 220 > /sys/class/gpio/export
Enable the pin for usage.
echo out > direction && echo 1 > value
Thanks for your reply.
However, It shows Permission denied, when use command “echo out > direction && echo 1 > value”
bash: direction: Permission denied
What troubles me is that I don’t kown how to give it permission.
hello VastStar ,
did you grant root permission for running this?
nvidia@nx-jp440:/sys/class/gpio$ echo 417 > /sys/class/gpio/export
nvidia@nx-jp440:/sys/class/gpio$ echo out >direction && echo 1 > value
nvidia@nx-jp440:/sys/class/gpio$ su
Password:
root@nx-jp440:/sys/class/gpio# echo out > direction
I don’t kown whether is correct or not.
Hi @VastStar ,
Have you tried like below?
sudo echo 417 > /sys/class/gpio/export
sudo echo out > direction && sudo echo 1 > value
Regards
I have tried but got the same result.
Can you type below command?
sudo chmod +x /sys/class/gpio/gpio417/direction
sudo chmod +x /sys/class/gpio/gpio417/value
It works. But 22Pin(gpio417) has no output.
Hello @VastStar
If you don’t want to change permissions or anything you can use the following commands:
sudo sh -c "echo 417 > /sys/class/gpio/export"
sudo sh -c "echo out > /sys/class/gpio/gpio417/direction"
sudo sh -c "echo 0 > /sys/class/gpio/gpio417/value"
This will run the command that you specify after the -c flag in a new shell with super user permissions and execute it. Maybe you can check with that too and see if the issue is still there.
Regards
