I had some issues with the fan controller (nvfancontrol) on Jetpack 5, the fan was not running and the CPU temperature seemed locked at 25C. Was digging around alot and the attached patch fixed the issue for me.
Can you confirm, that this is a bug in Jetpack 5? Or should i look for the root cause elsewhere? No problems on Jetpack 4.
Thanks for sharing the patch. Do you observe the issue on Jetpack 5.0.2 or 5.1? There are certain fixes between the releases and not sure if you have upgraded to 5.1 and still hits the issue.
I can confirm, 5.0.2 did not had this issue.
In 5.1, the temperature tends to not change for cpu. So it is not triggering fan.
Btw how to use patch @casperlyngesen.mogensen ?
