HI there, I have designed a custom carrier board for the NX, unfortunately the input voltage for the module and the power sequencing logic was set to 5.4volts. In the datasheet it states operating voltages to be from 5 to 5.25. The module was working fine for 2 hours and then it died.
I tried putting the module back on the devkit with no luck. It heats up really quickly and appears to be dead, no output from the debug serial, HDMI to any other IO.
Is there anyway to bring the module back to life ?
It seems the module had been broken. You can run RMA for it.
