Xavier Nx dev kit additional usb hub circuit
Hi all, wondered if anyone has used an additional USB hub circuit on the dev kit? I’m looking at things like the Microchip USB2502-HT USB Controller to add another 3+ channels… Will the jetson recognise it as a usb hub if i connect it straight to the existing carrier boards’ USB connector terminations?
Any advice / previous experience on this welcomed
Cheers
Hi, there is a supported components list in DLC as below. If there is no what you need in it, you will have to choose and tune that by yourself. Hope someone has such experience can be shared.
https://developer.nvidia.com/jetson-xavier-nx-supported-component-list
