Hello there,
I was hoping to encrypt my sd card, with SecureBoot, but as I am using a sd card in my Xavier NX dev kit, it seems like it is not possible.
In order for me to protect my IP(Intellectual Property), I needed some sort of encryption, and there were other 2 options : Trusted Execution Environment and Disk Encryption, right?
Then, I thought it might be better and a lot easier to encrypt my data through Disk Encryption.
But it seems like it needed another partition for it to be encrypted.
- Is it possible to write the disk image(jetson nx sd card image) with etcher after i made my SD card partition through other program?
1 -1 ) if not, is it possible to make partition after writing disk image and booting the os? Which i meant after booting the Xavier and make partitions inside the OS within?
- With TEE, can i possibly encrypt the data which is stored in my sd card?
Would be appreciated to get some helps here!
