When Xaiver NX is used, it occasionally fails to start after power-on, and displays “VFS: Found ext4 filesystem invalid superblock checksum.Run e2fsck”, and it still cannot be recovered after power-on. After trying to re-burn the image, it will return to normal, but the problem will still occur again after a period of time. What could be the cause of this problem?
Attached is the screen print message when the startup fails.
Which jetpack version is in use and did you remember how you reproduced this issue? Any specific usecase?
My NX has been putting there for weeks but it cannot hit this error.
The jetpack version is JetPack_4.6.1. There is currently no specific test method for this problem. The above problem occurs after a certain power-on.
