We test our board using xavier nx with jetpack 4.6.3 and find the output color is not good as original in this topic
And we tried in jetpack 5.1.5, but the result is the same, the red color is still bad is low and high area.
Please share the steps to replicate the issue. We will set up developer kit and check.
we use this in matlab to get the oringinal image. and output it in DRM
img = zeros(2160,3840,3);
model = 2;
for j = 1:3840
if model ==1% 模式1
t = floor(j/ 12); % 列条判断
if t > 255 % 截位
t = t-256;
end
img(:,j,:) = t; % 三通道赋值
else
% r通道赋值
tr = floor(j/ 12); % 列条判断
if tr > 255 % 截位
tr1 = tr-256;
else
tr1 = tr;
end
img(:,j,1) = tr1; % r通道赋值
% G通道赋值
img(:,j,2) = 255- tr1; % r通道赋值
% B通道赋值
tb = floor(j/ 12) + 128; % 列条判断
if tb > 255 % 截位
tb1 = tb-256;
else
tb1 = tb;
end
img(:,j,3) = tb1;
end
end
figure;imshow(uint8(img));
imwrite(uint8(img),'dor_start.png');
Sine we don’t use Matlab, it’s difficult for us to check further. Please try to replicate it on developer kit, and share us the full steps. So that we can set up the same. 08 sample is the reference sample and please base on it to reproduce the issue.
Please check if we can generate test file through gst-launch-1.0 command. For example:
$ gst-launch-1.0 videotestsrc num-buffers=100 ! video/x-raw,format=I420,width=1920,height=1080 ! nvvidconv ! nvv4l2h264enc profile=Main ! video/x-h264 ! h264parse ! video/x-h264,stream-format=byte-stream ! filesink location=~/FHD.h264
And can reproduce it by decoding the test file through 08 sample:
08_video_dec_drm$ ./video_dec_drm ~/FHD.h264 H264 --disable-ui
We need a method to replicate it on developer kit and check. Would need your help on this.
