Xavier NX I2C Boot Requirement
I am currently designing a carrier board for the Xavier NX. In the reference carrier board design, I see that I2C2_SCL/SDA are directly connected to an EEPROM which is unpowered during the power-on sequence. Is it acceptable to directly connect an I2C pair to a device which will be powered during the NX power-on sequence? For said I2C connection, I am planning to rely on the module’s internal I2C pull-ups.
Thank you for your time!
The carrier power should be ON after module especially for the shared interface b/w carrier and module. So the I2C device better to be powered after module power-on.
