I’m using a Nvidia jetson Xavier NX Development Kit for image classification, with model Resnet-18. But the frame rate for classification is slower than I expected.
The program basically uses the code from dusty https://github.com/dusty-nv/jetson-inference/blob/master/docs/imagenet-example-python-2.md
My image size is 224X224X3. To test the inference frame per second, I just load an image and model. run the inference 2000 time to calculate the FPS.
net = jetson.inference.imageNet(“ResNet-50”,[network1])
img= jetson.utils.loadImage(image_0.jpg)
start = time.time()
for im in range(2000):
class_idx, confidence = net.Classify(img)
end= time.time()
the resulting frame rate is ~250 FPS for Resnet-18 and ~160 FPS for Resnet-50. This is a lot slower than 824 for FPS ResNet-50.
using the benchmark program. I did get 824 FPS.
any other parameters need to be changed to increase the speed?
software:
Jetpack UNKNOWN (L4T 32.5.2)
CUDA 10.2.89
TensorRT: 7.1.3.0
