Xavier NX input voltage
Hi Guys,
Just clarification, I see from the data sheet that NX input voltage is 5V. Does it support some input voltage range or 5V fixed?
In data sheet is written for VDD_IN (page 36):
recommended: from 4.75V to 5.25
absolute maximum ratings: from -0.5V to 5.5V
Thank you ulmus. Just wanted confirmation by NVIDIA that there is no input voltage wide range like it was on TX2 or Xavier. Like ability to use 12V input, but I see it’s probably not the case. Thank you
In TX there is step-down DC-DC for inner 5V (and other voltages), therefor supply is from 6V to 19V. In NX there is no converter.
Thank you ulmus, issue is closed.
