Xavier NX Jetpack 5.1 initrd massflash doesn't work
Yes, I have already tested downloading through two separate USB ports.
orin-nx-massflash-anomaly.log (41.1 KB)
@lhoang Can you take a look at it ?
What is this log that you upload? Is it flashing individually or flashing with multiple devices? It is because it is slightly different from the screenshot above so I want to ask.
@lhoang Flashing with two devices , the log of the failed one.
Can you try
to generate mfi image
sudo ./tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device nvme0n1p1 --sparse -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg” -c ./tools/kernel_flash/flash_l4t_external.xml --massflash 5 --showlogs --network usb0 p3509-a02+p3767-0000 nvme0n1p1
to flash into nvme ssd
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --sparse --network usb0 --massflash 2 --showlogs
@lhoang Hi,
Generate mfi,
and flash two devices, one success, one fail
and the fail log.
orin-nx-massflash-anomaly.log (37.9 KB)
Maybe the USB cable is faulty can you replace the USB cable? Also can you upload both logs the failed one and the successful one.
@lhoang
the success one.
orin-nx-massflash-normal.log (38.2 KB)
the fail one.
orin-nx-massflash-anomaly.log (33.6 KB)
We tried two separate flash and it worked, so it had nothing to do with usb cables,I think.
