I am using Xavier NX (8GB), but I only use 2~3GB of Memory (RAM). I want to use more than that, but I can’t use it. Also, when other programs are executed, Core Dumped is output and terminated. Any solution?
It seems you need to be more specific on what applicat you tested. how you monitor the RAM usage status.
What the program is? Any dump log?
Hello, when I ran the JTOP program, there was no separate dump file. But I’ve seen them use only 3GB of RAM.
Problem solved. Thank you.
