We’ve recently hit a number of xavier nx module failures and were requested that we post some logs to the forum so here we go. While attempting to flash the problematic modules I connected a debug uart and collected the output during the attempt to flash. I’ve attached the logs here.
Summary:
Module 1:
[0016.808] C> Task 0x4d failed (err: 0x8c8c011c)
[0016.812] E> Top caller module: MB1_MSS, error module: MB1_MSS, reason: 0x1c, aux_info: 0x01
[0016.820] C> Error: 0x8c8c011c
[0016.823] C> MB1(2.6.0.0-t194-41334769-cab45716) BIT boot status dump :
Module 2
[0000.066] E> Failed to verify PMC high threshold fault occurrence. Fault reg: 0x0x2
[0000.073] C> Task 0x27 failed (err: 0x77770918)
[0000.077] E> Top caller module: FMON, error module: FMON, reason: 0x18, aux_info: 0x09
[0000.085] C> Error: 0x77770918
[0000.088] C> MB1(2.6.0.0-t194-41334769-cab45716) BIT boot status dump :
0000000000111111111001000000000001111010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
[0000.117] I> Reset to recovery mode
Module 3 - This one appears to be completely dead
Module 4
[0019.705] E> Error: 0
[0019.707] C> Task 0x6b failed (err: 0x32320006)
[0019.711] E> Top caller module: CPUINIT, error module: CPUINIT, reason: 0x06, aux_info: 0x00
[0019.719] C> Error: 0x32320006
[0019.722] C> MB1(2.6.0.0-t194-41334769-cab45716) BIT boot status dump :
0000000000111111111001000000000001111011111111000011111111111111001110001111111100100001111101110001101111100000000000000000000010101111000001010111100000110101011110000010101111000000000110000000000011000000000000000000000000000000000000000000000000000000
logs.tar.gz (21.1 KB)
