Xavier NX Module Keeps Rebooting
Hello everyone,
I get the following error on one of my Xavier NX modules that has a custom carrier board:
The system boots up normally but after few minutes it gives this error and reboots. Afterwards it writes garbage through UART so I can’t understand what the issue is.
Only power-cycling fix the garbled stuff issue. If I just unplug the UART cable it still gives these messages.
Thank you in advance,
Yusuf
Hi mehmetyusuf1414,
Is the issue specific to this Xavier NX module?
Do you have the devkit to check if there’s similar issue?
Please share the full serial console log as file here when you hit the reboot issue.
