I use the Toshiba RC500 SSD 250G m.2 solid-state NVMe to test the M.2 interface on Xavier NX (burned with ./flash.sh). The specific hard disk parameters are as follows:
Interface specifications:PCIE 3.1A. Commond: NVMe 1.3c
But after the system starts, under / dev, no NVMe device is found. Do you need other settings?
The following is the startup log:
nvidia@localhost:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (root@ubuntu) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) ) #3 SMP PREEMPT Fri May 15 16:12:49 CST 2020
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 2032640
[ 0.000000] DMA zone: 7184 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 459776 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1ffd04000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2000880
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29188(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7190196K/8130560K available (15294K kernel code, 2934K rwdata, 6876K rodata, 8576K init, 609K bss, 186700K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009630000 ( 6912 KB)
[ 0.000000] .init : 0xffffff8009630000 - 0xffffff8009e90000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e90000 - 0xffffff800a16d808 ( 2935 KB)
[ 0.000000] .bss : 0xffffff800a16d808 - 0xffffff800a205f3c ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000810] Console: colour dummy device 80x25
[ 0.000821] console [tty0] enabled
[ 0.000828] bootconsole [tegra_comb_uart0] disabled
[ 0.000841] kmemleak: Kernel memory leak detector disabled
[ 0.000859] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000874] pid_max: default: 32768 minimum: 301
[ 0.001973] Security Framework initialized
[ 0.002552] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002562] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.004166] ftrace: allocating 47062 entries in 184 pages
[ 0.399420] sched-energy: Sched-energy-costs installed from DT
[ 0.399439] ASID allocator initialised with 65536 entries
[ 0.434292] tegra-id: chipid=21917.
[ 0.434304] tegra-id: opt_subrevision=0.
[ 0.434330] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.434356] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.434366] DTB Build time: May 15 2020 18:43:21
[ 0.482447] CPU1: Booted secondary processor [4e0f0040]
[ 0.514470] CPU2: Booted secondary processor [4e0f0040]
[ 0.546602] CPU3: Booted secondary processor [4e0f0040]
[ 0.578857] CPU4: Booted secondary processor [4e0f0040]
[ 0.610989] CPU5: Booted secondary processor [4e0f0040]
[ 0.611211] Brought up 6 CPUs
[ 0.611220] SMP: Total of 6 processors activated.
[ 0.611229] CPU features: detected feature: Privileged Access Never
[ 0.611236] CPU features: detected feature: LSE atomic instructions
[ 0.611242] CPU features: detected feature: User Access Override
[ 0.611248] CPU features: detected feature: 32-bit EL0 Support
[ 0.612840] CPU: All CPU(s) started at EL2
[ 0.612894] alternatives: patching kernel code
[ 0.619309] devtmpfs: initialized
[ 0.655078] Initilizing CustomIPI irq domain
[ 0.655288] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.655304] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.665582] pinctrl core: initialized pinctrl subsystem
[ 0.665823] OS set in device tree is not L4T.
[ 0.666028] regulator-dummy: no parameters
[ 0.666221] Initializing plugin-manager
[ 0.666267] Plugin module not found
[ 0.666303] Plugin-manager status disabled
[ 0.667343] NET: Registered protocol family 16
[ 0.668499] pstore: using zlib compression
[ 0.668519] console [pstore-1] enabled
[ 0.668525] pstore: Registered ramoops as persistent store backend
[ 0.668532] ramoops: attached 0x200000@0xf0600000, ecc: 0/0
[ 0.681724] cpuidle: using governor menu
[ 0.682674] bpmp: waiting for handshake
[ 0.682681] bpmp: handshake completed
[ 0.682695] bpmp: synchronizing channels
[ 0.682704] bpmp: channels synchronized
[ 0.682710] bpmp: mail init ok
[ 0.684992] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.685155] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.685161] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.685168] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.685173] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.685179] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.685188] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.685195] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.685202] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.685209] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.685215] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.687962] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e94000)
[ 0.687989] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.690417] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.691321] Registering BPMP clocks…
[ 0.691411] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.692079] Serial: AMBA PL011 UART driver
[ 0.692256] tegra_powergate_init: DONE
[ 0.692411] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.692422] DTB Build time: May 15 2020 18:43:21
[ 0.695099] Tegra reboot handler registered.
[ 0.702262] iommu: Adding device 14160000.pcie to group 0
[ 0.702840] iommu: Adding device 141a0000.pcie to group 1
[ 0.704056] iommu: Adding device 2490000.ether_qos to group 2
[ 0.704526] iommu: Adding device 3100000.serial to group 3
[ 0.704990] iommu: Adding device 3110000.serial to group 4
[ 0.705338] iommu: Adding device 3140000.serial to group 5
[ 0.705971] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.706331] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.706356] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.706362] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.706367] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.706409] tegra-pmc: PMC Prod config success
[ 0.706624] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.706638] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.706924] iommu: Adding device 3400000.sdhci to group 6
[ 0.707407] iommu: Adding device 3210000.spi to group 7
[ 0.707760] iommu: Adding device 3230000.spi to group 8
[ 0.708090] iommu: Adding device 3270000.spi to group 9
[ 0.709110] iommu: Adding device 3160000.i2c to group 10
[ 0.709474] iommu: Adding device c240000.i2c to group 11
[ 0.709825] iommu: Adding device 3180000.i2c to group 12
[ 0.710207] iommu: Adding device 3190000.i2c to group 13
[ 0.710718] iommu: Adding device 31b0000.i2c to group 14
[ 0.711055] iommu: Adding device 31c0000.i2c to group 15
[ 0.711431] iommu: Adding device c250000.i2c to group 16
[ 0.711778] iommu: Adding device 31e0000.i2c to group 17
[ 0.712314] iommu: Adding device sound to group 18
[ 0.712842] iommu: Adding device 3510000.hda to group 19
[ 0.713304] iommu: Adding device bc00000.rtcpu to group 20
[ 0.715093] iommu: Adding device 13e10000.host1x to group 21
[ 0.715470] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.715825] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.716148] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.716631] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.716972] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.717327] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.717663] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.718074] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.718531] iommu: Adding device 15340000.vic to group 30
[ 0.718876] iommu: Adding device 15380000.nvjpg to group 31
[ 0.719140] iommu: Adding device 15500000.tsec to group 32
[ 0.719397] iommu: Adding device 15100000.tsecb to group 33
[ 0.719656] iommu: Adding device 15480000.nvdec to group 34
[ 0.719937] iommu: Adding device 15140000.nvdec1 to group 35
[ 0.720192] iommu: Adding device 154c0000.nvenc to group 36
[ 0.720440] iommu: Adding device 15a80000.nvenc1 to group 37
[ 0.720987] iommu: Adding device 15880000.nvdla0 to group 38
[ 0.721370] iommu: Adding device 158c0000.nvdla1 to group 39
[ 0.721950] iommu: Adding device 15200000.nvdisplay to group 40
[ 0.726037] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.726108] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.726711] iommu: Adding device 15210000.nvdisplay to group 41
[ 0.726778] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.728423] iommu: Adding device 15c10000.vi to group 42
[ 0.728581] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.728970] iommu: Adding device 14800000.isp to group 43
[ 0.729914] iommu: Adding device 16000000.pva0 to group 44
[ 0.730636] iommu: Adding device 16800000.pva1 to group 45
[ 0.731018] iommu: Adding device 15810000.se to group 46
[ 0.731412] iommu: Adding device 15820000.se to group 47
[ 0.731670] iommu: Adding device 15830000.se to group 48
[ 0.731930] iommu: Adding device 15840000.se to group 49
[ 0.732170] iommu: Adding device c1a0000.aon to group 50
[ 0.733493] iommu: Adding device d000000.bpmp to group 51
[ 0.733806] bpmp: ping status is 0
[ 0.733939] bpmp d000000.bpmp: firmware tag is 57f8a77779f848bf2ecf21dabee5645f
[ 0.737215] bpmp d000000.bpmp: probe ok
[ 0.738748] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.739167] iommu: Adding device smmu_test to group 52
[ 0.740250] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c10000
[ 0.740269] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c20000
[ 0.740285] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c30000
[ 0.740304] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2c40000
[ 0.740320] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2c50000
[ 0.740335] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2b80000
[ 0.740350] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2b90000
[ 0.740365] mc: mapped MMIO address: 0xffffff800b090000 -> 0x2ba0000
[ 0.740380] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x2bb0000
[ 0.740396] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1700000
[ 0.740411] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1710000
[ 0.740426] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1720000
[ 0.740447] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1730000
[ 0.740463] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1740000
[ 0.740478] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1750000
[ 0.740493] mc: mapped MMIO address: 0xffffff800b190000 -> 0x1760000
[ 0.740508] mc: mapped MMIO address: 0xffffff800b1b0000 -> 0x1770000
[ 0.740600] mc-err: mcerr ops are set to t19x
[ 0.745820] iommu: Adding device 2600000.dma to group 53
[ 0.750654] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.750692] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.750725] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.750977] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.757622] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.757906] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.759948] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.759961] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.760565] iommu: Adding device 3550000.xudc to group 54
[ 0.761128] iommu: Adding device 3610000.xhci to group 55
[ 0.762983] arm64_ras arm64_ras: probed
[ 0.763360] ras_fhi_enable: FHI 468 enabled on CPU0
[ 0.763414] ras_fhi_enable: FHI 469 enabled on CPU1
[ 0.763479] ras_fhi_enable: FHI 470 enabled on CPU2
[ 0.763533] ras_fhi_enable: FHI 471 enabled on CPU3
[ 0.763586] ras_fhi_enable: FHI 472 enabled on CPU4
[ 0.763638] ras_fhi_enable: FHI 473 enabled on CPU5
[ 0.763813] carmel_ras_enable: RAS enabled on cpu0
[ 0.763981] carmel_ras_enable: RAS enabled on cpu1
[ 0.764170] carmel_ras_enable: RAS enabled on cpu2
[ 0.764378] carmel_ras_enable: RAS enabled on cpu3
[ 0.764571] carmel_ras_enable: RAS enabled on cpu4
[ 0.764763] carmel_ras_enable: RAS enabled on cpu5
[ 0.764820] carmel_ras carmel_ras: probed
[ 0.765886] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 477, noc_nonsecure_irq = 476>
[ 0.766396] tegra-cbb c600000.aon-noc: noc_secure_irq = 479, noc_nonsecure_irq = 478>
[ 0.767252] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 481, noc_nonsecure_irq = 480>
[ 0.768078] tegra-cbb be00000.rce-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 0.768894] tegra-cbb b600000.sce-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 0.769242] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.770469] vdd-ac-bat: 5000 mV
[ 0.770828] vdd-sdmmc1-sw: 3300 mV
[ 0.771134] vdd-1v8-sd: 1800 mV
[ 0.771477] vdd-usb2-5v: 5000 mV
[ 0.771750] vdd-3v3-cvb: 3300 mV
[ 0.772015] vdd-1v8-cvb: 1800 mV
[ 0.772324] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.772357] vdd-epb-1v0: 1000 mV
[ 0.772728] avdd-cam-2v8: 2800 mV
[ 0.773003] vdd-fan: 5000 mV
[ 0.773275] vdd-hdmi-5v0: 5000 mV
[ 0.773569] vdd_sys_en: 1200 mV
[ 0.803354] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.808043] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.808326] SCSI subsystem initialized
[ 0.808609] libata version 3.00 loaded.
[ 0.808812] usbcore: registered new interface driver usbfs
[ 0.808854] usbcore: registered new interface driver hub
[ 0.808953] usbcore: registered new device driver usb
[ 0.819954] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.823006] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.830898] vdd-1v0: at 1000 mV
[ 0.834892] vdd-1v8-hs: at 1800 mV
[ 0.838924] vdd-1v8-ls: at 1800 mV
[ 0.842977] vdd-1v8-ao: at 1800 mV
[ 0.846952] vddio-ddr-1v1: at 1100 mV
[ 0.850737] vdd-rtc: at 800 mV
[ 0.851964] spmic-ldo1: at 2375 mV
[ 0.858784] vdd-ao-3v3: at 3300 mV
[ 0.866849] vddio-emmc-3v3: at 3300 mV
[ 0.868063] spmic-ldo4: at 1587 mV
[ 0.874911] vdd-usb-3v3: at 3300 mV
[ 0.882923] vddio-sdmmc1-3v3: at 3300 mV
[ 0.886951] vdd-csi-1v2: at 1200 mV
[ 0.888440] spmic-ldo8: at 1800 mV
[ 0.893164] GPIO line 246 (gpio_default) hogged as output/high
[ 0.894497] GPIO line 247 (gpio_default) hogged as output/high
[ 0.894767] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.895136] max77620 4-003c: max77620 probe successful
[ 0.895795] media: Linux media interface: v0.10
[ 0.895838] Linux video capture interface: v2.00
[ 0.897286] pps_core: LinuxPPS API ver. 1 registered
[ 0.897293] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.897345] PTP clock support registered
[ 0.897623] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.897882] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.897934] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.900462] trusty trusty: trusty version: Built: 18:08:23 Apr 8 2020
[ 0.900524] trusty trusty: selected api version: 3 (requested 3)
[ 0.901709] Advanced Linux Sound Architecture Driver Initialized.
[ 0.902164] Bluetooth: Core ver 2.22
[ 0.902204] NET: Registered protocol family 31
[ 0.902210] Bluetooth: HCI device and connection manager initialized
[ 0.902220] Bluetooth: HCI socket layer initialized
[ 0.902228] Bluetooth: L2CAP socket layer initialized
[ 0.902251] Bluetooth: SCO socket layer initialized
[ 0.904688] camchar: rtcpu character device driver loaded
[ 0.905187] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.905272] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.906243] clocksource: Switched to clocksource arch_sys_counter
[ 0.951857] VFS: Disk quotas dquot_6.6.0
[ 0.951948] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.952279] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.953489] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 0.953546] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.953787] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.953795] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.953809] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 0.953817] nvmap_page_pool_init: Total RAM pages: 1985965
[ 0.953823] nvmap_page_pool_init: nvmap page pool size: 248245 pages (969 MB)
[ 0.953981] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.954472] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.957076] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 0.969454] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.969633] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.969804] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 0.969997] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 0.970168] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.971432] la/ptsa driver initialized.
[ 0.971787] NET: Registered protocol family 2
[ 0.972661] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.972990] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.973570] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.973624] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.973741] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.974247] NET: Registered protocol family 1
[ 0.974921] RPC: Registered named UNIX socket transport module.
[ 0.974927] RPC: Registered udp transport module.
[ 0.974933] RPC: Registered tcp transport module.
[ 0.974938] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.974948] PCI: CLS 0 bytes, default 64
[ 0.975238] Trying to unpack rootfs image as initramfs…
[ 1.163859] Freeing initrd memory: 5432K
[ 1.180862] random: fast init done
[ 1.185534] host1x 13e10000.host1x: initialized
[ 1.187518] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.192215] audit: initializing netlink subsys (disabled)
[ 1.192255] audit: type=2000 audit(0.812:1): initialized
[ 1.193088] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.203052] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.204444] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.205141] 9p: Installing v9fs 9p2000 file system support
[ 1.210714] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.210896] io scheduler noop registered
[ 1.211123] io scheduler cfq registered (default)
[ 1.214632] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.247878] iommu: Adding device 2993000.adsp to group 56
[ 1.361898] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[ 1.362912] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.375464] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.375918] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.376517] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.376970] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.377400] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.380363] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.380532] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.383168] tsec 15500000.tsec: initialized
[ 1.384804] tsec 15100000.tsecb: initialized
[ 1.388522] nvdec 15480000.nvdec: initialized
[ 1.390928] nvdec 15140000.nvdec1: initialized
[ 1.396534] falcon 15340000.vic: initialized
[ 1.398483] falcon 15380000.nvjpg: initialized
[ 1.400447] falcon 154c0000.nvenc: initialized
[ 1.402312] falcon 15a80000.nvenc1: initialized
[ 1.405927] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.407239] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.408605] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.409944] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.411302] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.412729] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.414069] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.415442] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.418772] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.424010] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.424324] scare-pigeon 14b00000.isp-thi: initialized
[ 1.429776] pva 16000000.pva0: initialized
[ 1.436142] pva 16800000.pva1: initialized
[ 1.441106] nvdla 15880000.nvdla0: initialized
[ 1.445955] nvdla 158c0000.nvdla1: initialized
[ 1.447358] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.447371] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.447420] tegradccommon 15200000.dc_common: dma mapping done
[ 1.447545] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 1.447555] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.447947] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.447979] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.448214] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.448222] tegra_cec 3960000.tegra_cec: probed
[ 1.448863] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.448903] generic_infoframe_type: 0x87
[ 1.448979] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.449007] tegradc 15200000.nvdisplay: Display dc.ffffff800bd50000 registered with id=0
[ 1.453099] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[ 1.453110] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[ 1.453116] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 179200000 Hz
[ 1.453315] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.453324] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.456805] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.456813] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.460758] tegradc 15200000.nvdisplay: probed
[ 1.461685] Console: switching to colour frame buffer device 80x30
[ 1.461714] tegradc 15200000.nvdisplay: fb registered
[ 1.462178] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.462249] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.462688] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.462733] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.462854] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.462886] tegradc 15210000.nvdisplay: Display dc.ffffff800be50000 registered with id=1
[ 1.463116] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.463125] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.463764] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.463774] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.464511] kfuse 3830000.kfuse: initialized
[ 1.470475] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.474919] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.476698] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.477262] tegradc 15210000.nvdisplay: probed
[ 1.477440] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.477591] tegradc 15210000.nvdisplay: fb registered
[ 1.478779] console [ttyTCU0] enabled
[ 1.479125] [drm] Initialized
[ 1.482473] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.482482] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.482494] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.482508] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.482522] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.482527] Extcon DP: HPD disabled
[ 1.482532] hpd: hpd_switch 0
[ 1.482538] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.482549] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.482558] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.519667] brd: module loaded
[ 1.537269] loop: module loaded
[ 1.537354] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.537485] tegra_profiler: auth: init
[ 1.538046] THERMAL EST: found 3 subdevs
[ 1.538052] THERMAL EST num_resources: 0
[ 1.538059] [THERMAL EST subdev 0]
[ 1.538065] [THERMAL EST subdev 1]
[ 1.538070] [THERMAL EST subdev 2]
[ 1.538080] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.538418] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.538424] THERMAL EST: thz register success.
[ 1.542640] THERMAL EST: end of probe, return err: 0
[ 1.543323] sd: No Scsi addr parsed to reserve index
[ 1.543355] hisi_sas: driver version v1.6
[ 1.553860] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.553869] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.553880] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.554281] 1 ofpart partitions found on MTD device spi6.0
[ 1.554288] Creating 1 MTD partitions on “spi6.0”:
[ 1.554298] 0x000000000000-0x000002000000 : “Whole_flash0”
[ 1.556730] libphy: Fixed MDIO Bus: probed
[ 1.557411] tun: Universal TUN/TAP device driver, 1.6
[ 1.557416] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.558357] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 1.558363] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 1.558419] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.558423] igb: Copyright © 2007-2014 Intel Corporation.
[ 1.558459] igbvf: Intel® Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.558464] igbvf: Copyright © 2009 - 2012 Intel Corporation.
[ 1.558509] Intel® 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.558514] Copyright© 1999 - 2017 Intel Corporation.
[ 1.805927] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 3 50 5e
[ 1.806028] libphy: dwc_phy: probed
[ 1.808752] PPP generic driver version 2.4.2
[ 1.809129] PPP BSD Compression module registered
[ 1.809136] PPP Deflate Compression module registered
[ 1.809155] PPP MPPE Compression module registered
[ 1.809161] NET: Registered protocol family 24
[ 1.809245] usbcore: registered new interface driver r8152
[ 1.809313] usbcore: registered new interface driver asix
[ 1.809362] usbcore: registered new interface driver ax88179_178a
[ 1.809395] usbcore: registered new interface driver cdc_ether
[ 1.809425] usbcore: registered new interface driver net1080
[ 1.809491] usbcore: registered new interface driver cdc_subset
[ 1.809521] usbcore: registered new interface driver zaurus
[ 1.809562] usbcore: registered new interface driver cdc_ncm
[ 1.809759] VFIO - User Level meta-driver version: 0.3
[ 1.811032] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.811052] ehci-pci: EHCI PCI platform driver
[ 1.811106] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.811118] ohci-pci: OHCI PCI platform driver
[ 1.811150] ohci-platform: OHCI generic platform driver
[ 1.816400] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.818252] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4de0c00 id
[ 1.818551] usbcore: registered new interface driver uas
[ 1.818650] usbcore: registered new interface driver usb-storage
[ 1.818720] usbcore: registered new interface driver usbserial
[ 1.822026] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 1.822105] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.822922] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.822932] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 1.823094] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.823323] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.823660] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 1.823700] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.823721] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.823792] mousedev: PS/2 mouse device common for all mice
[ 1.823933] usbcore: registered new interface driver xpad
[ 1.824422] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.824490] tegra-xusb 3610000.xhci: irq 463, io mem 0x03610000
[ 1.824750] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.824758] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.824765] usb usb1: Product: xHCI Host Controller
[ 1.824771] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.824777] usb usb1: SerialNumber: 3610000.xhci
[ 1.825287] hub 1-0:1.0: USB hub found
[ 1.825358] hub 1-0:1.0: 4 ports detected
[ 1.825948] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.825961] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.825971] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.826454] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.826461] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.826467] usb usb2: Product: xHCI Host Controller
[ 1.826474] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.826480] usb usb2: SerialNumber: 3610000.xhci
[ 1.826986] hub 2-0:1.0: USB hub found
[ 1.827028] hub 2-0:1.0: 4 ports detected
[ 1.957188] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.958584] Wake73 for irq=42
[ 1.959876] rtc rtc1: alarm rtc device
[ 1.959892] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.959919] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.960138] i2c /dev entries driver
[ 1.962931] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 1.970002] clk-bpmp: failed to initialize clk 280
[ 1.970140] ERROR: could not get clock /bthrot_cdev:cpu0(0)
[ 1.970863] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 1.975044] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 1.975107] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 1.975114] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 1.975223] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 1.975315] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 1.975321] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 1.975612] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 1.975678] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 1.975684] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 1.976008] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 1.976075] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 1.976081] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 1.976452] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 1.976531] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 1.976537] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 1.976842] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 1.977519] FAN dev name: pwm-fan
[ 1.977570] FAN:gpio request success.
[ 1.977580] FAN: can’t find tach_gpio
[ 1.977591] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 1.977636] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 1.977923] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.977930] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.978579] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.978586] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 1.978592] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 1.978598] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 1.978603] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.978609] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.978614] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.978620] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.978648] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.978654] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.979966] device-mapper: uevent: version 1.0.3
[ 1.980501] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.983778] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 1.984964] cpuidle: Initializing cpuidle driver
[ 1.985985] sdhci: Secure Digital Host Controller Interface driver
[ 1.985990] sdhci: Copyright© Pierre Ossman
[ 1.985993] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.986332] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.987195] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.989028] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 245
[ 1.992778] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.993731] tegra-se-nvhost 15810000.se: initialized
[ 1.994755] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.995768] tegra-se-nvhost 15820000.se: initialized
[ 1.997233] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 1.998046] tegra-se-nvhost 15830000.se: initialized
[ 1.998849] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 1.999964] tegra-se-nvhost 15840000.se: initialized
[ 2.001149] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 2.001465] hidraw: raw HID events driver © Jiri Kosina
[ 2.003111] usbcore: registered new interface driver usbhid
[ 2.003115] usbhid: USB HID core driver
[ 2.007305] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 2.008516] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 2.009030] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.009787] denver_knobs_init:MTS_VERSION:48073932
[ 2.009971] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 2.010966] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.011393] t19x_cache tegra-cache: probed
[ 2.013454] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 2.013462] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 2.014057] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 2.016201] nvpmodel: initialized successfully
[ 2.017492] trusty-virtio trusty:virtio: initializing
[ 2.017734] trusty_ipc virtio0: vring0: va(pa) ffffffc1f2bd0000(0) qsz 32 notifyid 1
[ 2.017746] trusty_ipc virtio0: vring1: va(pa) ffffffc1f2bd2000(0) qsz 32 notifyid 2
[ 2.017873] trusty-virtio trusty:virtio: initializing done
[ 2.018110] trusty_ipc virtio0: is online
[ 2.018976] tegra-hda 3510000.hda: Override SDO lines to 4
[ 2.019358] usbcore: registered new interface driver snd-usb-audio
[ 2.032284] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 2.032487] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 2.032658] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 2.032842] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 2.034329] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 2.034388] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.119231] OPE platform probe
[ 2.119377] OPE platform probe successful
[ 2.150234] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.191561] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.191680] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.191772] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.191886] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.192004] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.192113] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.192207] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.192292] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.192379] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.192469] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.192555] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 2.192659] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 2.192764] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 2.192856] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 2.192976] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 2.193103] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 2.193211] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 2.193304] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 2.193345] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489
[ 2.193351] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.193355] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 2.193359] usb 1-2: Manufacturer: Generic
[ 2.193393] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 2.193528] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 2.194794] hub 1-2:1.0: USB hub found
[ 2.196102] hub 1-2:1.0: 4 ports detected
[ 2.223978] u32 classifier
[ 2.223983] Actions configured
[ 2.224063] Initializing XFRM netlink socket
[ 2.224699] NET: Registered protocol family 10
[ 2.225476] NET: Registered protocol family 17
[ 2.225491] NET: Registered protocol family 15
[ 2.225565] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.225663] Bluetooth: RFCOMM socket layer initialized
[ 2.225695] Bluetooth: RFCOMM ver 1.11
[ 2.225703] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.225716] Bluetooth: HIDP socket layer initialized
[ 2.225734] 9pnet: Installing 9P2000 support
[ 2.225780] Key type dns_resolver registered
[ 2.226605] Registered cp15_barrier emulation handler
[ 2.226624] Registered setend emulation handler
[ 2.228388] registered taskstats version 1
[ 2.228857] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 2.229875] OF: PCI: host bridge /pcie@14160000 ranges:
[ 2.229909] OF: PCI: IO 0x36100000…0x361fffff -> 0x36100000
[ 2.229918] OF: PCI: MEM 0x1740000000…0x17ffffffff -> 0x40000000
[ 2.229924] OF: PCI: MEM 0x1400000000…0x173fffffff -> 0x1400000000
[ 2.333898] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.455155] tegra_cec 3960000.tegra_cec: Can’t find physical addresse.
[ 2.455161] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.473107] mmc0: hw tuning done …
[ 2.473163] mmc0: new ultra high speed SDR104 SDXC card at address 0001
[ 2.473720] mmcblk0: mmc0:0001 ED4QT 119 GiB
[ 2.476221] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 2.746980] tegra-pcie-dw 14160000.pcie: link is down
[ 2.747153] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 2.747161] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 2.747169] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 2.747176] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 2.747181] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 2.747212] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 2.747421] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.747678] iommu: Adding device 0004:00:00.0 to group 58
[ 2.747885] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 2.747909] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.748095] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.748102] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.748184] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 2.748323] pcie_pme 0004:00:00.0:pcie001: unloading service driver pcie_pme
[ 2.748364] aer 0004:00:00.0:pcie002: unloading service driver aer
[ 2.748471] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 2.748576] iommu: Removing device 0004:00:00.0 from group 58
[ 2.748602] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 2.750285] usb 1-2: usb_suspend_both: status 0
[ 2.750315] tegra-pcie-dw 14160000.pcie: PCIe link is not up…!
[ 2.750356] usb usb1: usb_suspend_both: status 0
[ 2.751304] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 2.752618] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 2.752643] OF: PCI: IO 0x3a100000…0x3a1fffff -> 0x3a100000
[ 2.752653] OF: PCI: MEM 0x1f40000000…0x1fffffffff -> 0x40000000
[ 2.752659] OF: PCI: MEM 0x1c00000000…0x1f3fffffff -> 0x1c00000000
[ 3.266503] tegra-pcie-dw 141a0000.pcie: link is down
[ 3.266738] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 3.266746] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 3.266754] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 3.266761] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 3.266765] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 3.266813] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 3.266981] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 3.267229] iommu: Adding device 0005:00:00.0 to group 58
[ 3.267626] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 3.267650] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 3.267889] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 3.267897] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 3.268006] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 3.268172] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[ 3.268262] aer 0005:00:00.0:pcie002: unloading service driver aer
[ 3.268370] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 3.268533] iommu: Removing device 0005:00:00.0 from group 58
[ 3.268611] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 3.270425] tegra-pcie-dw 141a0000.pcie: PCIe link is not up…!
[ 3.281313] tegra-cbb 14040000.cv-noc: noc_secure_irq = 89, noc_nonsecure_irq = 88>
[ 3.286896] tegra194-isp5 14800000.isp: initialized
[ 3.294616] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 3.297509] tegra194-vi5 15c10000.vi: initialized
[ 3.302474] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 3.302549] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 3.303357] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 3.385361] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 3.385809] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.386067] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 3.386295] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 3.386703] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 3.386787] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 3.387059] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 3.387088] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.388040] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 3.388528] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 3.388623] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 3.388801] input: gpio-keys as /devices/gpio-keys/input/input4
[ 3.419252] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:15 UTC (946688415)
[ 3.419824] mmcblk mmc0:0001: Card claimed for testing.
[ 3.460332] bpmp: mounted debugfs mirror
[ 3.466917] vdd-1v8-sd: disabling
[ 3.466924] vdd-1v8-cvb: disabling
[ 3.466927] vdd-epb-1v0: disabling
[ 3.466930] avdd-cam-2v8: disabling
[ 3.466933] vdd-fan: disabling
[ 3.466937] vdd_sys_en: disabling
[ 3.466946] ALSA device list:
[ 3.466950] #0: tegra-hda-galen-t194 at 0x3518000 irq 64
[ 3.466953] #1: jetson-xaviernx-ape
[ 3.469078] Freeing unused kernel memory: 8576K
[ 3.501499] Root device found: mmcblk0p1
[ 3.502656] Found dev node: /dev/mmcblk0p1
[ 3.987348] EXT4-fs (mmcblk0p1): 13 orphan inodes deleted
[ 3.987355] EXT4-fs (mmcblk0p1): recovery complete
[ 4.072954] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 4.074098] Rootfs mounted over mmcblk0p1
[ 4.100223] Switching from initrd to actual rootfs
[ 4.282456] systemd[1]: System time before build time, advancing clock.
[ 4.330421] ip_tables: © 2000-2006 Netfilter Core Team
[ 4.334663] cgroup: cgroup2: unknown option “nsdelegate”
[ 4.345072] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.345675] systemd[1]: Detected architecture arm64.
[ 4.353983] systemd[1]: No hostname configured.
[ 4.354002] systemd[1]: Set hostname to .
[ 4.472075] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 4.472086] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.642344] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.642748] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.642891] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.642917] systemd[1]: Reached target User and Group Name Lookups.
[ 4.642987] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.643153] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.643201] systemd[1]: Reached target Swap.
[ 4.725683] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 4.973111] systemd-journald[2218]: Received request to flush runtime journal from PID 1
[ 5.952237] random: crng init done
[ 5.952246] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.004523] Wake76 for irq=199
[ 6.004530] Wake77 for irq=199
[ 6.004533] Wake78 for irq=199
[ 6.004535] Wake79 for irq=199
[ 6.004538] Wake80 for irq=199
[ 6.004541] Wake81 for irq=199
[ 6.004543] Wake82 for irq=199
[ 6.004588] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 6.004593] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 6.285270] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 6.335111] usb 2-3: new SuperSpeedPlus USB device number 2 using tegra-xusb
[ 6.372194] usb 2-3: New USB device found, idVendor=0bda, idProduct=0489
[ 6.372204] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.372212] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 6.372217] usb 2-3: Manufacturer: Generic
[ 6.382719] hub 2-3:1.0: USB hub found
[ 6.384560] hub 2-3:1.0: 4 ports detected
[ 6.962524] usb 2-3: usb_suspend_both: status 0
[ 6.962712] usb usb2: usb_suspend_both: status 0
[ 7.806397] using random self ethernet address
[ 7.806521] using random host ethernet address
[ 8.214262] tegra-xusb 3610000.xhci: entering ELPG
[ 8.217458] tegra-xusb 3610000.xhci: entering ELPG done
[ 9.314918] ras_fhi_disable: FHI 470 disabled
[ 9.315443] CPU2: shutdown
[ 9.315557] psci: CPU2 killed.
[ 9.379265] ras_fhi_disable: FHI 471 disabled
[ 9.380116] CPU3: shutdown
[ 9.380286] psci: CPU3 killed.
[ 9.438896] ras_fhi_disable: FHI 472 disabled
[ 9.439492] CPU4: shutdown
[ 9.439658] psci: CPU4 killed.
[ 9.486852] ras_fhi_disable: FHI 473 disabled
[ 9.488243] CPU5: shutdown
[ 9.488347] psci: CPU5 killed.
[ 9.496057] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 10.223179] zram: Added device: zram0
[ 10.226933] zram: Added device: zram1
[ 10.274335] zram0: detected capacity change from 0 to 2037215232
[ 10.312579] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.343445] Adding 1989464k swap on /dev/zram0. Priority:5 extents:1 across:1989464k SS
[ 10.360276] zram1: detected capacity change from 0 to 2037215232
[ 10.392552] Adding 1989464k swap on /dev/zram1. Priority:5 extents:1 across:1989464k SS
[ 10.627437] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 10.637666] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.049585] tegradc 15200000.nvdisplay: blank - powerdown
[ 13.049600] tegradc 15210000.nvdisplay: blank - powerdown
[ 16.739108] fuse init (API version 7.26)
[ 16.887590] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.887607] Bluetooth: BNEP socket layer initialized
nvidia@localhost:~ nvidia@localhost:~ ls /dev
autofs capture-vi-channel35 nvhost-isp tty22
block capture-vi-channel4 nvhost-isp-thi tty23
btrfs-control capture-vi-channel5 nvhost-msenc tty24
bus capture-vi-channel6 nvhost-nvcsi tty25
camchar-dbg capture-vi-channel7 nvhost-nvdec tty26
camchar-echo capture-vi-channel8 nvhost-nvdec1 tty27
capture-isp-channel0 capture-vi-channel9 nvhost-nvdla0 tty28
capture-isp-channel1 char nvhost-nvdla1 tty29
capture-isp-channel10 console nvhost-nvenc1 tty3
capture-isp-channel11 constraint_cpu_freq nvhost-nvjpg tty30
capture-isp-channel12 constraint_gpu_freq nvhost-prof-gpu tty31
capture-isp-channel13 constraint_online_cpus nvhost-pva0 tty32
capture-isp-channel14 cpu_dma_latency nvhost-pva1 tty33
capture-isp-channel15 cpu_freq_max nvhost-sched-gpu tty34
capture-isp-channel16 cpu_freq_min nvhost-tsec tty35
capture-isp-channel17 cuse nvhost-tsecb tty36
capture-isp-channel18 disk nvhost-tsg-gpu tty37
capture-isp-channel19 emc_freq_min nvhost-vi tty38
capture-isp-channel2 fb0 nvhost-vic tty39
capture-isp-channel20 fb1 nvhost-vi-thi tty4
capture-isp-channel21 fd nvmap tty40
capture-isp-channel22 full port tty41
capture-isp-channel23 fuse ppp tty42
capture-isp-channel24 gpiochip0 psaux tty43
capture-isp-channel25 gpiochip1 ptmx tty44
capture-isp-channel26 gpiochip2 ptp0 tty45
capture-isp-channel27 gpu_freq_max pts tty46
capture-isp-channel28 gpu_freq_min ptyp0 tty47
capture-isp-channel29 hugepages ptyp1 tty48
capture-isp-channel3 i2c-0 ptyp2 tty49
capture-isp-channel30 i2c-1 ptyp3 tty5
capture-isp-channel31 i2c-2 ptyp4 tty50
capture-isp-channel32 i2c-3 ptyp5 tty51
capture-isp-channel33 i2c-4 ptyp6 tty52
capture-isp-channel34 i2c-5 ptyp7 tty53
capture-isp-channel35 i2c-6 ptyp8 tty54
capture-isp-channel36 i2c-7 ptyp9 tty55
capture-isp-channel37 i2c-8 ptypa tty56
capture-isp-channel38 iio:device0 ptypb tty57
capture-isp-channel39 initctl ptypc tty58
capture-isp-channel4 input ptypd tty59
capture-isp-channel40 keychord ptype tty6
capture-isp-channel41 kmem ptypf tty60
capture-isp-channel42 kmsg quadd tty61
capture-isp-channel43 l3cache quadd_auth tty62
capture-isp-channel44 log ram0 tty63
capture-isp-channel45 loop0 ram1 tty7
capture-isp-channel46 loop1 ram10 tty8
capture-isp-channel47 loop2 ram11 tty9
capture-isp-channel48 loop3 ram12 ttyp0
capture-isp-channel49 loop4 ram13 ttyp1
capture-isp-channel5 loop5 ram14 ttyp2
capture-isp-channel50 loop6 ram15 ttyp3
capture-isp-channel51 loop7 ram2 ttyp4
capture-isp-channel52 loop-control ram3 ttyp5
capture-isp-channel53 mapper ram4 ttyp6
capture-isp-channel54 max_cpu_power ram5 ttyp7
capture-isp-channel55 max_gpu_power ram6 ttyp8
capture-isp-channel56 max_online_cpus ram7 ttyp9
capture-isp-channel57 media0 ram8 ttypa
capture-isp-channel58 mem ram9 ttypb
capture-isp-channel59 memory_bandwidth random ttypc
capture-isp-channel6 min_online_cpus rfkill ttypd
capture-isp-channel60 mmcblk0 rtc ttype
capture-isp-channel61 mmcblk0p1 rtc0 ttypf
capture-isp-channel62 mmcblk0p10 rtc1 ttyS0
capture-isp-channel63 mmcblk0p11 shm ttyS1
capture-isp-channel7 mmcblk0p2 snd ttyS2
capture-isp-channel8 mmcblk0p3 spidev0.0 ttyS3
capture-isp-channel9 mmcblk0p4 spidev0.1 ttyTCU0
capture-vi-channel0 mmcblk0p5 spidev2.0 ttyTHS0
capture-vi-channel1 mmcblk0p6 spidev2.1 ttyTHS1
capture-vi-channel10 mmcblk0p7 stderr ttyTHS4
capture-vi-channel11 mmcblk0p8 stdin uhid
capture-vi-channel12 mmcblk0p9 stdout uinput
capture-vi-channel13 mqueue tegra_camera_ctrl urandom
capture-vi-channel14 mtd0 tegra_cec vcs
capture-vi-channel15 mtd0ro tegra-crypto vcs1
capture-vi-channel16 mtdblock0 tegra_dc_0 vcs2
capture-vi-channel17 net tegra_dc_1 vcs3
capture-vi-channel18 network_latency tegra_dc_ctrl vcs4
capture-vi-channel19 network_throughput tegra_mipi_cal vcs5
capture-vi-channel2 null trusty-ipc-dev0 vcs6
capture-vi-channel20 nvhdcp0 tty vcsa
capture-vi-channel21 nvhdcp1 tty0 vcsa1
capture-vi-channel22 nvhost-as-gpu tty1 vcsa2
capture-vi-channel23 nvhost-ctrl tty10 vcsa3
capture-vi-channel24 nvhost-ctrl-gpu tty11 vcsa4
capture-vi-channel25 nvhost-ctrl-isp tty12 vcsa5
capture-vi-channel26 nvhost-ctrl-nvcsi tty13 vcsa6
capture-vi-channel27 nvhost-ctrl-nvdec tty14 vfio
capture-vi-channel28 nvhost-ctrl-nvdec1 tty15 vhci
capture-vi-channel29 nvhost-ctrl-nvdla0 tty16 watchdog
capture-vi-channel3 nvhost-ctrl-nvdla1 tty17 watchdog0
capture-vi-channel30 nvhost-ctrl-pva0 tty18 zero
capture-vi-channel31 nvhost-ctrl-pva1 tty19 zram0
capture-vi-channel32 nvhost-ctxsw-gpu tty2 zram1
capture-vi-channel33 nvhost-dbg-gpu tty20
capture-vi-channel34 nvhost-gpu tty21
