Hello dears,
In general, we use a 60w power adapter for the Xavier NX to test YoLov5 by
20w 6 cores and the performance is 28FPS
10w 4 cores and the performance is 25FPS
we only replace the power adapter to 120w, we see the performance increasing double to 50FPS with similar power consumption (17w)
Although both tests are going to be system throttling after few minutes, how to explain Xavier NX seems to extract out of spec power to improve performance?
Is that real power consumption in jtop what I see?
What is the real maximum power consumption of Xavier NX if the thermal and over-current issue can be managed?
Thanks for your reply.
Cheers,
Jay
