We are working on a Xavier NX based solution where we require to run ML models to check for abnormal sounds(crashes,gunshots).For that we are planning to use a single i2s mic and use native tegra xbar codec to achieve the noise reduction.Can you please let us know if APE in Xavier NX capable of the same and if so please let us know if there is any specifc guide for the same.
Hi Jaivishnu,
ADSP is not fully productized as part of current Jetpack releases, though the nodes are enabled by default in DT. This would limit the technical support for ADSP for current releases.
Yes, I agree either ADSP or Main CPU with external NC algorithm shall be ported to realize your usecase.
