Dear All,
In our carrier board, there is a M.2B Key connect to SOM’s usb3.0(without hub).
We’ve flash the officier’s jetpack r32.6.1 Image with few adjust at usb section.
- L4t Driver package
https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t186/jetson_linux_r32.6.1_aarch64.tbz2 - L4t Root filesystem
https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t186/tegra_linux_sample-root-filesystem_r32.6.1_aarch64.tbz2 - L4t source
https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/sources/t186/public_sources.tbz2
DTS adjust content
diff -ruN tegra194-p3668-all-p3509-0000_default.dts tegra194-p3668-all-p3509-0000_usb3_compliance.dts
--- tegra194-p3668-all-p3509-0000_default.dts 2022-01-21 19:15:27.262212295 +0800
+++ tegra194-p3668-all-p3509-0000_usb3_compliance.dts 2022-01-21 19:19:38.927123814 +0800
@@ -7128,7 +7128,10 @@
usb3-2 {
status = "okay";
- nvidia,usb2-companion = <0x1>;
+//lanner++
+// nvidia,usb2-companion = <0x1>;
+ nvidia,usb2-companion = <0x2>;
+//lanner--
usb3-3 {
DTS File(Revert from Linux_for_Tegra/kernel/dtb/)
tegra194-p3668-all-p3509-0000_usb3_compliance.dts (253.1 KB)
In this scenario, we’ve follow the ‘Jetson_Xavier_NX_Tuning_and_Compliance_Guide_Application_Note’
and tried to make the usb 3 enter compliance.
echo on > /sys/bus/usb/devices/usb1/power/control
echo on > /sys/bus/usb/devices/usb2/power/control
devmem2 0x03610440 w 0x10340
log file
Xavier_NX_usb_compliance_20220221_1547.log (41.2 KB)
But, there seems no signal from the M.2 B-Key so far.
Would you mind to give us some suggestion?
Best Regards,
MOMO Chen
