Xavier nx with JP 4.4.1 "build_opencv.sh 4.4.0" fails
I’m using xavier nx with JP 4.4.1 and trying to install open cv from GitHub - mdegans/nano_build_opencv: Build OpenCV on Nvidia Jetson Nano using the ./build_opencv.sh 4.4.0 command.
It fails:
Blockquote
$ sudo ./build_opencv.sh 4.4.0
It appears an existing build exists in /tmp/build_opencv
Do you wish to remove temporary build files in /tmp/build_opencv ?
(Doing so may make running tests on the build later impossible)
Y/N y
Installing build dependencies.
Hit:1 Index of /ubuntu-ports bionic InRelease
Hit:2 Index of /ubuntu-ports bionic-updates InRelease
Hit:3 Index of /ubuntu-ports bionic-backports InRelease
Hit:4 Index of /ubuntu-ports bionic-security InRelease
Hit:5 https://repo.download.nvidia.com/jetson/common r32.4 InRelease
Get:6 https://repo.download.nvidia.com/jetson/t194 r32.4 InRelease [2,565 B]
Fetched 2,565 B in 3s (949 B/s)
Reading package lists… Done
Building dependency tree
Reading state information… Done
Calculating upgrade… Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up nvidia-l4t-bootloader (32.4.4-20201027211332) …
3668----1–wolf-22xp-dp-mmcblk0p1
Starting bootloader post-install procedure.
ERROR. Procedure for bootloader update FAILED.
Cannot install package. Exiting…
dpkg: error processing package nvidia-l4t-bootloader (–configure):
installed nvidia-l4t-bootloader package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Blockquote
any help?
thanks
Please check this topic as a reference.
It looks like there is an apt upgrade in the script.
Could you remove the command and try it again?
Thank.s
I used this one and it solved this problem:
I don’t know why it solved it or what was the problem.
Thank you for your help!
