Xavier NX wont boot, sdkmanager hangs up while trying to flash
I did not connect the micro USB. I thought the magic wire did the connection.
Here is the output after the connected the micro usb:
[0011.458] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet lev.
[0011.467] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0011.472] I> Boot-mode: Platform RCM
[0011.475] I> Chip revision : A02P
[0011.478] I> Bootrom patch version : 15 (correctly patched)
[0011.484] I> ATE fuse revision : 0x200
[0011.487] I> Ram repair fuse : 0x0
[0011.490] I> Ram Code : 0x0
[0011.493] I> rst_source : 0x0
[0011.496] I> rst_level : 0x0
[0011.499] I> USB configuration success
[0013.574] I> mb2 image downloaded
[0013.595] I> Recovery boot mode 0
[0013.598] I> Boot-device: QSPI
[0013.603] I> UPHY full init done
[0013.607] I> MB1 done
[0013.612] W> Profiler not initialized
[0013.616] I> Welcome to MB2(TBoot-BPMP) Applet (version: 00.00.2018.32-mobile-)
[0013.624] W> Profiler not initialized
[0013.627] I> DMA Heap @ [0x40020000 - 0x40065800]
[0013.632] I> Default Heap @ [0xd486400 - 0xd48a400]
[0013.636] W> Profiler not initialized
[0013.640] W> Profiler not initialized
[0013.643] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0013.649] W> device prod register failed
[0013.653] W> Profiler not initialized
[0013.657] E> Error in command_complete 18001 int_status
[0013.662] E> OCR failed, error = f0f0706
[0013.666] I> SDMMC is not present.
[0013.670] I> QSPI Flash Size = 32 MB
[0013.681] I> Qspi initialized successfully
The console gets stuck here
The magic wire is just to dump log from UART. If you google search “uart” and you will find out the speed of it…
It won’t be possible to transfer a ~15GB OS to the board with such interface…
Did you remember to plug your sdcard to the module?
thanks. yes the 64 GB SD card is inserted
Ok, this looks like hardware broken. Cannot tell whether this is carrier board or module problem.
Please RMA it.
thanks for your help
