Using SDK Manager, I flashed JetPack 4.6 (rev.3) to boot from a 128GB NVME. After the flash I was able to go through the first run configuration using the /dev/ttyACM0 interface over usb-dev-mode. Once that was done, I can ssh in and everything seems to be working. If I run $ systemctl get-default, it returns graphical.target. The problem I’m having is that the GUI doesn’t load. The display just shows the nvidia splash screen forever.
Looking for some help troubleshooting this.
Other Info:
This is an industrial Xavier NX with an eMMC mounted in an aftermarket clone of the Xavier NX dev board. If I flash to the eMMC, everything works as expected, including the GUI Desktop.
