Hi Team,
We are using xavier NX and 32.4.3 release , after connecting the DP port we are able to get GUI and it is working fine.
But when we are trying to read details using console ‘xrandr’ command is not showing result.
Following are result :
xrandr
No protocol specified
Can’t open display :0
xrandr
Can’t open display :1
Can you guys help, what we missed ?
Alks
Will xrandr give you a result if you use the terminal on the screen but not remote access?
Hi @WayneWWW,
We are using debug UART(/dev/ttyUSB0) and also tried on ACM0 node on host laptop using minicom.
Actually we have to get details of screen/DP/HDMI, need to get/set resolution using debug UART linux command/code.
Yes, I know your purpose but please just reply my question first.
Yes @WayneWWW, It is working on screen (checked on Display port terminal).
working : xrandr
$ echo $DISPLAY
:1
Does this only happen to DP? I just tried my HDMI monitor with same setup but does not have problem.
We don’t have HDMI setup. Using DP only.
Ok. I will check with my DP.
I cannot reproduce your issue with my NX+ DP monitor.
Could you reboot your device and try again?
nvidia@nvidia-desktop:~$ export DISPLAY=:0
nvidia@nvidia-desktop:~$ xrandr
Screen 0: minimum 8 x 8, current 3840 x 2160, maximum 32767 x 32767
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 600mm x 340mm
3840x2160 60.01*+ 30.00
2560x1440 59.96
1920x1080 60.00 59.95 50.00 30.00 29.97 25.00 24.00 23.98
1680x1050 59.96
1440x900 59.89
1366x768 59.79
1280x1024 75.03 60.00
1280x960 60.00
1280x800 59.81
1280x768 59.87
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.01
832x624 75.05
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
720x400 70.04
640x480 75.00 72.81 67.06 59.94 59.94
