Xavier NX 模块客户运行视频监控软件,出现视频监控画面卡死,视频监控软件闪退问题。
xavier NX 模块客户运行视频监控软件,出现视频监控画面卡死,视频监控软件闪退问题。如下是错误日志截图和错误码。附件为报错日志文件。
logsNX_20250707.zip (2.3 MB)
Wha’t kind of camera? CSI/USB? YUV/Bayer?
What’s the BSP version?
摄像头通过以太网传输H.264格式的视频流,不涉及摄像头原始数据的编码(YUV/Bayer)
BSP:L4T 32.7.1 Jetpack:4.6.1
报错信息:Aug 8 09:12:46 XavierNX kernel: [ 821.044449] nvgpu: 17000000.gv11b gp10b_priv_ring_isr:120 [ERR] ringmaster intr status0: 0x00000000,status1: 0x00000001
Aug 8 09:12:46 XavierNX kernel: [ 821.044800] nvgpu: 17000000.gv11b gp10b_priv_ring_isr:164 [ERR] GPC0 write error. ADR 0x0041801c WRDAT 0x3f800000 INFO 0x1d40822a (subid 0x0000001d priv level 0), CODE 0xbadf1201
Aug 8 09:12:46 XavierNX kernel: [ 821.045084] nvgpu: 17000000.gv11b gp10b_priv_ring_decode_error_code:78 [ERR] client timeout
Aug 8 09:12:46 XavierNX kernel: [ 821.045255] nvgpu: 17000000.gv11b gk20a_ptimer_isr:46 [ERR] PRI timeout: ADR 0x0041801c READ DATA 0x00000000
Aug 8 09:12:46 XavierNX kernel: [ 821.045457] nvgpu: 17000000.gv11b gk20a_ptimer_isr:56 [ERR] FECS_ERRCODE 0xbadf1201
Aug 8 09:12:46 XavierNX kernel: [ 821.045629] nvgpu: 17000000.gv11b gp10b_priv_ring_decode_error_code:78 [ERR] client timeout
What’s the use case?
Do you use gstreamer or jetson_multimedia_api? Seems like you don’t use hardware decoder NVDEC.
1)实时视频采用OpenCV 4.4.1拉流播放,历史视频存储采用ffmpeg 3.4.8,都是用的模块内部的库;
2)OpenCV 4.4.1内部应该是调用了GStreamer拉流,至于Gstreamer是否使用了jetson_multimedia_api,需要英伟达自己核实;
3)是否使用了NVDEC decoder,也是英伟达自己从底层库分析
What’s the gstreamer pipeline?
