Xavier one max9296+two max96705+ two sensor
We use one max9296+two max96705+ two sensor on xavier jetpack4.4,
the clock speed of MIPI output configured by SENSOR is 400Mbps. How can I configure the CLOCK speed of MIPI output of SOC terminal (Xavier) also be 400Mbps?
BR.
MIPI output clocks is control by sensor device or max96705 you may need check with vendor.
Hi ShaneCCC,
